What did you do to your FL car today? Jump to page : < ... 58 59 60 61 62 63 64 65 66 > Now viewing page 64 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 7400 Location: northern germany | imopar380 - 2017-08-25 12:03 PM the clutch fan, referenced in above post! excellent piece, at least it looks like the mopar performace 5 blade fan/clutch (according to them the unit that robs the least amount of hp from an engine) i have been running for 25 years without problems. replaced it with a lighter aluminum version that does not cool as well. | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | 1960fury - 2017-08-25 9:31 AM excellent piece, at least it looks like the mopar performace 5 blade fan/clutch (according to them the unit that robs the least amount of hp from an engine) i have been running for 25 years without problems. replaced it with a lighter aluminum version that does not cool as well. The clutch fan is actually a 7-blade unit. The original non-clutch unit is a 6 blade fan. We arrived home from our trip today after 12 days out with the car. That fan worked great, the temp gauge didn't come near the hot mark at all, even when stuck in some heavy traffic hardly moving. In the past the gauge would creep right up near the hot line in a situation like that during hot weather. Edited by imopar380 2017-08-26 7:43 PM | ||
Viper Guy |
Expert Posts: 2003 Location: Branson, MO | Took my '59 Firesweep to an "orphan" car show sponsored by the Studebaker-Packard club. Not only my DeSoto but believe it or not there was another and it too is a FL! (IMG_0738.JPG) (IMG_0756.JPG) Attachments ---------------- IMG_0738.JPG (123KB - 554 downloads) IMG_0756.JPG (101KB - 557 downloads) | ||
Coronet 59 |
Member Posts: 34 Location: Eringsboda/Blekinge/Sweden | Tried to get the rear window out, but the window gasket is hard as a rock ! | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | YESTERDAY. Took Both the Dodges to our local town Vintage day,,, (172.jpg) (173.jpg) (174.jpg) Attachments ---------------- 172.jpg (222KB - 545 downloads) 173.jpg (234KB - 548 downloads) 174.jpg (237KB - 545 downloads) | ||
FinFury57 |
Elite Veteran Posts: 693 Location: Kangasala, Finland | Tube day (rRadio_57.jpg) Attachments ---------------- rRadio_57.jpg (223KB - 542 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Took the '55 Suburban to a local car show. (phpEftqzhAM.jpg) (php2RbAPdAM.jpg) Attachments ---------------- phpEftqzhAM.jpg (112KB - 558 downloads) php2RbAPdAM.jpg (150KB - 553 downloads) | ||
1961plymouthfury |
Expert Posts: 2633 Location: Minor Hill, TN | Did some sanding on the body were it was needed to be done. I got more por 15 and its waiting to be applied were it is needed. | ||
brdtee |
Veteran Posts: 263 Location: Pieksamaki, Finland, Europe | Took some storaged junk out of the trunk today. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Looks like your Windsor is coming together nicely Heikki. That will be a sweet car to cruise around in once you get it back together. I started to work on the left side exhaust on my New Yorker today, but a friend of mine brought by an 8 3/4 that he wanted me to cut & weld to A-body specs. That ate up the majority of my day so I didn't get much else done. Oh well, there's always tomorrow right? | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Today was busy. I started off by shampooing my 56 Dodge's rear seat bottom: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=65218&... While that was drying, I moved into the garage and played with the brake adjustment on my D500 Center-plane 12" x 2.5" brakes (left front - it had locked on a few weeks ago backing the car out of the garage): http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68135&... And then while I still had the wheel off, I finally installed the custom 0 gauge solenoid to starter cable that I had made months ago. