1958 Plymouth Belvedere Convertible Jump to page : 1 2 3 4 Now viewing page 4 [50 messages per page] | View previous thread :: View next thread |
big m |
Expert 5K+ Posts: 7808 Location: Williams California | Nice progress, Matt!! | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Thanks John! | ||
ply57nz |
Regular Posts: 94 Location: New Zealand | Looks like your getting the better of it, Great workmanship, it's going to be a car to be proud of when you are finished. Cheers Norm | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Today I removed both side rocker panels, totally wasted, but enough to build copies of I hope. The CDC wants this car gone, too much tetanus! (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (290KB - 309 downloads) image.jpg (316KB - 345 downloads) image.jpg (231KB - 316 downloads) image.jpg (242KB - 314 downloads) image.jpg (237KB - 336 downloads) image.jpg (316KB - 360 downloads) image.jpg (294KB - 380 downloads) image.jpg (272KB - 305 downloads) image.jpg (271KB - 316 downloads) image.jpg (251KB - 309 downloads) image.jpg (202KB - 350 downloads) image.jpg (230KB - 303 downloads) image.jpg (261KB - 296 downloads) image.jpg (286KB - 320 downloads) image.jpg (246KB - 333 downloads) image.jpg (229KB - 370 downloads) image.jpg (196KB - 319 downloads) image.jpg (248KB - 353 downloads) image.jpg (239KB - 309 downloads) image.jpg (214KB - 304 downloads) image.jpg (260KB - 329 downloads) | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Last week, I braced the side braces, and replaced the worn driver's side door hinges from the parts car. (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (247KB - 333 downloads) image.jpg (241KB - 345 downloads) image.jpg (164KB - 289 downloads) image.jpg (170KB - 309 downloads) | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Well done Matt, looks good. You have been busy!! Greg | ||
sidesho_bob1961 |
Expert Posts: 1728 Location: Fleetwood, Pa | Matt, Just remember, slow and steady wins the marathon.........keep going, you're making good progress... | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Thanks guys!!! | ||
henricthornsund |
Location: Sweden | christine-lover - 2011-08-08 2:06 AM d500neil - 2011-08-03 4:14 PM Motor number is NOT AVAILABLE....what's up, with that (not recording the engine number on the IBM card???) ? Thank you Neil, my guess is possibly only high performance engine numbers were listed on the IBM cards. I had no idea what NCS stood for, but it makes sense. I though it had something to do with Chrysler Historical Society. I looked at My build card just now and it contains the engine #. Mine is built at The Evansville plant with a 318 Super-Pak engine as well. It is also interesting how differently your accessory list is completed compared to mine. I Will upload pics of My IBM card in my Plymouth thread. Edited by henricthornsund 2014-06-06 5:04 PM | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Some years' IBM cards, from the various Assembly Plants, are very different from each other. 56 & 61 Dodges' IBM cards are very different, and after getting a Delaware Plant IBM card, for the 59 Dodges, I was finally able to 'crack' some of the options codes which were not self explanatory, on the Detroit & L.A. IBM's. | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | That's awesome. I'm sure the engine in my Plymouth is the original one, the engine bay was untouched, correct date coded/correct part number carburetor, distributor (which is different in 4 bbl car, but not listed in the Master Parts Catalog), radiator, etc. The fuel and water pump were replaced, which would be typical. I don't think I ever posted a photo of its engine bay, until now. Again, I plan on an it's-OE restoration on this car, so I will keep this looking this way just restored and detailed. (image.jpg) Attachments ---------------- image.jpg (256KB - 305 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Matt, Big M, on this website, should be able to fix you 'up' with an OEM fuel line and fuel filter. | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | d500neil - 2014-06-06 7:45 PM Matt, Big M, on this website, should be able to fix you 'up' with an OEM fuel line and fuel filter. Thanks Neil. I have this photo of what an OEM fuel line should look like for a 4 bbl car, from a 58 convertible as well. I wish John would cut the quarters off his Fury for me! Haha (image.jpg) Attachments ---------------- image.jpg (107KB - 280 downloads) | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Today I drilled a lot of the brass welds on the passenger side quarter off the donor car. This car was hit and a replacement quarter was put in using brass filler metal. I plan to use some of the inner and outer lower wheel house metal from both sides as patches. (image.jpg) Attachments ---------------- image.jpg (246KB - 296 downloads) | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | From the inside. (image.jpg) (image.jpg) Attachments ---------------- image.jpg (249KB - 286 downloads) image.jpg (298KB - 299 downloads) | ||
The Chrysler Kid |
