hammermg in freeze plug procedure
dodge59
Posted 2014-05-14 8:27 PM (#440821)
Subject: hammermg in freeze plug procedure
1000
I have a freeze plug  that I have to replace  in my 241 hemi .
what would you guys recommend  for a sealant around the disc ?  seen some guys you a black tarry permatex  sealer./gasket sealer
it's a dished  freeze plug
Thanks !
Edited by dodge59 2014-05-14 8:28 PM
VAN HELSING
Posted 2014-05-14 11:20 PM (#440844 - in reply to #440821)
Subject: RE: hammermg in freeze plug procedure
500100100100100252525
I have used a product for well over 35 years now called " Stag " jointing paste which is used for sealing up steam piping joins on boilers etc with good results always.
I'm in Australia so not sure if STAG is available overseas in the US or not but here it is here on evilbay.
http://www.ebay.com/itm/Stag-Wellseal-Gasket-Jointing-Compound-100m...
60 dart
Posted 2014-05-15 12:09 AM (#440851 - in reply to #440821)
Subject: Re: hammermg in freeze plug procedure
50002000100050010010010010025
i've never used anything on a saucer type freeze plug . i've been messin with motors for over 50 yrs. and never had one saucer type plug leak . when one installs sauce type plugs
peen em in like ya own em but not like ya want to destroy em and they won't leak or come out ---------------------------------------------later
Mopar1
Posted 2014-05-15 5:48 AM (#440876 - in reply to #440851)
2000100025
I use a little JB Weld.....
dodge59
Posted 2014-05-15 9:47 PM (#441004 - in reply to #440821)
1000
Thanks for your opinions guys !
john
wbower3
Posted 2014-05-15 9:55 PM (#441006 - in reply to #440821)
Walter passed away on Jul 29, 2014. We will miss you, Walt!
50001001001002525
Permatex will work. Apply it to the edges of the hole before you drive the plug in.
dodge59
Posted 2014-05-18 10:26 PM (#441420 - in reply to #440821)
1000
<p style="text-align: center;">I punched a larger hole in the old freeze plug  to let it drain out , got the old one ot  then  stuck the garden hose in there to flush it out ,,,,,and another one pounded in . I used ultra black permatex on the install and a little on the outside. good to go. Thanks guys ! john</p>
Edited by dodge59 2014-05-18 10:47 PM
(weeping freeze 40%plug.JPG)
(freeze plug fixed 40%.JPG)
Attachments weeping freeze 40%plug.JPG (94KB - 80 downloads)
Attachments freeze plug fixed 40%.JPG (62KB - 73 downloads)