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=66809&... And while I was under there, I took a photo of the throttle pedal lever boot that I made and installed months ago: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=66984&... And finally before I put the left wheel back on, I wire-brushed the upper and lower suspension control arms and painted them (heavily) with a cheap hog's hair brush and Tremclad (think Rustoleum) semi-gloss black rust paint. I will have to do the other (right) side when I lubricate those center-plane brake shoes at some point in the near future. I had to avoid the urge to paint the anti-roll bar black while I was there - mostly because I don't know what the correct colour is/was (black? silver?). Same with the bumper brackets (I did paint the frame rails while I was there). Then I started the car after weeks of not being started and let it run up to a good temperature (monitored the generator output on fast idle and it was something like 13.9V). Then I cleaned up outside, came in, washed up and cracked a beer. | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Please add some heat shrink to that joint where the cable meets the lug at the starter. Stranded cable has a tendency to pull loose from lugs over time, especially welding wire. Some good shrink wrap with the adhesive inside will keep that connection tight forever. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I've been using the Coronet to commute to work until I can get the parts to fix my daily driver. It looks out of place among the sea of new cars. (Commuter.jpg) Attachments ---------------- Commuter.jpg (144KB - 515 downloads) | ||
Viper Guy |
Expert Posts: 2003 Location: Branson, MO | All too often we never pay much attention to the stone shields. These things take about as much abuse as anything on the car but seldom, if ever, get more than a wash or polish/wax. Today I renewed mine after about 60 years of being on the car. (IMG_1600.jpg) (IMG_1601.jpg) (IMG_1604.jpg) Attachments ---------------- IMG_1600.jpg (118KB - 480 downloads) IMG_1601.jpg (102KB - 487 downloads) IMG_1604.jpg (82KB - 489 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Viper Guy - 2018-04-13 10:38 PM All too often we never pay much attention to the stone shields. These things take about as much abuse as anything on the car but seldom, if ever, get more than a wash or polish/wax. Today I renewed mine after about 60 years of being on the car. Very nice. Look better than new. How? | ||
Viper Guy |
Expert Posts: 2003 Location: Branson, MO | 56D500boy - 2018-04-13 9:57 PM Viper Guy - 2018-04-13 10:38 PM All too often we never pay much attention to the stone shields. These things take about as much abuse as anything on the car but seldom, if ever, get more than a wash or polish/wax. Today I renewed mine after about 60 years of being on the car. Very nice. Look better than new. How? :) 80 grit sandpaper, then 150, then 400, then 600, then 1000, and finally - the buffing wheel. And thank you for the compliment! | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | I've been working on my steering column and shaft all week. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68374&... | ||
Mstrat2727 |
Member Posts: 7 | Sun visors on 57 custom royal | ||
macedon |
Elite Veteran Posts: 963 Location: San Antonio, TX | I'm rearranging my shop, moving some stuff around to give me more room to remove the front clip off my Desoto. I got reminded just how freakin' MASSIVE a 392 and tranny is. Sheesh! (392.JPG) Attachments ---------------- 392.JPG (93KB - 481 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Some progress on making 56 Desoto carpet set fit into a 56 Dodge without too many obvious glitches. No blood was split so that was a good thing. Still need another day to get the final positions worked out. It's not going to be perfect. But much better than when I got the car. Old photo (but not much new): | ||
RUSTORICHES |
Extreme Veteran Posts: 494 Location: Alberta | macedon - 2018-04-17 5:51 PM I'm rearranging my shop, moving some stuff around to give me more room to remove the front clip off my Desoto. I got reminded just how freakin' MASSIVE a 392 and tranny is. Sheesh! Here You need one of these for that 392……Custom made to fit ( 354 0n Engine Test Stand p1.jpg) Attachments ---------------- 354 0n Engine Test Stand p1.jpg (89KB - 492 downloads) | ||
firedome |
