What did you do to your FL car today?Jump to page : < ... 40 41 42 43 44 45 46 47 48 49 50 51 ... > Now viewing page 46 [50 messages per page] | View previous thread :: View next thread |
| Forward Look NON-Technical Discussions -> 1955-1961 Forward Look MoPar General Discussion | Message format |
| FIN ME |
Expert Posts: 2788 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: USA - KY | Me too, Jon! Hmmm...now the dilemma is, do I repaint the car prior to installing the Deluxe trim, and the dual antenna, and the rear bumper extensions, and... Sigh...it never ends, does it?! | ||
| JT Vincent |
Expert Posts: 1493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Jamaica Plain, MA | Actually Rosy, I would put the stuff on now. That way if you scratch the paint, or make a mistake you can fix it. The stainless isn't hard to deal with. Just clips, a few screws, a few nuts. Just don't bend it. Straightening stainless is a bear. | ||
| di_ch_NY56 |
Expert Posts: 1535 ![]() ![]() ![]() Location: ZH, Switzerland | Yesterday I did a short trip to warm up the engine and the oil. I rode as long until the oil pressure dropped a little bit at idle. That's the sign, that the oil got the operating temperature. Then I went back to the barn and changed the oil and oil filter. Uhh it was a messy job, but good luck - successful, thanks to the hints I got from Mike (the mechanic where I changed the oil in August). With the oil I let out I drove 310 miles (+/- 500 km). It was really black all the way. I put a finger into the open drain thread to dig out some of the sludge. It was rather hot and like jelly. The smell of the warm sludge reminds me somehow at molybdenum disulphide grease. I put it to a house hold paper towel and used white gas to separate the soluble parts of the sludge. Happy Motoring! Dieter (DSC01643resized.JPG) (DSC01644resized.JPG) (DSC01646resized.JPG) (DSC01648resized.JPG) Attachments ---------------- DSC01643resized.JPG (151KB - 682 downloads) DSC01644resized.JPG (160KB - 704 downloads) DSC01646resized.JPG (100KB - 652 downloads) DSC01648resized.JPG (148KB - 655 downloads) | ||
| 59CRL |
Expert Posts: 2679 ![]() ![]() ![]() ![]() ![]() ![]() | Went to a car show yesterday, my picture is in the local news paper. I bought a 5 foot skeleton a couple weeks ago and it is a prop I use in my car. People get a kick out of it. They do call me a 58 Dodge..... close http://www.thenewsenterprise.com/content/photos-smokin-rides-and-go... ![]() | ||
| Beltran |
Expert Posts: 1730 ![]() ![]() ![]() ![]() ![]() Location: Michigan | Today's progress was moving the car into the garage because I got a letter from the township telling me that no inopperable vehicles are allowed to be kept outside of a closed building in our township. I have 7 days to comply or I will receive a 300-500 dollar fine. (mind you I can site several examples around the neighborhood, but someone in the back of the subdivision feels the need to complain because they drive by my house on their way home) Tomorrow I am going to call the township and ask for a permit for a greenhouse. This will be erected on my driveway to be my second 'closed building'. I will also request a permit for a billboard to be placed facing the road in front of my house that says. 'to the asshat that complained to the township about my covered vintage car in my driveway. Hope you like the township approved view better now. " | ||
| koopster |
Veteran Posts: 170 ![]() ![]() ![]() Location: central Massachusetts | Baked a cake for Ms. Rose. Tomorrow marks that special day, October 11, 1954- 58 years ago, that she rolled off the assembly line. Did I mention I'll find any excuse for throwing a party?!! Question is...what do you buy a "55 Custom Royal that is spoiled rotten....... Edited by koopster 2012-10-10 7:36 PM | ||
| tnlowrider |
Extreme Veteran Posts: 501 ![]() Location: Upper East Tennessee | Rosy, I'm glad you finally got the trim! Now comes the fun of putting it on! FIN ME - 2012-09-27 9:03 AM Me too, Jon! Hmmm...now the dilemma is, do I repaint the car prior to installing the Deluxe trim, and the dual antenna, and the rear bumper extensions, and... Sigh...it never ends, does it?! :bleh: | ||
| Finadk |
