'55-'56 Dodge/Plymouth Rear Axle Parts
   Forward Look Swap Meet -> For Sale - PARTSMessage format
Posted 2025-07-14 5:49 PM (#640811)
Subject: '55-'56 Dodge/Plymouth Rear Axle Parts
50005000100100100100
I am swapping out the rear axle, driveshaft & transmission from my pink '56 Belvedere. It has good working 3.54 gears in it. Would anyone like to buy the gears, brakes, drums, axles or other parts from it? I am planning to cut off the spring perches so the housing probably wouldn't be of interest to people. [UPDATE: I found the spring perches that I cut from my Savoy, so I can sell the whole rear end if someone would like to purchase it that way. I will keep the perches attached until I have to scrap it, if that ends up happening.]
I will sell this stuff cheaply. Shipping will be the only high cost on it. For the transmission, I will only sell that locally - dirt cheap. 2nd gear doesn't work, but the others do.
Edited by Powerflite 2025-07-14 11:44 PM
(56 Plym Belv Rear End.jpg)
Attachments 56 Plym Belv Rear End.jpg (175KB - 174 downloads)
Posted 2025-09-14 10:13 AM (#641432 - in reply to #640811)
Subject: Re: '55-'56 Dodge/Plymouth Rear Axle Parts
Does anyone need anything from this? I will cut the perches, remove the junction block and scrap the rest soon.
Posted 2025-09-25 5:08 PM (#641520 - in reply to #640811)
I will also be parting out an 8 3/4 from a '56 DeSoto. This axle isn't compatible with the '57-up 8 3/4 though, as far as I know. Let me know if anyone needs anything from it as it will most likely get scrapped otherwise.
Posted 2025-09-27 1:38 PM (#641548 - in reply to #641520)
Here is a picture of it. I rotated the wheels & counted to see that the gear ratio is the optional 3.73:1. This is in between the standard 3.54 for Powerflite & 3.90 for manual transmission. Let me know within 2-3 weeks if you want anything, before it gets scrapped.
(56Firedome Original Rear End.jpg)
Attachments 56Firedome Original Rear End.jpg (239KB - 77 downloads)
