| Are molded arm rest in the door panel a separate piece
or is it part of the door panel itself.
I'm looking for Fury door panels.
Thanks, Blast |
     Location: Newark, Texas (Fort Worth) | I believe it is a separate piece made of foam. |
| Any pictures and dimensions would be appreciated. |
   Location: Kangasala, Finland | It seems to be the same as in '57 Fury.
It is made of stampled cardboard, has foam cushion (2 cm thick) and metal support on the back,
The actual rest is 32 cm long, 11 cm high and 7,5 cm deep.
(20260411_190205.jpg)
Attachments ----------------
(20260411_190001.jpg)
(20260411_185809.jpg)
(20260411_190650.jpg)
(20260411_190135.jpg)
| Thank you so much for the pictures and dimensions.
Blast |
