"Make-Up" your Car!
Jump to page : < 1 2 3 4 5 6 7 >
Now viewing page 4 [50 messages per page]
sermey
Posted 2012-07-23 11:19 AM (#331235 - in reply to #156081)
Subject: RE: "Make-Up" your Car!
Front Seats: The seat and the backrest cannot be adjusted. They have a fixed angle, as it was on all former American cars I owned. I found always the backrest a little bit too steep and uncomfortable (1). Thus, the first modification I used to do was to increase the angle between seat and backrest.
First remove backseat for easier handling. On the swivel seat, just rasp on each side near the both hinges, where the backrest is stopped, about 4.5mm deep (2). In back position the seat should fit on both sides (3). The angle then will increase from about 97deg to 103deg (90 + 13) (4).
Now, simply by a minor “surgical operation”, sitting in the car feels more relaxing and comfortable (5).  - SERGE -
To know: The 6-way seat adjuster tilts the entire seat.
Edited by sermey 2012-07-23 2:26 PM
(1 - Front backseat before modification.jpg)
(2 - Front backseat rasped 4.5mm.jpg)
(3 - Front backseat in new position .jpg)
(4 - Final backseat angle 103deg.jpg)
(5 - Both front backseats modified.jpg)
Attachments 1 - Front backseat before modification.jpg (121KB - 1043 downloads)
Attachments 2 - Front backseat rasped 4.5mm.jpg (93KB - 1078 downloads)
Attachments 3 - Front backseat in new position .jpg (92KB - 1064 downloads)
Attachments 4 - Final backseat angle 103deg.jpg (127KB - 1034 downloads)
Attachments 5 - Both front backseats modified.jpg (134KB - 1038 downloads)
sermey
Posted 2012-07-23 3:52 PM (#331283 - in reply to #216878)
Black Painted Items 2: The black color spray I used for my items (see: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=23691&...), my reserve has now exhaust and couldn’t get anymore. This was the best black spray I ever used. It needed many contacts with manufacturers and suppliers to find an equivalent. And now I have found the identical one, from another supplier, in a new wrapping. It has the same fast-drying solvent, as well exactly the same satin-matt tint. All my comparative tests showed identical results.
Here how they call it newly (marketing!): Rust Stop 4 in 1, Rust protecting paint, deep black, satin mat, RAL9005, and the products description, as printed:
Active rust protection by effective 4-in-1 high-solid coating system:
1. Primer. 2. Rust protection. 3. Colour. 4. Sealing. Fast-drying and high coverage. Excellent adhesion on nearly all surfaces, even directly on rust. Liquid corrosion inhibitor. Brand: Dupli-Color (868320). In Switzerland available in LANDI (03487).
(New Black Spray Satin.jpg)
Attachments New Black Spray Satin.jpg (130KB - 1073 downloads)
sermey
Posted 2012-07-26 7:24 AM (#331710 - in reply to #156081)
Dual Rear Antenna Connection: At the end of the fifties in cars mostly radios for long waves (LF: 148.5kHz – 283.5kHz, 2000m - 1058m) and medium waves (MF: 520kHz – 1620kHz, 576m -185m ), with a bandwidth of 9kHz have been usual. For these radios, the option of dual rear antennas have been offered (1). Later, with radios for very short waves (VHF: 1m – 10m, UHF: 10cm – 1m), the dual rear antennas disappeared, due to interference and as result fading. On FWL-cars the dual rear antennas have a distance of 154.5cm (to relate with the RF wave length). They are parallel-connected with a coupler. The original has wrapped antenna cable (2). The repro needs a plugged cable extension (3). The so coupled dual antennas then will work without problems when connected to an original MF-radio. For best reception, this radio should be optimized in sensitivity by adjusting the capacitor trimmer near the antenna input (4) (5).
To a modern radio only one of these antennas should be connected, the second antenna, as stated, to the original MF- radio, or when removed or not working, just left unconnected.
My car has two radio receivers: the original radio type 857, (MF range “5 – 16”) located in the center of the dashboard (6), the loudspeaker as well on top center dashboard (*). The other multi-band stereo receiver with musicassette player and remote controle is hidden in the glove box. (7), the 6 loudspeakers are on both front bottom sides and on the rear.
 Accordingly there are two separate antenna cables from the dual antennas, both along the right side under the sill plate to the radios. The rear left antenna leads to the original radio, the line here  is longer and less loss-sensitive at lower RF-signals, the rear right antenna goes to the modern radio needing a shorter cable, with low capacity as used today.
Now, both radios work independently, even simultaneously, without any interference and fading (8).  – SERGE –
(*) Details about the radio: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=23691&...
Edited by sermey 2012-07-26 7:58 AM
(1 - Set of Dual Rear Antennas NOS.jpg)
(2 - Original Dual Rear Antenna Coupler.jpg)
(3 - Repro Dual Rear Antenna Coupler.jpg)
(4 - Capacitor Trimmer - Inside View.jpg)
(5 - Hex Head Capacitor Trimmer - Outside View right side of radio.jpg)
(6 - Original 1959 DODGE Radio.jpg)
(7 - Multiband Musicassette Radio in Glovebox.jpg)
(8 - Two different Car-Radios.jpg)
Attachments 1 - Set of Dual Rear Antennas NOS.jpg (90KB - 1038 downloads)
Attachments 2 - Original Dual Rear Antenna Coupler.jpg (74KB - 1081 downloads)
Attachments 3 - Repro Dual Rear Antenna Coupler.jpg (59KB - 1097 downloads)
Attachments 4 - Capacitor Trimmer - Inside View.jpg (91KB - 1052 downloads)
Attachments 5 - Hex Head Capacitor Trimmer - Outside View right side of radio.jpg (80KB - 1104 downloads)
Attachments 6 - Original 1959 DODGE Radio.jpg (119KB - 1097 downloads)
Attachments 7 - Multiband Musicassette Radio in Glovebox.jpg (106KB - 1064 downloads)
Attachments 8 - Two different Car-Radios.jpg (92KB - 1040 downloads)
Posted 2012-07-26 4:24 PM (#331763 - in reply to #156081)
Subject: Re: "Make-Up" your Car!
50005000200010001002525
Again, thanks' Serge for good tips and tricks - I will copy the swivel seat backrest modification. You are totally right, the angle is too step OEM and full tilt does not give what a driver would like to have...
1959 Belvedere Conv
Posted 2012-07-26 11:42 PM (#331814 - in reply to #331763)
Serge, I agree with Sven (Wizard) that is a great fix on the seats for a more comfortable sitting position with that modification to the stop area. I know you changed the rear seats too for a better angle of comfort but I will keep that angle as factory.
I also need to reverse my Chrome seat hinge screws, I have the slotted end inside and the clear rivet part out. I thought it looked better that way.
The seat pivot works fine but small details like that do count.
Edited by 1959 Belvedere Conv 2012-07-26 11:43 PM
sermey
Posted 2012-07-27 2:57 AM (#331834 - in reply to #331235)
Front Seats 2: For those who want this modification to be reversible, here I did the seatback angle adjustable, to a fixed angle:
Cut on both sides of the lower seat hinge in the upper end a thread of M6 and insert a headless Allen screw of 10mm length (6).
Now the modified seatback angle (7) can be re-set to its original position (8) by compensating the rasped 4.5mm with the screw. Or you can adjust the angle to a minor amount to your best comfort (9).  - SERGE -
N.B. As I like my fixed setting, these pictures are real-view mounted for illustration on PS.