Expert Posts: 1384 Location: Ocala, Florida | Very nice progress! You sure this is the same car at the beginning of the build? | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | I think so Randy, it didn't look that bad before. | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Continued drilling out the spot welds today. (image.jpg) Attachments ---------------- image.jpg (172KB - 278 downloads) | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | I currently have a fabricator making rocker panels for this car, using the Swedish reproductions as a base, which includes all 3 panels on each side. They are being done to resemble the OE panels even in areas that will never be seen. When they are completed I am going to install them. That's where I'm at with this car. | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | These are photos of how the rockers are starting to fit, not completed but I did test fit these last month. (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (430KB - 335 downloads) image.jpg (486KB - 304 downloads) image.jpg (225KB - 268 downloads) image.jpg (217KB - 270 downloads) image.jpg (273KB - 304 downloads) image.jpg (254KB - 284 downloads) image.jpg (300KB - 299 downloads) | ||
Matthew Keij |
Extreme Veteran Posts: 481 Location: The Netherlands | Great work Matt! Are you coming to Carlise? | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Thank you Matt. Yes, I'll be in Carlisle, definitely. | ||
big m |
Expert 5K+ Posts: 7808 Location: Williams California | Looks nice, Matt!! | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Matt, just check you're drain holes in rockers, 57 and 58 I think are different , those holes you have look like 57 rockers, Paul. | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Hi Paul, he is using my original rockers as patterns so everything is identical to what was on the car. | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | big m - 2015-06-22 4:42 PM Looks nice, Matt!! Thanks John! | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Very professional, Matt. Nicely done! Greg | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Thanks Greg. This past Sunday I picked up all 6 panels from him. | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | christine-lover - 2015-06-30 8:11 PM This past Sunday I picked up all 6 panels from him. After waiting this long it probably feels great to have them home. Good luck with the assembly and keep us posted! Greg | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Yes, that will be the next adventure. And what an adventure that will be. I got to get a cleaner, since they have an oil coating on them, then POR-15 the inside areas of them and prime the other areas. | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Test fitted the drivers side inner rocker, fits well. (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (244KB - 275 downloads) image.jpg (223KB - 256 downloads) image.jpg (218KB - 273 downloads) image.jpg (197KB - 296 downloads) image.jpg (118KB - 298 downloads) image.jpg (111KB - 291 downloads) | ||
Adventurer 60 |
Elite Veteran Posts: 827 Location: tailFinland | Looking good! | ||
fast59desoto |
Elite Veteran Posts: 929 Location: Finger Lakes NY | looking great matt! | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Thanks! | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | I put together the 3 pieces of the rocker panels on the right side up into the car. I had to cut and rework the inner rocker to fit the floor better at the rear part. Before I would put each panel up into place and see how it fit and the fit well. This was the first time I put all 3 pieces into place to check fit. Well, they don't fit good at all, the inner is a half inch? away from the floor, also the outer rocker up front is way off where it would be bolted to the outrigger once fender is on. Not really sure what to do now, I may have dug myself into a corner!! (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (189KB - 263 downloads) image.jpg (155KB - 293 downloads) image.jpg (117KB - 273 downloads) image.jpg (123KB - 257 downloads) image.jpg (147KB - 257 downloads) image.jpg (174KB - 287 downloads) image.jpg (124KB - 259 downloads) image.jpg (150KB - 247 downloads) image.jpg (99KB - 267 downloads) | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Hi Matt, Don`t try putting all 3 pieces together at the same time, they probably won`t fit, put the inner rocker in first and work round that, the floor is not straight from one end to the other the inside of the car is wider in the middle, concentrate on getting that in first, then work the outer rocker in place to get a good gap under your door, a few vise grips are going to be needed to pull the sections together for welding, use self tapping screws to hold panels in place then you can plug weld holes up after, Paul. | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Thank you Paul. I believe I found the issue here, took me a while but it appears to be sagging, the sides of the cowl and also the overhang of the front of the quarters weigh a good bit and what needs to be done is to bring them up using a scaffold, which I started to bring it up. I'm just glad at this point I didn't try to cut the rockers in anyway to make them fit. | ||
Board Moderator & Exner Expert 10K+ Posts: 13055 Location: Southern Sweden - Sturkö island | Very nice work, keep it up Matt and keep us posted! | ||