Expert Posts: 3155 Location: NY & VT | Curious as to why a '56 DeS carpet was used? Aren't similar sets available for just about all makes? Looks good in any event. Edited by firedome 2018-04-18 9:27 AM | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | macedon - 2018-04-17 6:51 PM I'm rearranging my shop, moving some stuff around to give me more room to remove the front clip off my Desoto. I got reminded just how freakin' MASSIVE a 392 and tranny is. Sheesh! They are HUGE! And when you start pulling them apart, they get even bigger! But they can be fun too. I used some chain, eye bolts, an engine leveler, and a 2x4 to make this front-clip arrangement. It allowed me to use an electric winch to lift it in the air to keep it from taking up so much space. I had it high enough that we could walk under it. The clip could be attached to an engine hoist to move it around. Worked well for me. (1.jpg) (2.jpg) (3.jpg) Attachments ---------------- 1.jpg (310KB - 482 downloads) 2.jpg (203KB - 471 downloads) 3.jpg (269KB - 590 downloads) | ||
macedon |
Elite Veteran Posts: 963 Location: San Antonio, TX | 57burb - 2018-04-18 9:38 AM I used some chain, eye bolts, an engine leveler, and a 2x4 to make this front-clip arrangement. It allowed me to use an electric winch to lift it in the air to keep it from taking up so much space. I had it high enough that we could walk under it. The clip could be attached to an engine hoist to move it around. Worked well for me. That's a cool set-up for the front clip. I may just try that myself. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Not as exciting as a front clip hoist but I worked hard on getting my two piece Stock Interiors/ACC 1956 "Dodge Desoto" carpet set (which turned out to be for a 55/56 Desoto Fireflite 4 dr sedan) into its final positions and then starting the trimming (because the Desoto is so much wider) and the cutting of holes for the front seat mount and the new shoulder belt outboard bottom mount and the seat belt receiver. I struggled to get things symmetrical but eventually realized that there were too many hard points, i.e. the steering column hole, the gas pedal hole that were set by ACC (even after they redid the front piece) and subsequently the headlight high beam switch and the windshield washer pump pin, that symmetrical was not going to happen. Won't really be an issue because the seat will hide the things that aren't symmetrical anyway. I used an awl to line up the sill plate in its proper position (using the awl through the screw holes, into the holes in the rocker panel) and then I market the inner edge of the sill plate with masking tape. I ended up trimming about 1.5" off the front of the rear section in the right front passenger door area and a bit more in the rear of the rear section by the right rear passenger door area. I am targeting to have about 1" of carpet (with no padding) under the inner edge of the sill cover. I still have to trim the outer edges of the front carpet piece. Made good progress today - once I got over the symmetrical thing. So I was quite happy with the day (which also included rough fitting the carbon fibre version of my cold air scoop). Hey, soon I might have a real front seat and I can retire the milk crate and foam pad and go for a real drive! Edited by 56D500boy 2018-04-19 2:11 AM (TrimmingStockInteriorsACCDodgeDesotoCarpet_1.jpg) (TrimmingStockInteriorsACCDodgeDesotoCarpet_2.jpg) Attachments ---------------- TrimmingStockInteriorsACCDodgeDesotoCarpet_1.jpg (221KB - 493 downloads) TrimmingStockInteriorsACCDodgeDesotoCarpet_2.jpg (220KB - 482 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | I replaced the 3" rear lowering blocks with 2" ones. After driving it, the stock springs were sagging to the point it was getting a little too low in the rear. The last straw was when the driveshaft rubbed. Eventually I'll put some shorter and stiffer leaf springs on it to get rid of the blocks altogether. I ran all the wires to get the power windows operational again. Still have to wire in the relays and switches to get it all working. At the same time I installed a small amp and the cables to get an iPod or wireless/Bluetooth device playing through the speakers. Other than that, I just drove it a bit. Man it is sweet. Edited by 57burb 2018-04-23 1:12 PM (20180416_200629 (2).jpg) Attachments ---------------- 20180416_200629 (2).jpg (175KB - 474 downloads) | ||
Knighty |
Extreme Veteran Posts: 444 Location: Victoria, AUSTRALIA | just removed the body from the chassis