Edited by sermey 2012-07-27 3:10 AM
(6 - Headless Allen screw.jpg)
(7 - Max Seatback angle.jpg)
(8 - Reset Seatback angle.jpg)
(9 - Visible Adjustable Backseat.jpg)
Attachments 6 - Headless Allen screw.jpg (80KB - 1059 downloads)
Attachments 7 - Max Seatback angle.jpg (102KB - 1023 downloads)
Attachments 8 - Reset Seatback angle.jpg (90KB - 991 downloads)
Attachments 9 - Visible Adjustable Backseat.jpg (123KB - 1095 downloads)
FIN ME
Posted 2012-08-02 10:57 AM (#332872 - in reply to #156081)
2000500100100252525
Amazing stuff, Serge!
Thank you for posting all of this...you should write a book!
Great photos...please keep them coming!
sermey
Posted 2012-08-06 11:49 AM (#333469 - in reply to #332872)
FIN ME - 2012-08-02 4:57 PM Amazing stuff, Serge! Thank you for posting all of this...you should write a book! Great photos...please keep them coming! :)
Thanks for your kind comment, and to all the many people viewing this thread. Three hints to the photos: - 1. clean the item - 2. remove around all what not needed - 3. then at all if possible: NO flash to keep the deepness! - SERGE -
sermey
Posted 2012-08-06 11:54 AM (#333470 - in reply to #156081)
Fuel Alert Contact: In addition to: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=23691&posts=173&start=41
I sacrificed various samples of micro-switches because their body was not resistant to fuel (01). Then I applied a simple way to get a cursor controlled contact, to switch ON a LED before the fuel tank is empty.
I used a copper plated board (PCB) as used in electronics. Then separated the copper plating in two sectors by grinding, one side A soldering to the ground and fixing, the other side B leading to the LED by a separate (black) wire. The hand-made cursor is soldered to the turning axis of the variable resistor (02). It needs an additional pad, very well sealed to the fuel (3). Inside, the wire is soldered (4). Just before the fuel tank is empty, the cursor grounds the LED to switch it ON. The other pad of the LED is connected to +5V (regulator), over a resistor of 180 – 470Ohm to fix the brightness.
Now, when the LED goes on, I read the odometer and know exactly how far the remaining fuel will last, independent of the vague fuel gauge reading (05). For today cars nothing exceptional, but all the more on a fifties car.  – SERGE -
N.B. The elegant solution is using a differetial OPAMP, no extra wires, but same variable resistor. Finally I was restoring a car, not again designing an electronic device.
Edited by sermey 2012-08-07 1:48 AM
(01 - Micro-Switch.jpg)
(02 - Mopar Fuel Sending Unit.jpg)
(03 - View PCB and Cursor on Resistor Unit.jpg)
(04 - View Fuel Tank Unit Connections Side.jpg)
(05 - View Fuel Tank Unit Fuel Side .jpg)
(06 - LED Alert at Empty Fuel Tank.jpg)
Attachments 01 - Micro-Switch.jpg (100KB - 1073 downloads)
Attachments 02 - Mopar Fuel Sending Unit.jpg (67KB - 1062 downloads)
Attachments 03 - View PCB and Cursor on Resistor Unit.jpg (108KB - 1069 downloads)
Attachments 04 - View Fuel Tank Unit Connections Side.jpg (101KB - 1081 downloads)
Attachments 05 - View Fuel Tank Unit Fuel Side .jpg (99KB - 1012 downloads)
Attachments 06 - LED Alert at Empty Fuel Tank.jpg (130KB - 1045 downloads)
sermey
Posted 2012-08-07 9:15 AM (#333604 - in reply to #156081)
Wider tires: Modern wider tires transform a car visually to a more powerful vehicle. This is obvious when comparing two tire types next to each other on the similar FWL-Car: Original Dodge Diagonal Type, and replacement Radial Type (01). This and the much better stability on the street, mainly in curves and when braking, brought me to do this switch. First, shortly abstract considerations on dimensions:
_________________________________________________________________________________________
Diagonal Type 225/75/14”
DW = 355.6mm : [Diameter of Wheel (DW)14": 14 x 25.4mm= 355.6mm (1" = 25.4mm)]
HT = 168.75mm :[Height of the Tire (HT): 225mm x 75% = 168.75mm]
OD = 693.1mm : [Overall Diameter (OD): DW + (2 x HT) = 355.6mm + 337.5mm = 693.1mm (or 27.3")]
CC = 2176mm : [Circumference (CC): OD x 3.14 (pi) = 693.1mm x 3.14 = 2176.334 mm (or 85.7")]
Radial Type 235/70/15”
DW = 381mm : [Diameter of the Wheel (DW)15": DW = 15 x 25.4mm= 381mm]
HT = 164.5mm : [Height of the Tire (HT): HT = 235mm x 70% = 164.5mm]
OD = 710mm : [Overall Diameter (OD): OD = DW + (2 x HT) = 381mm + 329mm = 710mm (or 27.9")]
Overall Diameter measured OD = 708mm – I wonder how accurate (02).
CC = 2229.4mm : [Circumference (CC): CC = OD x 3.14 (pi) = 710mm x 3.14 = 2229.4 mm (or 87.7")]
____________________________________________________________________________________________
Differences and effects on car:
The Circumference CC (235/70/15") is 2.4% longer than the CC (225/70/14"). At same speedometer reading, now the car will run 2.4% faster. This difference is just tolerable without modifying the speedometer. Or otherwise: the speedometer will show 2.4% less at same speed. To calibrate the speedometer when needed, the return-spring in the speedometer should be lowered by lengthen, as calibrating mechanical watches.
The Overall Diameter OD (235/70/15") is 16.9mm bigger, thus the car will stay about this half amount higher. For the front this can be compensated by adjusting the torsion bars, and for the rear by setting down the high jackers.
The Wheel Distance with tires 8.00 x 14” is factory given by 60.9” (03) or 1546.8mm, on my car with the wider tires it is 1624mm, about 77mm more.
There is a noticeable difference in the Road Contact when measured: the Diagonal Type 125mm (04), and the Radial Type 175mm (05). This is 40% more! Highlighted the rear left tire on the street (06), or another front view (07).
Wider tires offer more security and power-feeling in one step. Just keep the original hubcaps on the car, and keep as well in reserve the original wheels. – SERGE –
P.S. (01) Partly Picture: Quentin Willson “Classic American Cars”
Edited by sermey 2012-08-07 9:37 AM
(01 - Comparison Front View.jpg)
(02 - Measured Radial Overall Diameter 708mm.jpg)
(03 - 1959 Dodge Promoted Tire 800 x 14in.jpg)
(04 - Measured Diagonal Road Contact 125mm.jpg)
(05 - Measured Radial Road Contact 175mm.jpg)
(06 - Rear View zoomed Left Radial Contact on Road.jpg)
(07 - Front View Radial Contact on Road.jpg)
Attachments 01 - Comparison Front View.jpg (160KB - 1063 downloads)
Attachments 02 - Measured Radial Overall Diameter 708mm.jpg (104KB - 1021 downloads)
Attachments 03 - 1959 Dodge Promoted Tire 800 x 14in.jpg (90KB - 1075 downloads)
Attachments 04 - Measured Diagonal Road Contact 125mm.jpg (130KB - 1048 downloads)
Attachments 05 - Measured Radial Road Contact 175mm.jpg (111KB - 1051 downloads)
Attachments 06 - Rear View zoomed Left Radial Contact on Road.jpg (114KB - 1056 downloads)
Attachments 07 - Front View Radial Contact on Road.jpg (118KB - 1038 downloads)
Leadfoot1000
Posted 2012-08-07 10:07 PM (#333728 - in reply to #156081)
10010025
Thanks for sharing all the great tips, I will apply many to my car (as soon as I get one). Your car is awesome!
