cable removal help!!!!
fireguyfire
Posted 2014-10-14 3:45 PM (#459206)
Subject: cable removal help!!!!
1002525
Trying to remove the cable from my 56 powerflite pushbutton at the tranny so I can pull the engine and tranny out for overhaul. Pulled the tranny pan and popped the pointy end of the spring that goes through the hole out, but I still cant remove this stupid cable. It comes out about 1/4" and then stops. Am I missing something? It is almost like it is hanging up on the o-ring that seals the cable to the tranny, but I have pulled on it with all of my strength and it will not come out.
Suggestions? This stupid cable is frustrating the heck out of me!
Shep
Posted 2014-10-14 5:24 PM (#459221 - in reply to #459206)
Subject: Re: cable removal help!!!!
20001000100100100100
That clip retainer must be pried up/off the retaining groove to release the cable.
fireguyfire
Posted 2014-10-14 5:59 PM (#459225 - in reply to #459206)
1002525
Got it out! the O ring was holding it up; I was able to pry it out of its groove and the cable slid right out.
The bad news is I lost the O ring. Anybody know sizing on those O rings?
Beltran
Posted 2014-10-14 8:11 PM (#459236 - in reply to #459206)
100050010010025
search the site.. I know that has come up before. Someone posted it.
kari613
Posted 2014-10-29 4:07 PM (#460555 - in reply to #459225)
Next time-- notch a V in the end of a flat blade screw driver and insert in thru the top of the neutral switch hole-push in slightly while you pull the cable out. The o'ring can be very hard to find. I took my old ring to a few parts stores, hardware stores and 3 trans. shops before i found the correct size that would hold up in trans. fluid.