(20180423_213932_resized.jpg) (20180423_212708_resized.jpg) (20180423_212652_resized.jpg) (20180423_213704_resized.jpg) Attachments ---------------- 20180423_213932_resized.jpg (137KB - 467 downloads) 20180423_212708_resized.jpg (79KB - 474 downloads) 20180423_212652_resized.jpg (92KB - 461 downloads) 20180423_213704_resized.jpg (157KB - 462 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | '55 New Yorker convertible. Now THERE is a car worth saving! Love it. | ||
RUSTORICHES |
Extreme Veteran Posts: 494 Location: Alberta | My D500 and I parted ways today,yep she left me for the the "Canadian Big Rock Candy Mountain"….. Kelowna BC is where she's now calling home (Untitled.jpg) Attachments ---------------- Untitled.jpg (144KB - 454 downloads) | ||
fivespeedv8 |
Regular Posts: 68 Location: Seven Valleys, PA | I installed the engine... (IMG_4184.JPG) (IMG_4185.JPG) (IMG_4186.JPG) (IMG_4187.JPG) Attachments ---------------- IMG_4184.JPG (134KB - 489 downloads) IMG_4185.JPG (143KB - 452 downloads) IMG_4186.JPG (139KB - 457 downloads) IMG_4187.JPG (137KB - 456 downloads) | ||
1961plymouthfury |
Expert Posts: 2633 Location: Minor Hill, TN | My dad is doing the finishing touches before the paint and I am polishing the stainless steel . I am also starting 1 once a week | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I continued on with the windlace install - working on the driver's side rear door of my 56 Dodge http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68557&... I also scanned and posted Section B of the 56 Dodge Date book: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68637&... | ||
Viper Guy |
Expert Posts: 2003 Location: Branson, MO | Way overdue, but today I decided to have my front seat cushion re-padded with new foam 'cause I just got tired of the "sugar" foam falling down under the seat. With the car being 59 years old and a wee bit out of warranty, I finally bit the bullet. As much as I wanted to keep the car as factory original as possible, I realize there are such things as limitations and this is one of them. Hopefully I will feel, and actually be, a little taller in the saddle when all is said and done. | ||
skyhawk |
Veteran Posts: 161 Location: newton north carolina | Annual hand applied wax job! (59 Ply wax job 5-18.jpg) Attachments ---------------- 59 Ply wax job 5-18.jpg (210KB - 459 downloads) | ||
60 Imp |
Location: North Australia | If I owned a Plymouth like that, I would be doing ''Hand applied Wax Jobs'' way more often than annually Nice Plymouth! Steve. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Technically it was yesterday but I: 1. Finished (mostly) the carpet install in my 56 Dodge 2. Added vinyl and some OE-style trim to the bottom of my painted ABS kick panel (right side so far): 3. Put the front seat back in (been out since late October for the carpet install prep), set up the driver's side three point shoulder belt that I installed and took the car for a spin. Engine smoked Hope it was just the lack of driving (only around the block sitting on a milk crate periodically since November). Fingers crossed it goes away with more driving or I can at least manage it. | ||
skyhawk |
Veteran Posts: 161 Location: newton north carolina | Thanks for the compliment, Steve! Car stays in out of the weather, but more frequent waxing would be better. I shall try harder. Edited by skyhawk 2018-05-29 4:50 PM | ||
Viper Guy |
Expert Posts: 2003 Location: Branson, MO | Well, I did it again after I said I wouldn't. I went to the Route 66 All MoPar show again held at Presley's Jubilee theater here in Branson. There were 147 MoPars with about 10 being older than 2017 models (being a fit facetious) but you get the point. Sad to say only the "Geritol" generation paid much attention to the older cars. I did get a fairly neat picture of King Kong scaling the building in the background using my right tailfin as a "sight". (IMG_1792.jpg) (IMG_1805.jpg) Attachments ---------------- IMG_1792.jpg (114KB - 453 downloads) IMG_1805.jpg (75KB - 470 downloads) | ||
LostDeere59 |