Veteran Posts: 130 ![]() ![]() Location: Central NJ | I managed to mock up the Rack and Pinion setup for my 56 Dodge. I had a lot of problems getting clearance between the starter and the headers while leaving room for the steering shaft. The solution was a very small compact starter. Next I have to remove the steering column from the box, fabricate a lower bearing to support the steering shaft and connect it to the rack. I still have a lot of work to finalize the brackets and get it all to work but I have at least proven that it WILL fit. | ||
| oldwood |
Expert Posts: 2905 ![]() ![]() ![]() ![]() ![]() ![]() Location: little rock, AR | I adjusted the valves on my '61 Plymouth /6 tonight. When I took the VC off I really think the mileage is correct ie. 33k miles. The valve train was really clean. I pulled the plugs and found Champions,UGH!!! I'll replace these with NGK's. | ||
| Finadk |
Veteran Posts: 130 ![]() ![]() Location: Central NJ | I have been on a roll the past two months. Before moving to the steering I finalized fabricating the brackets for the Alternator and AC. This turned out to be quite an engineering exercise. I made over 20 different templates out of cardboard then 3/8 plywood until I finally got everything where id should be and lined up. | ||
| 57plymouth |
Expert Posts: 3641 ![]() ![]() ![]() ![]() ![]() Location: Blythewood, SC | Wouldn't it have been simpler to use the bracket from Bouchillon Performance? They make a small block sanden compressor mount. | ||
| Finadk |
Veteran Posts: 130 ![]() ![]() Location: Central NJ | I tried the Bouchillon mount first. Actually bought the compressor and bracket from them. The compressor sat about two inches higher and more toward the center of the engine. I also had the belt rubbing on the water pump pulley because I had to run an underdrive crank pulley to clear the crossmember. I never liked the way Chrysler mounted the compressors they are the first ugly thing you see when you open the hood , so once i figured out that i had to move it I made it as close to the block as possible. I tried for hours to find a way to mount It down low but on a small block it just can't be done if you especially if you are also running power steering. The under drive pulley also forced me to go with a High flow water pump, and a high output alternator that puts out 110 amps at idle so that I have the power required for the electric fans, fuel pump and fuel injection. Edited by Finadk 2012-10-11 8:16 AM | ||
| Chrome58 |
Expert Posts: 1321 ![]() ![]() ![]() ![]() Location: Belgium, 40 miles south of Brussels | I finally put in place the full Belvedere 3-piece headliner set I bought from Mel Bohnenkamp ($$$$) six years ago. With all the chrome parts (I did a Fury-like interior) and the Mylar strips it sure looks striking. Pictures will come as soon as possible. Edited by Chrome58 2012-11-01 3:15 PM | ||
| bel5758 |
Elite Veteran Posts: 716 ![]() ![]() ![]() | Brought Kate home from a neighbor's garage....wanted her indoors during Sandy. And shook my head in a very disappointing manner because of all the PS fluid she left on this good ol' boy's garage floor. Public thanks to Tommy in any event. | ||
| Chrome58 |
Expert Posts: 1321 ![]() ![]() ![]() ![]() Location: Belgium, 40 miles south of Brussels | As promised, here are some pictures ... (P1030113r.jpg) (P1030120r.jpg) (P1030151r.jpg) (P1030152r.jpg) (P1030153r.jpg) (P1030154r.jpg) (P1030157r.jpg) Attachments ---------------- P1030113r.jpg (163KB - 666 downloads) P1030120r.jpg (109KB - 662 downloads) P1030151r.jpg (121KB - 707 downloads) P1030152r.jpg (158KB - 707 downloads) P1030153r.jpg (146KB - 690 downloads) P1030154r.jpg (110KB - 709 downloads) P1030157r.jpg (123KB - 634 downloads) | ||
| Conelrad |
Regular Posts: 62 ![]() ![]() | I took the cat for a ride. It's the only car she likes to ride in. (CatInDesoto.jpg) Attachments ---------------- CatInDesoto.jpg (90KB - 683 downloads) | ||
| di_ch_NY56 |