Windsor59
Posted 2012-08-08 2:50 AM (#333746 - in reply to #333728)
2000500100
Hi sermey
Your are Good to ut better,
I dont like this, maby you can Do this better: Only one stop when you open the door
At fl Cars. I Will have two stop. Some times at parking you have not lots off space, and only can oppend
The door litle.
sermey
Posted 2012-08-08 2:50 AM (#333747 - in reply to #333728)
Leadfoot1000 - 2012-08-08 4:07 AM Thanks for sharing all the great tips, I will apply many to my car (as soon as I get one). Your car is awesome!
Thank you and as new member welcome on this site.
What you see here is mostly “cold coffee”, because the restoration was completed about 15 years ago. At this time I had no digital camera. Now, not so easy to comment and particular to show “before – after”. Sometimes I must use pictures of other cars as reference.  - SERGE -
Edited by sermey 2012-08-08 2:29 PM
sermey
Posted 2012-08-08 3:38 PM (#333803 - in reply to #333604)
Wide tires: Supplement
Edited by sermey 2012-08-08 3:40 PM
(Coker Tire Radial Cross Reference.jpg)
Attachments Coker Tire Radial Cross Reference.jpg (169KB - 1128 downloads)
sermey
Posted 2012-08-10 7:02 AM (#334028 - in reply to #333746)
Windsor59 - 2012-08-08 8:50 AM Hi sermey  Only one stop when you open the door At fl Cars. I Will have two stop.  . . .
A useful option that make sense. I will have a look at. - SERGE -
sermey
Posted 2012-08-14 8:04 PM (#334633 - in reply to #156081)
Filling Fine Scripts: For fine letters, standard paints will sometimes “over-layer” when filling. For this purpose, the thinnest paint I found was the Permanent Refill Ink (01), used for water resistant marker felt pens. It is very fast-drying and has a high coverage.
Apply with an ultra fine brush or needle (*), and when dried, remove the over-paint simply by rubbing with the finger or a school rubber. If too resistive use a fine cloth, moistened with solvent without pressing.
Now, the newly filled fine scripts have got a much higher contrast and thus become significantly better readable.  – SERGE -
(*) A felt pen is not suitable for a homogeneous coating on metal.
Edited by sermey 2012-08-14 8:30 PM
(01 - Refill Ink Permanent Marker.jpg)
(02 - Filling fine script MIRROR.jpg)
(03 - Filling fine script HOOD.jpg)
Attachments 01 - Refill Ink Permanent Marker.jpg (97KB - 1062 downloads)
Attachments 02 - Filling fine script MIRROR.jpg (108KB - 1026 downloads)
Attachments 03 - Filling fine script HOOD.jpg (61KB - 1096 downloads)
sermey
Posted 2012-09-01 3:42 AM (#337112 - in reply to #156081)
Leaking Valve Covers: At the first glance it seemed to be an easy thing to mount the valve covers without any leaking  .  .  .  .  .  but finally I got it.
First all contact surfaces of the valve cover have to be properly mated all around. Often, around the bolt  holes the cover is deformed due to a previous too strong tightening.
For a sure sealing, Silicon Gasket (as already presented earlier) is applied just on the inner edges of the valve cover (1). Remember: this is not glue for fixing and will not harden. It remains soft (20 shore) and allows an easy removal of the cover. Any other similar Silicon can be used, but it must be resistant to temperatures in the range of -40 to +180deg. Before tightening, when visible the gasket then can be pushed under the cover (2).
To avoid local high pressing and a deformation around the head of the bolt, special hold-down brackets are being used. These give two additional extended hold-down points (3). The big washer improves the local stability around the bolt holes, shorten virtually the bolt for the cap nut and hide the eccentric bore.
Polished stainless cap nuts (4) underline the overall harmonic style of the engine compartment (5).  - SERGE -
Edited by sermey 2012-09-01 3:03 PM
(1 - Automotive Gasket.jpg)
(2 - Aligned Valve Cover.jpg)
(3 - Valve Cover Hold-Down Bracket.jpg)
(4 - Fixed Valve Cover.jpg)
(5 - Valve Cover Top View.jpg)
Attachments 1 - Automotive Gasket.jpg (72KB - 1108 downloads)
Attachments 2 - Aligned Valve Cover.jpg (93KB - 1066 downloads)
Attachments 3 - Valve Cover Hold-Down Bracket.jpg (120KB - 1046 downloads)
Attachments 4 - Fixed Valve Cover.jpg (117KB - 1035 downloads)
Attachments 5 - Valve Cover Top View.jpg (136KB - 1024 downloads)
sermey
Posted 2012-09-01 1:27 PM (#337134 - in reply to #156081)
Carpets and Floor Mats 1: With my 1959 Dodge Convertible I got white Knight Rubber Mats I never saw elsewhere. I found these exceptional and thus present them here. The Side Emblem ot the front mat seems to be equal to the Center Emblem.
Since restored, I used other Carpets and Floor Mats in my car, and will thread them in a next part to come.  - SERGE -
Edited by sermey 2012-09-02 4:27 AM
(01 - 1959 Knight Rubber Mats Front - Rear.jpg)
(02 - Knight Mat - Front Center Emblem.jpg)
(03 - Knight Mat - Rear Center Emblem.jpg)
(04 - Knight Mat - Rear Side Emblem.jpg)
Attachments 01 - 1959 Knight Rubber Mats Front - Rear.jpg (150KB - 1133 downloads)
Attachments 02 - Knight Mat - Front Center Emblem.jpg (122KB - 1012 downloads)
Attachments 03 - Knight Mat - Rear Center Emblem.jpg (94KB - 1014 downloads)
Attachments 04 - Knight Mat - Rear Side Emblem.jpg (99KB - 1013 downloads)
sermey
Posted 2012-09-04 8:31 AM (#337454 - in reply to #337134)
Carpets and Floor Mats 2: On the market a wide range of said "Original Floor Mats" are offered. There are very nice ones and available at a reasonable price. Others, described as “original” size doesn’t fit at all.
I set my personal standards on quality, material, color and finish, mainly based on practical considerations. Furthermore, on a Convertible some specs on carpets have higher weighting, being more exposed than on a Sedan.
Here my arguments:
1. The quality. There are two basic carpet versions being used: the "loop pile" and the "cut pile" (05). Practical arguments brought me to use exclusively "cut pile" carpet.(06):
Cleaning a carpet from any dirt, the "loop pile" prevents to remove it, the dirt will even enter more in the carpet. Furthermore, hanging on a loop, the carpet may be damaged all along a line.
Other the "cut pile": when brushing, the slanted pile supports to take out the dirt easily. It is invisible, when added two parts together, or when inserted a round stamped sample in damaged spots.
Walking on a good quality cut pile floor is noticeable much more comfortable, and it has a better absorbance of sound and noise.
2. The material. In a car, exposed to humidity and oil, a full synthetic material is a must. It doesn't rot, thus offer a longer lifetime, and is much more resistive to aggressive cleanser.
