Desoto ´57 341 water pump
Finfireflite
Posted 2008-11-06 1:35 PM (#150972)
Subject: Desoto ´57 341 water pump
Looking for a water pump to my desoto and it seems that it`s not so easy to find.Does anyone know if the `58 and later mopar bb water pump fits?It look a lot like mine from the pictures.
Shep
Posted 2008-11-11 7:43 PM (#151573 - in reply to #150972)
Subject: Re: Desoto ´57 341 water pump
20001000100100100100
If you have one that is bad, many places rebuild them. If not try try Fremans Auto 406-287 5436, or VVAP.com, whoops, didn't see where you are!! I will check my interchange book tomorow.
Shep
Posted 2008-11-12 3:21 PM (#151666 - in reply to #150972)
According to my book that pump is for that year/engine only.
Finfireflite
Posted 2008-11-13 12:17 AM (#151733 - in reply to #151666)
Thanks Shep for the information.I found a `59 Desoto water pump and compared it with my old one .I found out that it´s a little bit bigger than mine.It think it could be used but it will need some work ( some machining to the impeller and case).I bought a `57 nos pump from ebay so this problem is solved.
Edited by Finfireflite 2008-11-13 12:24 AM