Expert Posts: 1535 ![]() ![]() ![]() Location: ZH, Switzerland | Hi all Today - this afternoon I removed all nuts and screws at the drive shaft to remove it. But it resisted. Now I would like to get a hint how to remove the drive shaft without a hammer and chisel - or screw driver... any hint is very welcome. Thank you. I'm happy that the boot is intact, so I applied some silicone oil (spray...). Happy Motoring! Dieter (IMG_0974resized.jpg) (IMG_0976resized.jpg) Attachments ---------------- IMG_0974resized.jpg (105KB - 690 downloads) IMG_0976resized.jpg (106KB - 692 downloads) | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | Just insert a pry bar between the rear universal joint and the yoke. Push it in the center of the "cross" and the drive shaft will move forward on the splines.... | ||
| di_ch_NY56 |
Expert Posts: 1535 ![]() ![]() ![]() Location: ZH, Switzerland | Thank you very much Sven. I guess next Saturday I'm going to get the pry bar in my house (70 km away - one way). At Saturday evening there's the annual meeting of the ski club at the small village where my little house is. BTW: my propeller shaft does not have splines, just the trunnion... from what I noticed there's no lash in the trunnion, but inside the differential... the gasket at the input shaft is rather new. Happy Motoring! Dieter | ||
| Ray |
Expert Posts: 1497 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Fairfax, Minnesota | My son and I removed the brake vacuum booster. As soon as I find a strong shipping box, it will be on its way to Booster Dewey. Our working process for this adventure was a favorite of his- do the work and then read the manual to see if we screwed up anything. | ||
| recondo |
Regular Posts: 92 ![]() ![]() ![]() Location: montevallo, alabama | Dropped more money in the bottomless bucket again today, my god this is contageous insanity. my amx's were soooooo much simpler. yeah right there goes my selective memory kickin in again. I used to be a sane man, look what ya'll have done to me. Somebody make me an offer, no amount to small, FREE SHIPPING, BUY ONE GET ONE FREE!, FINANCING AVAILABLE , whew I'm alright now, those pills kick in pretty fast. | ||
| di_ch_NY56 |
Expert Posts: 1535 ![]() ![]() ![]() Location: ZH, Switzerland | This afternoon I removed the propeller shaft. It seems I did a little damage at the cover of the gasket holder/protection device... I used a tool from the Landlord and a block of wood and a hammer to tap at the trunnion (after I moved the farther end out of the yoke) until it started to free. When I move the case of the trunnion it feels like it would be new But the u-joint needs a little bit work (I plan to clean it with Diesel, try to fix the holder of the gasket and re-grease it). Happy Motoring! Dieter (DSC01655resized.JPG) (DSC01657resized.JPG) (DSC01659resized.JPG) (DSC01661resized.JPG) (DSC01667resized.JPG) Attachments ---------------- DSC01655resized.JPG (117KB - 680 downloads) DSC01657resized.JPG (117KB - 687 downloads) DSC01659resized.JPG (122KB - 678 downloads) DSC01661resized.JPG (110KB - 663 downloads) DSC01667resized.JPG (109KB - 680 downloads) | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | Looking good, there Dieter, over-all. Due to that front trunion-design, it is very difficult to balance our drivelines, but, what you can do, now, is either sand-blast the driveline, and/or wire-wheel polish it, to its bright shiny new appearance. When it is 'polished', you can either heavily clear-coat it, or apply a 'bare metal' or a 'bright aluminum' finish to it. The emergency brake drum, and the differential carrier housing should appear in natural "bare cast iron", and, there are "cast iron" paints which you can apply to them. Years ago, I clear coated the carrier housing, but surface rust somehow returned to the housing, underneath the clear coat. As "cast iron" paint looks just like what its title says, applying it to a fully stripped carrier (with lotsa surface texture on it) makes it look like brand-new, from several feet away, and, that is about as close as any casual observer will ever get to it, given its location! So, the driveline is very shiny/bright, and the brake drum and carrier housing are in 'natural' finish. That trunion joint cover can be in a sort of semi-gloss gray, or brownish color. Here's both ends of Horrie's driveline.... (And that's the Land Speed Record/Mighty-2.76 gear ratio diffie, that I bought off of Brent, here, a few years ago). Edited by d500neil 2012-11-14 3:46 PM (PICT0006.JPG) (PICT0007.JPG) Attachments ---------------- PICT0006.JPG (112KB - 687 downloads) PICT0007.JPG (109KB - 648 downloads) | ||
| C-300 |