3. The color. It should match to the interior of the car, preferably unicolored not visually interfering to other items. Unicolor generally looks more precious, is calmative, but as well more delicate when not clean.
4. The finish: Solid and wear resistant base enabling to glue when needed, no under foam-coating, all around bordered to prevent fringing.
On my Convertible, at the time not finding floor insertions or original mats, all was custom made with loop pile carpets, black synthetic, solid tissue base and vinyl-bordered all around (07) (08).
Instead of bordering, on straight edging a plastic profiles as used to fix papers can be applied as protection (09). The same profile I used inside of my door sills (see: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=23691&posts=184&start=13). If needed for attaching, rubber or plastic items can be inserted as shown (10).
(will be continued)
(05 - Basics Loop Pile - Cut Pile.jpg)
(06 - Carpets Loop Pile - Cut Pile.jpg)
(07 - Carpets Loop Pile - Cut Pile Upper Side bordered.jpg)
(08 - Carpets Loop Pile - Cut Pile Under Side bordered.jpg)
(09 - Alternative bordering with a Profile.jpg)
(10 - Rubber for attaching.jpg)
Attachments 05 - Basics Loop Pile - Cut Pile.jpg (96KB - 1056 downloads)
Attachments 06 - Carpets Loop Pile - Cut Pile.jpg (154KB - 1043 downloads)
Attachments 07 - Carpets Loop Pile - Cut Pile Upper Side bordered.jpg (130KB - 1057 downloads)
Attachments 08 - Carpets Loop Pile - Cut Pile Under Side bordered.jpg (132KB - 1051 downloads)
Attachments 09 - Alternative bordering with a Profile.jpg (109KB - 1054 downloads)
Attachments 10 - Rubber for attaching.jpg (109KB - 1078 downloads)
mogge65
Posted 2012-09-04 9:22 PM (#337545 - in reply to #156081)
1000100100252525
This thread is really outstanding, just love to read an see what he´s up to! Sermey "The Magic Man"
Leadfoot1000
Posted 2012-09-08 1:01 AM (#337959 - in reply to #161298)
10010025
sermey - 2009-02-01 4:44 AM
15” Wheels and Tires: I always found, 14” Wheels on my Car are relatively too small and look poor in Proportion to the Body and its Wheelhouse. Must say, this was the Style at this time.
The other Point, bigger and wider Tires have much better Adhesion on the Street, the 235/70/15 Radial Tires about +25% in Comparison to the Original 14” Diagonal ones. This improvement is necessarily needed for a full Advantage of Disk Brakes. Thus, I decided in favor of 15” Wheels and the corresponding WWW Tires, still keeping the Original 14” Wheel Set including the Spinner Hubcaps. In order to keep the Original Appearance, the Original HubCaps should fit to the 15” Rims.
I bought 15” decorative stainless Rings, cut out the Border around, and soldered it inside the Wheel Cover. For a stronger Fixing on the rechromed Wheels I increased the Clamp Pression by putting a soft round PVC Profile under the Clamps.
Now, the Hubcaps fit perfectly to the 15” Rims, their Edges are even protected from Curbstones due to the inner Position, and the Air Valve is perfectly centered as well. According my personal feeling, this Wheel Size gives the Car its settled Proportions. Another improvement of the Outfit, for the Drivers Security, and as an additional Benefit the Wheel Cover Edge Protection.
(can see, my HubCaps are not perfect, but polished and with the sticked Black they look as)
Hi Sermey, I plan to get 235-70/15's for my car also. Can you please tell me what's the width of the white walls on your tires? Your choice of white walls provides the same look I'm trying to achieve. By the way, I bought a car a few weeks ago if you want to see it under Member's Rides title "My 57 New Yorker." Steve
sermey
Posted 2012-09-08 7:16 AM (#337971 - in reply to #337959)
Leadfoot1000 - 2012-09-08 7:01 AM
sermey - 2009-02-01 4:44 AM . . . .  what's the width of the white walls on your tires?  Steve
Measured on the car:   70.5mm = 2.775"
According the Manufacturer Coker Tire:   Radial P235/70R15, WW 2n3/4 (see attached Specs 2012)    - SERGE -
Edited by sermey 2012-09-08 7:25 AM
(1959 DODGE Custom Royal Lancer Convertible 2012.jpg)
Attachments 1959 DODGE Custom Royal Lancer Convertible 2012.jpg (231KB - 1042 downloads)
Attachments 1959 DODGE Custom Royal Lancer Convertible 2012.pdf (148KB - 1285 downloads)
sermey
Posted 2012-09-08 12:13 PM (#338017 - in reply to #156081)
Fan Shroud: My car didn’t had a Fan Shroud (01). On a car meeting I purchased a Chrome Metal Fan Shroud, thinking this would give the engine compartment a more valuated look, will prevent parts or screws falling on the propeller when working at idling, and as protection from casually touch inside. (old Pic 02). So far so good.
In hot summer, at longer stops and idling I encountered critical heating situations, the engine room got quite hot. I was reflecting: without a shroud, the fan blows not only axial, but as well partially radial as a centrifugal fan. My Metal Shroud, covering only 65% of the propeller, now caused in idle more air to be centrifuged downward instead towards the engine. -> Just check it!
I took a high temperature Heat Protective Mat (03), put this over a panel to seal airtight underneath the fan and front (04). As result, the heating was noticeable reduced. Then I purchased two Chrome Metal Shrouds, the longest available (170mm), one for the upper, the other one for the lower side of the fan. They had to be exactly marked for a partly cut-out to fit all around (05). Needed cut-outs for: the water hose (06), the generator belt (07), the steering pump, the transmission oil lines (08), and a bending on the fuel pump side (09). All these cuts were previously simulated with a cardboard sample. Then the prepared two halves (to see lower Shroud) (10) (11) could be mounted very easy, without disassembling anything, and fixed with long bolts through the radiator.
The distance of the shroud to the propeller, here should be taken in consideration the movement of the engine on bad streets. The short Metal Shroud was initially mounted too near, as signs of contacts can be seen on the comparison (12).
Now this Chrome Metal Shroud makes multiple sense: protection, outfit and an improved cooling at longer stop (13).   - SERGE -
Comment: If you find a standard shroud fitting the radiator you will save some handiwork, but will have to disassemble some items!
