1958 Fury Patch Panels
Blast
Posted 2025-10-15 12:12 PM (#641696)
Subject: 1958 Fury Patch Panels
I would like to know what are the most sort after patch panels.
What areas of the fury are most problematic (rust through).
What panels would you like to see reproduced.
I may be able to help with reproduction of these panels.
If they are reproduced already let me know and Pictures are a plus.
Thanks, Blast
Posted 2025-10-15 2:31 PM (#641699 - in reply to #641696)
Subject: Re: 1958 Fury Patch Panels
50005000100100100100
Good, high quality reproductions are made in Sweden, but *IF* you can make them as good, it would be good to have a US supplier. If you can't, then don't bother.
Typical problems are lower rear quarters, all around the wheel lip, front portion of rear quarter, front upper part of front fender, and of course, floors. Floors are probably what most people need. There are a couple of US suppliers for them, but none of them are very accurate.
Posted 2025-10-15 10:19 PM (#641702 - in reply to #641699)
500050002525
You may also want to try John and M'Lisa Fowlie at Big M.  Sometimes you can cut floors from a good donor and use those.
Finsinthemirror
Posted 2025-10-16 1:57 AM (#641705 - in reply to #641696)
10001002525
Let's not forget lower doors along with the rear c pillar corners and all around the rear window bottom.