Extreme Veteran Posts: 496 ![]() ![]() ![]() ![]() ![]() ![]() ![]() | I finally got the rear A/C unit installed in my 60 Polara. Aaron | ||
| di_ch_NY56 |
Expert Posts: 1535 ![]() ![]() ![]() Location: ZH, Switzerland | d500neil - 2012-11-13 9:09 PM Looking good, there Dieter, over-all. Due to that front trunion-design, it is very difficult to balance our drivelines, but, what you can do, now, is either sand-blast the driveline, and/or wire-wheel polish it, to its bright shiny new appearance. When it is 'polished', you can either heavily clear-coat it, or apply a 'bare metal' or a 'bright aluminum' finish to it. The emergency brake drum, and the differential carrier housing should appear in natural "bare cast iron", and, there are "cast iron" paints which you can apply to them. Years ago, I clear coated the carrier housing, but surface rust somehow returned to the housing, underneath the clear coat. As "cast iron" paint looks just like what its title says, applying it to a fully stripped carrier (with lotsa surface texture on it) makes it look like brand-new, from several feet away, and, that is about as close as any casual observer will ever get to it, given its location! So, the driveline is very shiny/bright, and the brake drum and carrier housing are in 'natural' finish. That trunion joint cover can be in a sort of semi-gloss gray, or brownish color. Here's both ends of Horrie's driveline.... (And that's the Land Speed Record/Mighty-2.76 gear ratio diffie, that I bought off of Brent, here, a few years ago). Hello Neil Big thank you for your answer and pictures. I was thinking about the drive shaft appearance as well. I don't know if it would be a good idea, but I thought about installing it (after re-greasing), use a block of wood and sand paper - let the engine run and work from the start until the end. So the propeller shaft starts rotating and I only have to hold the wood to the propeller shaft and the sand paper does it's work. Applying the color (base coat and cast iron color) I plan to do the same way. If I'll be careful I don't produce big imbalance. But my plan sounds very dangerous... But first I want do degrease the u-joint end. There's still some undercoating to remove. Happy Motoring! Dieter BTW: you still have the - or a - original u-joint mounted? I just wonder where to get it - just for the case ... | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | It's dangerous Dieter and I would not recommend it. Most probably, you're alone with your car in the garage and if the sandpaper gets stuck, or even worse, your sleeve, it can rip your arm off. I demounted the ball and trunnion, carefully wrapped the end with electrical tape, wrapped the universal joint as well. Then I cleaned the propeller shaft with a wire brush in a drill machine. The propeller shaft was then painted, hanging in a piece of welding rod in the garage roof. Absolutely no problem with the balance... | ||
| soiouz |
Expert Posts: 3490 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Montreal, Canada | Chrome58 - 2012-11-01 3:07 PM I finally put in place the full Belvedere 3-piece headliner set I bought from Mel Bohnenkamp ($$$$) six years ago. With all the chrome parts (I did a Fury-like interior) and the Mylar strips it sure looks striking. Pictures will come as soon as possible. :) Wow, the pictures are amazing! Beautiful interior!! The headliner looks perfect! | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | Dieter, you can slather the driveshaft with Naval Jelly, or some other rust removal product, to get a lot of the rust off of the driveshaft. Then, you go at it with several types of wire-wheels. Personally, if I had it to do over, again, I'd just get it sand blasted, and THEN polish it with the wire wheels. Naval Jelly-type rust remover should be used on the differential carrier. It can, then, be wire-wheeled. I was lucky in that the carrier was 'loose' and lying on the ground, when I attacked it with the 'jelly' and with the wire wheels. Your best bet might be to take off as much surface-rust as possible from the carrier, and then merely paint it with a thin coat of 'bare metal' paint, IF you have to work on it, up in the 'air', and not lying on the ground. Polishing the mounting nuts will make for a good contrast with the painted carrier housing. Then, clear-coat the carrier, which will preserve the 'bare' nuts and will brighten up the carrier's paint. Edited by d500neil 2012-11-15 7:15 PM | ||
