Stop Light Switch electrical plug/connector
Posted 2025-07-11 10:42 AM (#640775)
Subject: Stop Light Switch electrical plug/connector
50001000500100252525
Hi all:
I am looking for the plug with 2 female connectors for the SLS27 switch. I found a couple 90 degree single plugs and ordered them. Mine has some cobbled butt connectors and works terribly. Thanks! Marc.
(60ply3.jpg)
Attachments 60ply3.jpg (122KB - 205 downloads)
Posted 2025-07-11 3:45 PM (#640782 - in reply to #640775)
Subject: RE: Stop Light Switch electrical plug/connector
5000500050010010010010025
mstrug - 2025-07-11 7:42 AM
Hi all:
Marc: I believe that the 1960 Mopar stop lamp switch was a 2084 284. When searching as "2084284 stop lamp switch 1960 Plymouth Dodge" the OE looking ones that show up in the search have both male and female
bullet connector needs. One of the wires has the "hot" signal and therefore should need a female bullet connector that fits over the male pin on the switch. The output side of the switch is most likely a male bullet
connector.
One switch source:
https://www.moparpro.com/brake-light-switch-1955-1961-plymouth-dodge...
"Replaces MoPar part #1604989 or 2084284"
Edited by 56D500boy 2025-07-11 3:49 PM
(1960PlymouthOEBrakeLightSwitchPN2084284.jpg)
(1960PlymouthOEBrakeLightSwitch.jpg)
Attachments 1960PlymouthOEBrakeLightSwitchPN2084284.jpg (109KB - 202 downloads)
Attachments 1960PlymouthOEBrakeLightSwitch.jpg (148KB - 203 downloads)
Posted 2025-07-11 8:48 PM (#640787 - in reply to #640775)
Subject: Re: Stop Light Switch electrical plug/connector
O.K. thanks! The one I got has 2 pins. nice detail, makes it even harder. I'll just use the 90 degree connectors. Marc
