single point distributor dual point conversion.
Blast
Posted 2025-11-06 3:40 PM (#641873)
Subject: single point distributor dual point conversion.
I understand that I can convert a single point distributor for my 58 plynouth with a 318 poly engine with an
IBS/IAZ/IBK dissie dual point cam and plate inside a single point dissie. I also want to maybe use the Petronix 1383 Ignitor attached to the dual point plate.
The 1383 Petronix Ignitor was discountiuned and replaced with the Petronix 1385ls Ignitor. Is the any differences between the 2 ignitors and can I use it to supersede the Petronix 1383 Ignitor.
Thank, Blast.
Mopar1
Posted 2025-11-07 5:17 PM (#641883 - in reply to #641873)
Subject: Re: single point distributor dual point conversion.
20001000100252525
You can switch guts, or just drop in an electronic LA dizzy.