| Beltran |
Expert Posts: 1730 ![]() ![]() ![]() ![]() ![]() Location: Michigan | Now your gonna make me take apart the drive shaft I just put in Neil! That is so nice looking, even if it is under the car and not seen very much. GAAAHH... I need some of Bob's pills. | ||
| jboymechanic |
Expert Posts: 2221 ![]() ![]() ![]() Location: Muskego, WI | Some long over due updates. The interior has been insulated with FatMat, I have sand blasted and painted the power seat rack, and the head liner, dome lights, and hangers have been restored and installed. All of the interior is being redone over the winter and the window frames and mechanisms have all been restored and installed. Hoping to get the car far enough along so it can be driven this coming summer. The Charger in the background of the one pic is my dad's in case any one asks. ![]() | ||
| di_ch_NY56 |
Expert Posts: 1535 ![]() ![]() ![]() Location: ZH, Switzerland | Happy New Year! Today I worked at the propeller shaft. A mechanic at the Ford dealer nearby pressed out the u-joint /w my assistance. Then I took the drilling machine and a wire brush to start cleaning the propeller shaft. The u-joint is dirty, but one arm has almost no wearing (lash between cup and shaft), the other three are like new (no lash). All four arms were running /w black, soft grease. I'll clean and re grease it. Here are two pics... A question: is the cover of the b/t reusable or where to get a NOS one? Happy Motoring! Dieter BTW: Jon thanks for the pictures of your Imperial. It's going to look wonderful. Edited by di_ch_NY56 2013-01-03 5:03 PM (IMG_1065resized.jpg) (IMG_1066resized.jpg) Attachments ---------------- IMG_1065resized.jpg (161KB - 658 downloads) IMG_1066resized.jpg (168KB - 753 downloads) | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | Happy new year Dieter! If the dust booth is free from cracks and not dried out, you can use it again. There is a guy that sells new booths - check your inbox..... | ||
| di_ch_NY56 |
Expert Posts: 1535 ![]() ![]() ![]() Location: ZH, Switzerland | I guess I need some more time to clean the propeller shaft. All of the loose rust is removed but it's not shiny as a new shaft. I plan to apply ground coat, then iron tone color and after that a coat of clear color. Happy Motoring! Dieter | ||
| Desotorandy |
Veteran Posts: 234 ![]() ![]() ![]() Location: Chambersburg,PA | Changed the coolant then took the Fireflite on a long drive,55 degrees,sunny, January in PA? I'd say it was Delovely,Delightful,a great day for a Desoto :O) Tomorrow it's to be about 60,will have to take her out again??? Edited by Desotorandy 2013-01-12 7:09 PM | ||
| imopar380 |
Expert 5K+ Posts: 7229 ![]() ![]() ![]() ![]() ![]() Location: Victoria, BC, on Vancouver Island, Canada | Well today was the second of 2 dry, sunny days after some pretty steady rain. So I hooked up Stella's battery and we went out for a drive. Then I came home and mowed the lawn.... | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | Good for you Ian (Green with envy)!!!!! Here the snow lies deep and nothing seems to be better. I have changed the lower control arms, upper control arms, all the relative rubber bushings and had an initial front end alignment. The rear leaf springs has been re-forged by an 87 year old blacksmith (still working 6 days aweek with his "younger" brother as a helper. An extra leaf was added to each side. The rear leaf bushings are now in polyurethane. I had an old friend Johnny at Johnnys Bil & Plåt doing the works in his workshop, since he has all the equipment and space. All the work went very smooth with a good result. The works will be followed up with new tires and rims, a final height adjustment and the final front end alignment. The aim is good cornering, roadability and safety, allowing active driving. Further the swivel seats and the power undercarriage was demounted today for to allow some work space for the installation of the power door locks. Also the windsheild wiper motor will be changed and the linkage serviced - my motor doesn't park the wipers anymor. | ||
