Carter 2631s dual carburetor / right or wrong
Blast
Posted 2025-09-27 9:15 PM (#641557)
Subject: Carter 2631s dual carburetor / right or wrong
I was browsing the web searching for the Carter 2631s dual carburetor.
What I found was pictures showing 2 different throttle bases.
One Picture showed a solid base while other pictures showed the vacuum cut out in the base.
Which one is correct for the 2631s secondary carburetor or where both bases used on that particular carburetor?
Posted 2025-09-28 12:57 AM (#641560 - in reply to #641557)
Subject: RE: Carter 2631s dual carburetor / right or wrong
5000500050010010010025
The Carter 2631s is the front carburetor of a 1957 Plymouth Fury dual carb pair. It's PN was 1821 709.
The rear carburetor of that dual carb pair was a Carter 2632s, PN 1821 710.
They will be different because one will have a heat activated choke (I think). Not sure about which one
would have a vacuum connection for the distributor but I would have to guess the rear one.
Some info about these carbs:
https://www.carbkits.com/catalog/details/3985
https://www.carburetion.com/kits/plymouth.htm?srsltid=AfmBOop1hyWUJ1...
Posted 2025-09-28 12:38 PM (#641564 - in reply to #641557)
Subject: Re: Carter 2631s dual carburetor / right or wrong
Photos or links to the photos would probably help us get answers for you.
