Upgraded Brakes question for those who have done it Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Beltran |
Expert Posts: 1730 Location: Michigan | I am converting my 55 to disk with a new booster and master cylinder. What distribution block did you use to split the disk output into two lines and accommodate the brake sensor? | ||
Shep |
Expert Posts: 3416 Location: Chestertown, NY ( near Lake George) | The appropriate proportioning valve is the right way to do this. | ||
Phatton |
Veteran Posts: 174 Location: Camptown PA | Most any proportioning valve from a disc/drum brake car will work. I used one from a chrysler E body car on mine - it works fine. | ||
1955windsor |
Member Posts: 20 Location: St. Martins NB | What are you using to convert to discs, the '55 Chryslers seem to be odd man out. | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | AAJ Brakes seems to have the most comprehensive kits for Forward Look cars http://aajbrakes.com/ I've done 2 cars with his kits, a 60 and a 62 Chrysler. Edited by imopar380 2014-11-11 9:23 PM | ||
Mopar1 |
Expert Posts: 3040 Location: N.W. Fla. | imopar380 - 2014-11-11 8:22 PM He has "business 4 sale" ads posted on this site. Might try Rusty Hope and/or Scare bird. both Google.AAJ Brakes seems to have the most comprehensive kits for Forward Look cars http://aajbrakes.com/ I've done 2 cars with his kits, a 60 and a 62 Chrysler. | ||
60 Windsor |
Member Posts: 41 Location: South Central PA | I spoke with Roger about a month ago, he was trying to sell off the non mopar side of the business at one point but he said he just acquired a lathe to keep the business going. I just got a rear kit from him 2 weeks ago. | ||
Beltran |
Expert Posts: 1730 Location: Michigan | Yes I have been working with Roger too. He is very supportive and his kit will work with the 55. I am in the middle of the break down at the moment. Amazing how easy this car comes apart... I had to get a lower control arm kit from Burnbaum... will arrive next week some time.. then I can get back to it. I ended up getting a willwood distribution block. It's a very neat and clean fit with the booster / Master Cylinder I have. I will post some pictures soon. | ||
Mopar1 |
Expert Posts: 3040 Location: N.W. Fla. | imopar380 - 2014-11-11 8:22 PM On my '60 Plym I swapped in disc spindles, not an option on '55s, but easy on the newer models.I've done 2 cars with his kits, a 60 and a 62 Chrysler. | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | I had a couple of minor issues with the AAJ kit, but was just glad to have a source for the conversion. The part quality is excellent and everything was furnished. I don't know about the distribution block model, and it's not installed yet, but I'm going to rely on the one provided in the kit. I have a couple entries in my blog about the brake installations, and here is one post, and there are earlier enties...FWIW. (Purists and finicky restorers; save yourself a case of ulcers and don't bother visiting the site!) http://56plymouth.blogspot.com/2014/09/it-rolls.html | ||
Beltran |
Expert Posts: 1730 Location: Michigan | Thanks Gary. My conversion is being documented on the site. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=55600&... | ||
Beltran |
Expert Posts: 1730 Location: Michigan | oh.. and it turns out that my lower bushing wasn't bad after all. It had 'normal' play as the new one was exactly the same. Well I now have some spare and rare parts for my 55... who knows.. maybe my daughter will need them in another 60 years. | ||