| Beltran |
Expert Posts: 1730 ![]() ![]() ![]() ![]() ![]() Location: Michigan | You gotta work on your drive shaft now to aye Dieter. I blame Neil. | ||
| imopar380 |
Expert 5K+ Posts: 7229 ![]() ![]() ![]() ![]() ![]() Location: Victoria, BC, on Vancouver Island, Canada | wizard - 2013-01-13 8:51 AM Good for you Ian (Green with envy)!!!!! Here the snow lies deep and nothing seems to be better. Further the swivel seats and the power undercarriage was demounted today for to allow some work space for the installation of the power door locks. Also the windsheild wiper motor will be changed and the linkage serviced - my motor doesn't park the wipers anymor. Sven, are you putting in an original vacuum lock system, or after-market electrics? | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | Original Ian, I finally found a kit while ago - bought it from Herman | ||
| FIN ME |
Expert Posts: 2788 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: USA - KY | Today I yelled through the garage door, "I know I promised to take you for a spin today, but the darn rain just won't stop!". Yes, I talk to my DeSoto. | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | Have disassembled my AFB 2797S carburetors (1959) which I bought from Big M. As usual cutting brass screws in the throttle shafts or breaks. When you live in Sweden, it is not as easy to get hold of the screws in inch. Got hold of the right to end 6/32 in stainless, but the head of the screw a little too big. Cut them down to size yesterday. To fit the taper of the throttle shafts. Then cleaned everything before glass blasting and zinc plated in yellow and black. (DSC_4664.jpg) (DSC_4732.jpg) (DSC_4727.jpg) (DSC_4731.jpg) Attachments ---------------- DSC_4664.jpg (84KB - 649 downloads) DSC_4732.jpg (64KB - 641 downloads) DSC_4727.jpg (99KB - 591 downloads) DSC_4731.jpg (106KB - 618 downloads) | ||
| 60 Imp |
![]() ![]() ![]() ![]() Location: North Australia | Jboy, I occasionally wonder how you are going with this project. Looking awesome. More pic's appreciated Mate, I love the look of the 56 Imperials, especially the two door model. What have you done with the rear air evaporator? Sound insulation? Keen to know how you routed the refridgerant lines too. I plan to fit a vintage air rear unit to my 60. Steve. | ||
| JGomez |
Veteran Posts: 163 ![]() ![]() ![]() Location: Metro Detroit | Wired up my dome light, fixed the door switch. Now I need a lens! | ||
| big m |
Expert 5K+ Posts: 7831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Williams California | I didn't do much other than drive my car to work, but I did pick up a '56 Chrysler wagon, '58 Plymouth 2-door wagon, 2- '57 Belvedere 4-door hardtops, and a '60 Dodge Seneca sedan from a fellow that is more of a muscle car guy. ---John | ||
| jboymechanic |
Expert Posts: 2221 ![]() ![]() ![]() Location: Muskego, WI | 60 Imp - 2013-01-19 8:48 AM Jboy, I occasionally wonder how you are going with this project. Looking awesome. More pic's appreciated Mate, I love the look of the 56 Imperials, especially the two door model. What have you done with the rear air evaporator? Sound insulation? Keen to know how you routed the refridgerant lines too. I plan to fit a vintage air rear unit to my 60. Steve. I haven't run the lines to the rear evaporator yet, but when I do I will take pictures. All insulation has been Dynamat and FatMat, I prefer the FatMat personally so that is what I've been going with. In other news, my entine interior is at Kasper Auto Interiors here in Tichigan, WI (Carl is 78 and still doing great interior work) along with 6 yards of custom red imperial eagle embroidered cloth. Should be done by early spring. | ||
| koopster |
Veteran Posts: 170 ![]() ![]() ![]() Location: central Massachusetts | Windsor59 - 2013-01-17 9:32 AM Have disassembled my AFB 2797S carburetors (1959) which I bought from Big M. As usual cutting brass screws in the throttle shafts or breaks. When you live in Sweden, it is not as easy to get hold of the screws in inch. Got hold of the right to end 6/32 in stainless, but the head of the screw a little too big. Cut them down to size yesterday. To fit the taper of the throttle shafts. Then cleaned everything before glass blasting and zinc plated in yellow and black.
