Poly Valve Cover ID Help
tdesoto276
Posted 2026-01-11 9:37 PM (#642587)
Subject: Poly Valve Cover ID Help
New User
Need some expert help. What poly engine used the valve cover with the coil bracket off the passenger side? Or alternatively, was this valve cover used on a 1957 V800 combination? Thanks in advance.
Edited by tdesoto276 2026-01-11 9:41 PM
Posted 2026-01-12 9:46 PM (#642592 - in reply to #642587)
Subject: RE: Poly Valve Cover ID Help
5000500050010010010010025
tdesoto276 - 2026-01-11 6:37 PM
Not an expert but I know how to search.
BUT from Justin L's excellent website:
https://poly318.com/poly-318-intake-manifolds/
"Poly 318 Factory Stamped Steel Valve Covers
All factory valve covers were stamped steel. 1956 – 1958 and some 1959 have three bolt holes but will interchange with all year and displacement A-blocks. Most cylinder heads have the center bolt boss drilled and threaded through end of production in 1967. Those missing the center boss or threads can be drilled and tapped for the center bolt.
Note that the spark plug separators, wire loom clamps, and other mounting brackets changed throughout the years for those needing to pay specific attention for Concours-level restorations."
Personally, I don't see much room for a coil on a V800/Fury passenger side valve cover
