Location: bishop, ca | Mike, the OEM undercoating was applied after the car was primered and painted, and before the car's body
was "Dropped" onto the asembled rolling chassis.
There should not be any undercoating appearing on the frame rails or on the chassis equipment, altho the
gas tank can be covered by the undercoating.
The inside of the trunk received an amalgam of undercoating/sealer which was then contacted by the body color(s)
painting's overspraying.
The trunk's inner reinforcements were painted in the main body color, but, the asphaltic deadener panel was not
(supposed to be-) painted, and should show its un-painted-over mottled appearance, which can be in several
different shades.
The trunk hinges got hit with the body-color, as did the trunk torsion bar-springs and some/most of the underside of
the parcel shelf, and some over spray unavoidably got to be heavily applied onto the middle area of the fuel filler tube.
can you post up some pics of your car's appearance?
Welcome aboard (again-).