Windsor59- one little trick is to take a piece of round stock and drill & tap the correct thread into the end of the round stock. thread a nut onto the screw/bolt, then tread the remainder of the bolt into the stock. Use the nut as a locking nut to prevent spinning. This way you can hold and twist the head of the screw against a grinding wheel, brillo or wire wheel, polishing head, etc without worry that the wheel will grab and rip the screw from the channel lock pliers! Nothing worse then hearing the one sole screw bouncing off the ceiling or into the netherworld of the unkept corner of your garage!!!! (note: this was from experience | ||
| 1961plymouthfury |
Expert Posts: 2682 ![]() ![]() ![]() ![]() ![]() ![]() Location: Rogersville, Alabama | Its under a car cover and in the garage. | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | koopster - 2013-02-23 6:41 PM Windsor59 - 2013-01-17 9:32 AM Have disassembled my AFB 2797S carburetors (1959) which I bought from Big M. As usual cutting brass screws in the throttle shafts or breaks. When you live in Sweden, it is not as easy to get hold of the screws in inch. Got hold of the right to end 6/32 in stainless, but the head of the screw a little too big. Cut them down to size yesterday. To fit the taper of the throttle shafts. Then cleaned everything before glass blasting and zinc plated in yellow and black.
Windsor59- one little trick is to take a piece of round stock and drill & tap the correct thread into the end of the round stock. thread a nut onto the screw/bolt, then tread the remainder of the bolt into the stock. Use the nut as a locking nut to prevent spinning. This way you can hold and twist the head of the screw against a grinding wheel, brillo or wire wheel, polishing head, etc without worry that the wheel will grab and rip the screw from the channel lock pliers! Nothing worse then hearing the one sole screw bouncing off the ceiling or into the netherworld of the unkept corner of your garage!!!! (note: this was from experience Thanks for the tip Speaking of flying, I would replace the one hood spring on Buick. Took using the pry bar which I dropped it and pry bar flew above my Windsorn and hit the wall behind. | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | This is how it's done safely Jocke. I did this neat trick when I installed a broken door spring without removing the door. You add washers until the spring can be pressed into place with the door/hood almost fully open - when you open the door/hood fully the washers will fall out. Edited by wizard 2013-02-25 1:43 PM (Resize of IMG_3598.jpg) (Resize of IMG_3599.jpg) (Resize of IMG_3602.jpg) (Resize of IMG_3603.jpg) Attachments ---------------- Resize of IMG_3598.jpg (48KB - 603 downloads) Resize of IMG_3599.jpg (34KB - 615 downloads) Resize of IMG_3602.jpg (49KB - 644 downloads) Resize of IMG_3603.jpg (36KB - 622 downloads) | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | OK Nice and it look easy (without removing the door) Edited by Windsor59 2013-02-25 1:54 PM | ||