Edited by sermey 2012-09-08 12:35 PM
(01 - Unprotected Fan - Water Hose Removed.jpg)
(02 - Short Metal Shroud Mounted.jpg)
(03 - Heat Protective Mat.jpg)
(04 - Protective Heat Protective Mat under Fan.jpg)
(05 - Metal Shroud Ready for Cut.jpg)
(06 - Cut-Out for Water Hose.jpg)
(07 - Cut-Out for Generator Belt.jpg)
(08 - Bottom View Trans Line.jpg)
(09 - Bent for under Trans Lines.jpg)
(10 - Lower Metal Shroud Cut - Outside View.jpg)
(11 - Lower Metal Shroud Cut - Inside View.jpg)
(12 - Short and Long Metal Shroud - Cut.jpg)
(13 - Chrome Metal Shroud 170mm - Top View.jpg)
Attachments 01 - Unprotected Fan - Water Hose Removed.jpg (153KB - 1035 downloads)
Attachments 02 - Short Metal Shroud Mounted.jpg (137KB - 1045 downloads)
Attachments 03 - Heat Protective Mat.jpg (116KB - 1028 downloads)
Attachments 04 - Protective Heat Protective Mat under Fan.jpg (100KB - 1063 downloads)
Attachments 05 - Metal Shroud Ready for Cut.jpg (94KB - 1012 downloads)
Attachments 06 - Cut-Out for Water Hose.jpg (112KB - 1027 downloads)
Attachments 07 - Cut-Out for Generator Belt.jpg (82KB - 1039 downloads)
Attachments 08 - Bottom View Trans Line.jpg (138KB - 1002 downloads)
Attachments 09 - Bent for under Trans Lines.jpg (114KB - 1028 downloads)
Attachments 10 - Lower Metal Shroud Cut - Outside View.jpg (108KB - 1064 downloads)
Attachments 11 - Lower Metal Shroud Cut - Inside View.jpg (114KB - 1050 downloads)
Attachments 12 - Short and Long Metal Shroud - Cut.jpg (101KB - 1048 downloads)
Attachments 13 - Chrome Metal Shroud 170mm - Top View.jpg (133KB - 1034 downloads)
sermey
Posted 2012-09-09 10:58 AM (#338129 - in reply to #156081)
Trunk Edge: The lower trunk edge is most exposed to damage when loading items not carefully. The paint is most badly affected. In addition, this edge is even not exactly straight.
A profile in plastic or rubber, preferably in the cars color, could eliminate this situation. I found a plastic channel used in electric installations, in white as the car (1). The cover fits to the trunk edge as required (2). The trunk seal keep it in the right position (3) ( ! the carpet is black and ends up with the profile). Some rubber profiles or a small slotted hose would work as well.
Now, the trunk edge is protected, straight, no color damages anymore, all as it should always be (4).  – SERGE -
(1 - White Profile.jpg)
(2 - Applied White Protective Profile.jpg)
(3 - Protective Profile fixed behind Trunk Seal.jpg)
(4 - Protected Trunk Edge - Top View.jpg)
Attachments 1 - White Profile.jpg (68KB - 1063 downloads)
Attachments 2 - Applied White Protective Profile.jpg (139KB - 1066 downloads)
Attachments 3 - Protective Profile fixed behind Trunk Seal.jpg (119KB - 1061 downloads)
Attachments 4 - Protected Trunk Edge - Top View.jpg (98KB - 1039 downloads)
sermey
Posted 2014-05-11 8:03 AM (#440274 - in reply to #156081)
Emblem on Ash Tray: As already shown earlier in this thread, I had fixed the small Knight Head (01) on the ash tray. It is the same as already on the steering wheel. Looking a little bit “lost”, I replaced it now by the more sophisticated emblem
used on the Glove Box of the 1959 Coronet (02-03). If nicer to put there an emblem, particulary this new one depends on each personal taste (04-05).
Anyway, as lover of emblems I like it. Another eye-catcher!   - SERGE -   :laugh:
Edited by sermey 2014-05-11 8:15 AM
(01 Small Knight Head 25.jpg)
(02 1959 Glove Box Medaillon NOS 25.jpg)
(03 1959 Glove Box Medaillon NOS Solo 25.jpg)
(04 Ash Tray Solo 25.jpg)
(05 Ash Tray Front View 25.jpg)
Attachments 01 Small Knight Head 25.jpg (63KB - 972 downloads)
Attachments 02 1959 Glove Box Medaillon NOS 25.jpg (95KB - 952 downloads)
Attachments 03 1959 Glove Box Medaillon NOS Solo 25.jpg (63KB - 973 downloads)
Attachments 04 Ash Tray Solo 25.jpg (88KB - 959 downloads)
Attachments 05 Ash Tray Front View 25.jpg (119KB - 981 downloads)
sermey
Posted 2014-05-16 12:28 PM (#441072 - in reply to #156081)
Bright Back Light: When replacing the bulbs by LEDs for backlight, there are various LED lamps available that fit to the socket 1156 BA (01). Here not shown all. The standard replacement LEDs shines more white then brighter. One solution for a brighter light is to use Super Bright LEDs, as the power dissipation and therefore the heating effect remains small. A next step brighter is to use instead of the 1156 BA single lamp the High Power 1157 BA dual Lamp (Turn Signal / Brake), when bridging the two connectors, and adapting one fixing pin to fit to the single contact socket (02). The difference between standard bulb and Power LED manifests in color and an impressive brightness (03).
Now, turning backwards at night, the street is sufficient illuminated, in respect to ground and in distance (04). – SERGE -
Edited by sermey 2014-05-16 12:34 PM
(01 Various LEDs BS1156 -25.jpg)
(02 Sockets BS1156 - BS1157 bridged -25 .jpg)
(03 Comparison Bulb - LED -25.jpg)
(04 Super Bright Back Light - 25.jpg)
Attachments 01 Various LEDs BS1156 -25.jpg (47KB - 989 downloads)
Attachments 02 Sockets BS1156 - BS1157 bridged -25 .jpg (68KB - 973 downloads)
Attachments 03 Comparison Bulb - LED -25.jpg (73KB - 947 downloads)
Attachments 04 Super Bright Back Light - 25.jpg (80KB - 984 downloads)
Posted 2014-05-16 2:25 PM (#441084 - in reply to #156081)
Nice idea Serge, thanks' for sharing!
sermey
Posted 2014-05-23 3:44 PM (#442055 - in reply to #156081)
The Last Emblem: Many years ago I found a nice ForwardLook Emblem with a Dodge Script. Because I liked I purchased, even I had never seen this one on a 1959 Dodge. It got a nice place under the left Front Seat (01). Since then I was looking for a similar Emblem for the right side, but without the Dodge Script - a ForwardLook Emblem should never be mounted Backward.
Now I found what I was looking for a long time (02). It has got his reserved place, looking happily forward as his brother on the left side (03). Another hidden eye-catcher (04).
Was this the last emblem to be mounted on my 1959 Dodge Convertible?  - SERGE -
(01 FWL Emblem LH -25.jpg)
(02 FWL Emblem Solo-25.jpg)
(03 Emblem RH -25.jpg)
(04 FWL Emblem View RH -25 .jpg)
Attachments 01 FWL Emblem LH -25.jpg (128KB - 944 downloads)
Attachments 02 FWL Emblem Solo-25.jpg (61KB - 970 downloads)
Attachments 03 Emblem RH -25.jpg (118KB - 933 downloads)
Attachments 04 FWL Emblem View RH -25 .jpg (118KB - 955 downloads)
Posted 2014-05-27 4:22 PM (#442514 - in reply to #156081)
That looks really like a nice emblem Serge - fact I don't recall ever seeing such a nicely shaped one?! Is there a story behind??
FIN ME
Posted 2014-06-08 7:53 AM (#444193 - in reply to #156081)
2000500100100252525
Looks great, Serge!
Love your work. You are part mechanic, part artist!
Astounding attention to detail!
sermey
Posted 2015-04-06 1:27 PM (#474519 - in reply to #156081)
Flashing LEDs: Brighter light on directional and rear lamps can be achieved when using LEDs of the new generation (01). They about 10% current consumption then standard bulbs. With this low current the common thermostatic operated flasher (02) will not work anymore. Load resistors of about 6 Ohm/20Watt (03) are offered to connect in parallel to each replaced bulb. To keep it low-cost, one resistor can be connected directly at the output of the flasher and will then be parallel to any LEDs in flashing mode. With the load resistor the additional “advantage” of a lower current consumption is lost, but it works.