Extreme Veteran Posts: 406 Location: Hilltown, PA | Well today I got "intimate" with my Desoto for the first time. New LF lower balljoint, new thrust rod bushings, new idler arm bearing kit, new shocks all the way around. And some miscellaneous minor things. Haven't aligned it yet, but I can say it's already so much better/tighter/smoother. And I also want to especially thank Sid - the idler arm bearing kit you sent is AWESOME! Fits perfect, smooth motion, no play - and greasable! I think that the idler arm kit alone made most of the difference in how the steering feels. Once I get the alignment done it should be better than new. So next weekend it's on to plugs, wires, service . . . Getting ready for the drive to Carlisle! Gregg | ||
62 Newport |
Member Posts: 17 Location: Västerås Sweden | Painted with new dash pad. (20180108_162301.jpg) (20180108_182219.jpg) Attachments ---------------- 20180108_162301.jpg (446KB - 446 downloads) 20180108_182219.jpg (372KB - 452 downloads) | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | Installed a brand new reduction drive aftermarket starter on the 60 Saratoga. The old starter was starting to fail - cranking slow when hot, and other issues. Bought from Quality Power. http://www.qualitypowerauto.com/catalog.php?item=600 I also helped install one of these three weeks ago on Islander_62's 1961 Saratoga. A minor glitch was that the edge of the flange in one spot rubbed against the side of the engine block so it wouldn't seat in the bellhousing properly. It took a few minutes with a file to make it work. It was the same for both cars. (20180624_170025_resized.JPG) (b.JPG) (Filed_down.JPG) Attachments ---------------- 20180624_170025_resized.JPG (77KB - 453 downloads) b.JPG (58KB - 444 downloads) Filed_down.JPG (105KB - 453 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I had to do the same thing on mine for the '60 413, but maybe not quite as far as yours. http://forwardlook.net/forums/forums/thread-view.asp?tid=66444&post... | ||
60 Imp |
Location: North Australia | Ian and Nathan, can you please quote manufacturer and part number for the starters you used please. Just want to confirm numbers before I buy one for my 1960 Imperial. Steve. Edited by 60 Imp 2018-07-10 7:41 AM | ||
60 Imp |
Location: North Australia | After work I put the Imperial on the hoist and re-adjusted the brake shoes again. I fixed my bad brake issues over the past couple days, plus drained and refreshed the fuel as it had been sitting 6 months. Car is fully serviceable again Steve. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | You can just do a quick search on Ebay to get them. Type in "1960 Chrysler IMI" and you will find them. I believe the part number that IMI uses is MDT6001, or maybe 126-001. Edited by Powerflite 2018-07-10 3:08 PM | ||
Expert 5K+ Posts: 7400 Location: northern germany | Nathan, was the new starter lighter than the OE one? It looks huge, but aluminum-like. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Much lighter. I estimate by about 10 lbs, but I didn't measure it. Edited by Powerflite 2018-07-10 5:46 PM | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | 60 Imp - 2018-07-10 4:38 AM Ian and Nathan, can you please quote manufacturer and part number for the starters you used please. Just want to confirm numbers before I buy one for my 1960 Imperial. Steve. Here is the link showing the starters for various years and models. http://www.qualitypowerauto.com/catalog.php?item=600 | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Paid the nearby Quicklane to change the manual transmission lube in the 1955 Plymouth. After changing the differential and engine oil, I'd had enough of being under the car. I wanted to have all new lube before driving up to Carlisle tomorrow. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Drove the '55 wagon to Carlisle. Something is not right with it. Feels like an exhaust restriction. But, we got there, had a great day. Headed home, coming down US-15 between Emmitsburg and Thurmont, MD, the throttle return spring snapped. Fortunately, the car is slow enough that it wasn't a huge problem being stuck at WOT. I had to briefly ride the brakes a couple of times to maintain interval with traffic ahead of me going downhill. We hit the flats around Lewistown, north of Frederick and I turned off the ignition and pulled over. We called for a tow. While waiting, a farmer stopped, grabbed a pair of pliers and some wire and we were back in business. Cancelled the tow and drove on home. Stopped at the auto parts just before it closed and bought an assortment of return springs. Rolling the dice and headed back tomorrow. | ||
