Dual Carburetor 318 poly v800
Blast
Posted 2025-08-30 9:47 PM (#641317)
Subject: Dual Carburetor 318 poly v800
What are the correct dual carburetor numbers for 1958 318 poly v800 engine.
Posted 2025-08-30 11:40 PM (#641318 - in reply to #641317)
Subject: RE: Dual Carburetor 318 poly v800
500050001000100100
Blast - 2025-08-30 6:47 PM
What I see listed is two different front/rear Carter WCFB pairs for the 1958 dual quad 318 :
2631S Front and 2632S rear (might be the 1957 version)
and
2761S front and 2762S rear (most likely the 1958 version)
Rebuild Kits:
https://www.ebay.com/itm/281495446237?
Hope that helps a bit
(57-58PlymouthDualQuadCarbPNs.jpg)
Attachments 57-58PlymouthDualQuadCarbPNs.jpg (158KB - 264 downloads)
Mopar1
Posted 2025-08-31 11:51 AM (#641320 - in reply to #641318)
20001000100252525
56D500boy - 2025-08-30 10:40 PM
and
Rebuild Kits:
I suspect one has a choke & one doesn't.
Posted 2025-08-31 12:25 PM (#641321 - in reply to #641320)
500050001000100100
Mopar1 - 2025-08-31 8:51 AM]
Agree. Probably very similar to this early Corvette dual WCFB quad set up:
Blast
Posted 2025-09-01 8:24 AM (#641325 - in reply to #641317)
Subject: Re: Dual Carburetor 318 poly v800
Thank you guys. I appreciate your help.
One other question. I read somewhere what
the v800 had was the dual carbs, special cam and dual exhaust
that gave it that 290hp. Is that correct?
Blast
Posted 2025-09-01 8:37 AM (#641326 - in reply to #641317)
I think I left something out , Dual point distributor?
What cam was in it?
Posted 2025-09-01 9:58 AM (#641327 - in reply to #641325)
500050001000100100
Blast - 2025-09-01 5:24 AM
There are a few flavours of 318 V800. The one you are talking about was the Dual Fury V800:
Blast
Posted 2025-09-01 7:14 PM (#641329 - in reply to #641317)
Thank you for that info.im looking for the dual braker distributor IBS-4003
Any advise to find one?
Mopar1
Posted 2025-09-01 10:17 PM (#641333 - in reply to #641329)
20001000100252525
If you're not looking at an OEM resto type, a 318 LA dual point will bolt right in.
Blast
Posted 2025-09-02 8:07 AM (#641335 - in reply to #641317)
Thank you for that LA 318 information.
Do you have a number on that distributor?
Mopar1
Posted 2025-09-03 9:32 PM (#641345 - in reply to #641335)
20001000100252525
Blast - 2025-09-02 7:07 AM
Was thinking more on the line of an aftermarket one for a 340.