Using an electronic controlled flasher (astable multivibrator) with relais (04), the flash frequency will be independent of the loading. It is defined by the time-constant, and can be modified by the value of a capacitor or resistor (05).
Simpler is to use an adjustable electronic flasher (06), The pin configuration enables to replace directly the standard flasher. It needs an additional lead to ground. Now the flashing frequency can be modified manually in a wide range by turning the axis of the potentiometer, and independent of load and voltage it remains stable.
The simplest and lowest cost solution at all is to keep all the bulbs connected, but outside the housing (in a thermo- protected and dimmed space), and insert the LED lamps in parallel. The total current will increase about 10% and as well the flashing frequency.
The result with Power LEDs is a Super Bright Rear Light, when flashing and at stop. With the camera the brightest red becomes yellow (07)!
To get a warmer and homogenous white light I covered the front LEDs with a Dessert Cap  (08), only possible because the LED doesn’t heat.
With parking LEDs ON, now the car can keep the battery charge up to one week, at super bright light!  - SERGE -  :laugh:
(01 Power LEDs Red-White Cree.jpg)
(02 Thermostatic Flasher.jpg)
(03 Load Resistors.jpg)
(04 Electronic Flasher.jpg)
(05 Printed Circuit Board.jpg)
(06 Adjustable Electronic Flasher.jpg)
(07 Super Bright Red Light.jpg)
(08 Dessert Cap.jpg)
(09 Damped LED Park Light.jpg)
Attachments 01 Power LEDs Red-White Cree.jpg (74KB - 925 downloads)
Attachments 02 Thermostatic Flasher.jpg (93KB - 906 downloads)
Attachments 03 Load Resistors.jpg (76KB - 916 downloads)
Attachments 04 Electronic Flasher.jpg (72KB - 902 downloads)
Attachments 05 Printed Circuit Board.jpg (93KB - 890 downloads)
Attachments 06 Adjustable Electronic Flasher.jpg (93KB - 940 downloads)
Attachments 07 Super Bright Red Light.jpg (96KB - 926 downloads)
Attachments 08 Dessert Cap.jpg (51KB - 904 downloads)
Attachments 09 Damped LED Park Light.jpg (80KB - 939 downloads)
ttotired
Posted 2015-04-06 6:42 PM (#474543 - in reply to #156081)
5000200010001001001001002525
Very good
Always enjoy reading this thread (been a long time since something new)
I will add though that those "scotch locks" (red wire taps) belong in the bin, nothing but electrical gremlin makers especially on anything that draws a current
sermey
Posted 2015-04-07 11:43 AM (#474633 - in reply to #156081)
Dash Pad 1: When I got my Dodge, the dash pad was hard, dried and partly broken. There was no other way then to remove it (01). After cleaning the surface I used the same black vinyl to coat it as for the door panels (02). Applying on both sides enough Contact Glue, as for the arm rests (see earlier post), the coating got softer, could then be stretched and pulled around the edges. Fixed with masking tape I had to wait one week. The instruments metallic insert (03) then mounted over when black painted. The right side rounding was simulated by a coated metal (04).The result was impressive, as shown in 06 – 08. There was just one negative aspect: the surface was not padded and there were no ribbers.
Looking at the old brochure the ribbing is also missing (09), but I think this was a preliminary draft. The illustration in the parts book, the dash pad shows ribbes (10 black), as can be seen on cars with the original pad (11 blue, for Ron).
Today the Swedish company RD Autoline (Tony) reproduces this one and many other dash pads in a stunning originality and at high quality standard. What I saw in documentations is a high skilled artwork.
I ordered one for my 1959 Dodge Convertible and will later report the proceeding in mounting it, in: Dash Pad 2.  - SERGE -
(01 Remove Old Dash Board.jpg)
(02 Black Vinyl Coating.jpg)
(03 Instruments Metallic Insert.jpg)
(04 Vinyl Coated Dash Right Side.jpg)
(05 Vinyl Coated Dash Center.jpg)
(06 Vinyl Coated Dash Left Side.jpg)
(07 Vinyl Coated Dash Board Overview.jpg)
(08 Dash Pad Old Brochure.jpg)
(09 Dash Pad Partsbook Black.jpg)
(10 Dash Pad Partsbook Blue.jpg)
Attachments 01 Remove Old Dash Board.jpg (91KB - 907 downloads)
Attachments 02 Black Vinyl Coating.jpg (112KB - 925 downloads)
Attachments 03 Instruments Metallic Insert.jpg (97KB - 892 downloads)
Attachments 04 Vinyl Coated Dash Right Side.jpg (96KB - 939 downloads)
Attachments 05 Vinyl Coated Dash Center.jpg (134KB - 963 downloads)
Attachments 06 Vinyl Coated Dash Left Side.jpg (124KB - 882 downloads)
Attachments 07 Vinyl Coated Dash Board Overview.jpg (112KB - 908 downloads)
Attachments 08 Dash Pad Old Brochure.jpg (79KB - 907 downloads)
Attachments 09 Dash Pad Partsbook Black.jpg (53KB - 927 downloads)
Attachments 10 Dash Pad Partsbook Blue.jpg (93KB - 873 downloads)
sermey
Posted 2015-04-08 11:49 AM (#474748 - in reply to #156081)
Weak Hood Spring: When I got my Dodge, the hood had to be kept up with a wooden bar because of weakened springs. Thus I had first to reproduce stronger springs, and found a manufacturer. For an incredible price of CHF 80.00 he produced for me (1994), according the sample I sent him, 3 different pairs of springs, so I could test them on the car (01) and make the choice. What you see are the remaining 2 new pairs.
I kept the pair of spring that just hold up the hood and painted them in white as the car (02). Since then the hood is up as it should. - SERGE –
Edited by sermey 2015-04-08 12:05 PM
(01 Old-New Repro Hood Spring.jpg)
(02 Mounted New Hood Spring.jpg)
Attachments 01 Old-New Repro Hood Spring.jpg (132KB - 902 downloads)
Attachments 02 Mounted New Hood Spring.jpg (77KB - 976 downloads)
di_ch_NY56
Posted 2015-04-08 1:49 PM (#474762 - in reply to #156081)
100050025
Hi Serge
With a big interest I'm following your thred. You're like a Wizard here in Switzerland. Thank you very much for all your helpful hints. I'm sure I could use some of your hints for my Letter after it comes back from the body shop. I'm happy I could meet you at Zug on April 20th this year and we'll do the journey to the PBM together. Big hugs.
Till later, take care,
Dieter
Posted 2015-04-08 2:27 PM (#474767 - in reply to #156081)
hoodinki - 2015-04-08 12:13 PM
We all got that stick, I prefer the unscrewable wooden type on push brooms. I remember needing these, and a wheel chuck to keep in the trunk for parking on hills if you had a Powerflite, back in the 1970s for my Plymouth. Not really MBZ engineering going on back then. No wonder Plymouth is now Dead,.
wtf?! in 100 000s of miles driving my plymouth or other fls i never had the slightest problems with hood springs or the very efficient parking brakes. they lock the tires anytime and on the steepest hills. don't blame these fine cars for poor maintenance. these cars are build for the eternity IF properly serviced.
sermey
Posted 2015-04-19 4:42 AM (#475941 - in reply to #156081)
Front Light Connections: All wires of the front lights lead to a Terminal Block located in front of the battery (01).
