1955 custom royal converting to manual trans
TwoLane
Posted 2025-08-04 11:40 PM (#641087)
Subject: 1955 custom royal converting to manual trans
New User
This is my first post here, so bear with me. I have a 55 custom royal that I am converting to a manual 5-spd transmission with a hydraulic clutch. Any advice on what clutch pedal assembly to go with to add a third pedal? I ordered a set for a 68 camaro that doesn't seem like it will work out without a lot of modification. It doesn't quite wrap around the steering colum like it should. Any advice on what would work aside from just fabbing something up from scratch? Thanks
Posted 2025-08-05 12:12 AM (#641089 - in reply to #641087)
Subject: RE: 1955 custom royal converting to manual trans
5000500010001002525
David: Not sure where you are living but you will want to find a wrecking yard with old Mopars.
French Lake Auto Parts in Minnesota
Wild Cat Mopars in Oregon
Big M Auto Parts in California
I have dealt with all three with success in the past.
Good luck:
(55-56ClutchAnd BrakePedals.jpg)
Attachments 55-56ClutchAnd BrakePedals.jpg (148KB - 278 downloads)
TwoLane
Posted 2025-08-14 11:05 PM (#641190 - in reply to #641087)
Subject: Re: 1955 custom royal converting to manual trans
New User
Thanks for the info and the diagram. I found a setup from a 55 DeSoto on ebay and it was exactly what I needed. I'm looking forward to getting this thing rolling! Thanks again!