This Terminal Block has 5 connectors (1 – 5 from left to right). For a nicer appearance, it is fixed with polished stainless pan-head screws (M5), the connector bolts are covered with cap nuts, and the leading wires are hold in black (02).
The schematic diagram can be found in the Service Manual DODGE 59 Supplement, here a part restricted to the front lights (03). The connections on my car are originally slightly different then shown in the manual (04). They could not be interchanged because of the exact length of the wires.
There is a nice repro of the terminal connector available, at a reasonable price (05). The connections of the terminal block I added as well in PDF.  - SERGE -
(01 Terminal Location.jpg)
(02 Terminal Block.jpg)
(03 Front Light Schematic.jpg)
(04 Connections Terminal Block.jpg)
(05 Connector Repro.jpg)
Attachments 01 Terminal Location.jpg (118KB - 1067 downloads)
Attachments 02 Terminal Block.jpg (118KB - 1064 downloads)
Attachments 03 Front Light Schematic.jpg (91KB - 1007 downloads)
Attachments 04 Connections Terminal Block.jpg (77KB - 1029 downloads)
Attachments 05 Connector Repro.jpg (101KB - 1015 downloads)
Attachments 06 Connections Terminal Block.pdf (6KB - 1027 downloads)
Posted 2015-04-19 11:22 AM (#475968 - in reply to #475941)
50005000100
outstanding, Serge - I always enjoy reading this thread. Your attention to detail and inventiveness is remarkable.
Posted 2015-04-19 1:09 PM (#475981 - in reply to #156081)
Always interesting to read Serges posts - careful work to enhance the car
sermey
Posted 2015-04-24 3:00 AM (#476474 - in reply to #156081)
Push Buttons: When restoring the Push Buttons a time ago, I had to remove the old paint in the letters. All chemical way where to aggressive, I used a soft diluent to be cleaned with water. But this plastic is so “weak”, that not only the paint was removed, but as well the front was badly affected. I had to grind it down and then use letter sticker (01), protected by a transparent foil (02).
Most Push Buttons are irreparably damaged by Finger Nails. It is very rare to find one with intact letters (03). Finally I found now a set in acceptable condition (04).
This time I didn’t use any chemistry at all (05), cleaned them with a soft brass brush (06), and got them all quite nice (07). The paint for the letters (red as used for the Instuments) I applied locally with a needle, removed instantly the color around with a rubber scraper, and when dried grinded the front (08). To fix and center the caps I put some tape around (white), inserted again a protective transparent foil, and for a soft return I added an O-Ring over the cap (09).
Now the Push Buttons look again as they should and are protected from Finger Nails: Clear letters and nice to look at.  - SERGE -
Edited by sermey 2015-04-24 3:12 AM
(01 Push Buttons restored.jpg)
(02 Sticked Letters.jpg)
(03 Push Buttons Ross Roy.jpg)
(04 Used Push Button.jpg)
(05 Push Button Unrestored.jpg)
(06 Brush-up Push Buttons.jpg)
(07 Push Buttons AC brushed.jpg)
(08 Grinding Front Rounded.jpg)
(09 Push Button Assembly.jpg)
(10 Push Button Unit Mounted.jpg)
Attachments 01 Push Buttons restored.jpg (104KB - 1052 downloads)
Attachments 02 Sticked Letters.jpg (80KB - 1136 downloads)
Attachments 03 Push Buttons Ross Roy.jpg (117KB - 1035 downloads)
Attachments 04 Used Push Button.jpg (113KB - 1101 downloads)
Attachments 05 Push Button Unrestored.jpg (60KB - 1077 downloads)
Attachments 06 Brush-up Push Buttons.jpg (80KB - 1077 downloads)
Attachments 07 Push Buttons AC brushed.jpg (58KB - 1045 downloads)
Attachments 08 Grinding Front Rounded.jpg (90KB - 1026 downloads)
Attachments 09 Push Button Assembly.jpg (77KB - 1090 downloads)
Attachments 10 Push Button Unit Mounted.jpg (115KB - 1086 downloads)
Posted 2015-04-24 3:18 AM (#476476 - in reply to #156081)
Lot of patience and love for the work at hand - those pushbuttons could'nt be any better.
sermey
Posted 2015-04-29 9:13 AM (#476922 - in reply to #156081)
Six-Way Seat Adjuster Switch: By a single bar of the switch, all six positions of the seat can be adjusted (01).
Forward -  Backward (5 inches)      Higher -  Lower (2 inches)      Tilt CW -  CCW (18 degrees) (02).
As the initial current of the seat adjustment is quite high, the contacts should be checked from time to time (03) (04).  The color of the wires must be correct, the switch is folded down for rear view (05).
Later I found another switch as spare part, mounted on a chrome bezel, as illustrated in the owners manual (06). This bezel should be on front side of the seat. To keep the nice golden emblem I put it reversed on the rear side - and it fits as it should be. The top view shows the mounting bracket and the power seat motor (07). The red main wire is connected after the circuit breaker located on the top lift switch, this as well the power windows. The chrome bezel is mounted with the two existing screws of the switch, thus easy to remove if one day dislike.
But for now, a bit more chrome on my Convertible! (08) – SERGE -
Edited by sermey 2015-04-29 9:26 AM
(01 Six-Way Power Switch.jpg)
(02 Six-Way Seat Adjustments.jpg)
(03 Contact Elements.jpg)
(04 Power Switch Components.jpg)
(05 Connections Rear View.jpg)
(06 Six-Way Power Switch Owners Manual 25 .jpg)
(07 Top View with Power Seat Motor.jpg)
(08 Power Switch with Chrome Bezel.jpg)
Attachments 01 Six-Way Power Switch.jpg (103KB - 1026 downloads)
Attachments 02 Six-Way Seat Adjustments.jpg (92KB - 1062 downloads)
Attachments 03 Contact Elements.jpg (67KB - 1040 downloads)
Attachments 04 Power Switch Components.jpg (82KB - 1067 downloads)
Attachments 05 Connections Rear View.jpg (102KB - 1046 downloads)
Attachments 06 Six-Way Power Switch Owners Manual 25 .jpg (121KB - 1039 downloads)
Attachments 07 Top View with Power Seat Motor.jpg (110KB - 1037 downloads)
Attachments 08 Power Switch with Chrome Bezel.jpg (116KB - 1034 downloads)
di_ch_NY56
Posted 2015-04-29 10:24 AM (#476931 - in reply to #156081)
100050025
Thank you very much Serge for this information. In my Letter I got a six way electric adjustable drivers seat as well. The switch looks different on a 1960 Mopar, but I assume the basic function is the same - one motor, three clutches.
Happy Motoring!
Dieter
1961plymouthfury
Posted 2015-04-29 11:54 AM (#476935 - in reply to #476931)
2000500100252525
Thank You for the 411
sermey
Posted 2015-05-03 8:34 PM (#477275 - in reply to #156081)
Dome Lamp: With time the plastic lens goes brown and burns out in the center, due to excessive heat by the bulb. This is already observable in the original brochure of the 1959 Dodge Convertible, burned lens zoomed right down (01). As these lenses are highly demanded, reproductions are available up to USD 80 a pair (02). A single NOS Dome Lamp Lens Imperial with crown insigna is offered for USD155 (03).
To replace the lens, the fixing pins on the rear shell have to be bent out with the result that they mostly break off. Therefore break out one of the three pins for the lens can be removed, replace it by a soldered one, and grind a slot in the metal retainer. Now it can be fixed or removed anytime just by twisting (04).
To avoid a newly deformation of the replaced lens by heat a LED, no longer then 35mm, is advised in replacement of the bulb (05). This special bulb has two terminals, plus and minus, the socket is isolated, means not grounded. One pin is connected to plus, the other pin to minus when the door switch is activated. As I could not find such a LED I had to do some “surgical” interventions:
- Unsolder the two contacts and the four fixing points of the socket for removal (06).
- Socket removed (07).
As shown, one contact leads direct to the LED unit for a bright light, the other contact to the same point but over a resistor of 15 Ohm for a lower light. The ground (-) goes to the socket, as expected (07).
- Connect the resistor to minus (for lower light), and cut out the cupper of the printed circuit board in order to disconnect the ground (08).
- Resolder the socket on the LED unit as it was previously. The LED has become a direct replacement of the original bulb (09).
Now the dome lamp shows a brighter white light, without any burning of the plastic lens (10). - SERGE -
P.S. Numbering of the pictures corrected.
Edited by sermey 2015-05-03 9:08 PM
(01 Brochure Dome Lamp.jpg)
(02 NOS Dome Lamp Lense.jpg)
(03 NOS Dome Lamp Lense Imperial.jpg)
(04 Twist Rear Shell for Removal.jpg)
(05 Comparison LED - Bulb.jpg)
(06 Socket Removal.jpg)
(07 Socket Removed.jpg)
(08 Resistor on Minus and Ground Cut.jpg)
(09 Modified LED Inserted.jpg)
(10 Bright White Dome Light.jpg)
Attachments 01 Brochure Dome Lamp.jpg (132KB - 1065 downloads)
Attachments 02 NOS Dome Lamp Lense.jpg (81KB - 1039 downloads)
Attachments 03 NOS Dome Lamp Lense Imperial.jpg (137KB - 1040 downloads)
Attachments 04 Twist Rear Shell for Removal.jpg (61KB - 1016 downloads)
Attachments 05 Comparison LED - Bulb.jpg (66KB - 1124 downloads)
Attachments 06 Socket Removal.jpg (91KB - 1096 downloads)
Attachments 07 Socket Removed.jpg (50KB - 1008 downloads)
Attachments 08 Resistor on Minus and Ground Cut.jpg (60KB - 1029 downloads)
Attachments 09 Modified LED Inserted.jpg (81KB - 1078 downloads)
Attachments 10 Bright White Dome Light.jpg (114KB - 995 downloads)
sermey
Posted 2015-05-12 10:41 AM (#478081 - in reply to #156081)
Car Production Broadcast: My restored Car Production Broadcast I had already presented a time ago in the appropriate forum. In this thread here I just show HOW I did it, not must be the best way to go – but it works.
Scan the sheet with 1200dpi in precise vertical/horizontal orientation with Photoshop. It needs Win7 64-bit with at least 8MB RAM. The original scan is in the first layer named background (01). The layer 00 is a copy of the background in case of a disaster. . . . (01).
Create the next layers 01 – 06 for individual mastering, and freeze them from moving (02).
The layer 01 is the background pattern of the sheet, sample taken in a clean segment in layer 00. Remember, this background in not a uniform color, thus a pattern!
Next copy the selected items from layer 00 into the designated layers as shown in (02), ready there for clean and restore individually. If the result in a layer is not satisfactory, then just delete and re-copy it.
Examples of restored layers:
Layer 02: Original Text with Grid brown (03).
Layer 03: Original Typed Numbers black (04).
The typed numbers are not upgraded as they could be in order to keep their authentification. When all layers have been restored, merge all in one layer to stay fixed. This will be the final Car Production Broadcast Restored, saved here in a smaller resolution, as JPG-Picture (05), or 1 : 1 as PDF-File with 144dpi (because of the 250k limitation) (08).
The letters and the grid can as well be reproduced instead restored. Here the letters then are taken from the font library (Arial, Bold, Smooth, Color RGB: 207-113-46) and the lines are created by construction, all in Photoshop. In direct comparison to the original in the left, the difference is hardly visible (06). The Original Typed Numbers remains as before (04). Each single number can be selected, copied and inserted individually for another specific sheet (07).
Now, any missing Car Production Broadcast can be re-created by anyone. Happy printing!   - SERGE -
(01 Car Production Broadcast Scanned in.jpg)
(02 Layers Listing.jpg)
(03 Original Text with Grid.jpg)
(04 Original Typed Numbers black.jpg)
(05 Car Production Broadcast Restored.jpg)
(06 Comparison Original Text - New Font.jpg)
(07 Car Production Broadcast New Texted.jpg)
Attachments 01 Car Production Broadcast Scanned in.jpg (123KB - 1112 downloads)
Attachments 02 Layers Listing.jpg (118KB - 1026 downloads)
Attachments 03 Original Text with Grid.jpg (119KB - 1103 downloads)
Attachments 04 Original Typed Numbers black.jpg (40KB - 999 downloads)
Attachments 05 Car Production Broadcast Restored.jpg (132KB - 1042 downloads)
Attachments 06 Comparison Original Text - New Font.jpg (122KB - 1030 downloads)
Attachments 07 Car Production Broadcast New Texted.jpg (137KB - 1111 downloads)
Attachments 08 Car Production Broadcast Restored 144dpi.pdf (120KB - 1136 downloads)
ToMopar
Posted 2015-05-13 6:29 AM (#478134 - in reply to #156081)
10001001002525
Serge, It's great to "restore" all the history what comes with the car. Great work!
d500neil
Posted 2015-05-15 12:18 PM (#478355 - in reply to #156081)
5000500050002000200010025
PM sent (very-soon!)
sermey
Posted 2015-05-20 4:10 AM (#478891 - in reply to #156081)
License Plate Lamp: For a brighter light the bulb can as well be replaced by a LED. The lamp unit is fixed with a bracket (01) (02). The heat of the bulb, consuming 5W, causes the lens to melt partially (03).
As replacement I used the same LED as for the dome lights. The contacts here are brigded for a full power (04). The fixing pins on the LED can be left as is. Just bent out the tab, on the concerned side of the lamp socket, for turning the LED in, view one side and the other side (05).
Now the license plate shines brighter at lower power consumption, and without melting the lens anymore (06). - SERGE -
Edited by sermey 2015-05-20 6:15 AM
(01 Lamp Unit.jpg)
(02 Lamp Unit Rear View.jpg)
(03 Melted Lens.jpg)
(04 Bulb 5W - LED.jpg)
(05 Lamp Socket Bent.jpg)
(06 Bright License Plate.jpg)
Attachments 01 Lamp Unit.jpg (72KB - 1044 downloads)
Attachments 02 Lamp Unit Rear View.jpg (84KB - 1091 downloads)
Attachments 03 Melted Lens.jpg (71KB - 1063 downloads)
Attachments 04 Bulb 5W - LED.jpg (88KB - 1005 downloads)
Attachments 05 Lamp Socket Bent.jpg (80KB - 1031 downloads)
Attachments 06 Bright License Plate.jpg (100KB - 1024 downloads)
di_ch_NY56
Posted 2015-05-20 6:07 AM (#478897 - in reply to #156081)
100050025
Hell! It looks wonderful. Thank you very much Serge.
Did you know, there are LED lamps available with a BA15d socket with to connection points?
Kind  regards,
Dieter
Edited by di_ch_NY56 2015-05-20 6:08 AM
