315 Poly V8 valve Lifter questionJump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forward Look Technical Discussions -> Engine, Exhaust, Fuel and Ignition | Message format |
| Steve1956 |
Veteran Posts: 139 ![]() ![]() | I bought an engine rebuild kit from Egge , and passed it over to my engine rebuilder with the engine. All has gone well, until he has now looked at the Valve Lifters and tells me they are about .001 oversize as they wont fit in the head, and also they are a different height. My original ones are 2" tall, and the new ones from Egge are about 1 27/32" tall, plus being about .001 oversize. When you order the 315 CID Poly kit and select valve lifters there is no option to choose a particular size i.e oversize. I have emailed Egge for their response, but I am in Australia and keen to know that what came with the motor was the correct lifter. The engine was not running when I acquired the car. Have attached some photos if that helps anyone offer an opinion. I see some valve Lifters on ebay etc, as well, but I don't want to buy another wrong set. They don't offer detailed dimensions on these items, so guess I will have to ask ? Thanks, Steve (VALVE4.jpg) (VALVE1.jpg) (VALVE3.jpg) (VALVE2.jpg) Attachments ---------------- VALVE4.jpg (49KB - 236 downloads) VALVE1.jpg (96KB - 240 downloads) VALVE3.jpg (52KB - 254 downloads) VALVE2.jpg (53KB - 222 downloads) | ||
| Mopar1 |
Expert Posts: 3158 ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | Hopefully he meant block, noy head.... You might have lifters for something other than a Mopar, hemi, poly, LA, big block all have same diamiter lifters. Hemis, and hemi based Polys should use # 812 lifters for the early 361/413 big block. Not exactly the same as OEM but they work. One company makes 812s, but those are for S. B. chevy. Melling 812s are right. The LA lifter will work, but is taller & probably would need adjustable push rods, might be what you have, except for the width problem. | ||
| 58coupe |
Expert Posts: 1793 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Alaska | I have torn down a number of LA engines, big blocks and poly, early hemi and have never seen a lifter that looks like the ones sent to you from Egge. As George stated, these must be for a different engine sent to you by mistake. | ||
| 57chizler |
Expert Posts: 3858 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: NorCal | Steve1956 - 2025-07-09 12:31 AM I bought an engine rebuild kit from Egge , and passed it over to my engine rebuilder with the engine. All has gone well, until he has now looked at the Valve Lifters and tells me they are about .001 oversize as they wont fit in the head, and also they are a different height. Has your rebuilder actually tried to fit the lifters in the block? The height of the lifter body isn't as important as is the dimension from the lifter face to the bottom of the pushrod socket. IOW, the disc at the top of the long lifter might sit further down in the body. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11028 ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . I think that the standard bore OE PN for the 315 Poly hydraulic lifter was 1555 176 (1555176 when searching). Should look something like this one: Part Number: 2808569 [supercedes P/n 1531204, 1555176, 1731618 1851904 & 2084029] ![]() | ||
| wayfarer |
Elite Veteran Posts: 935 ![]() ![]() ![]() ![]() ![]() ![]() Location: Peoples Republic of Oregon | The short lifter with the wide band looks to be a #2011, common for the LA engine. They require a 5/16 dia pushrod tip whereas the early engines use a ¼" tip. Generally, they do not properly connect with the oil feed hole in the lifter bore although you could modify the hole with a Dremel. You will also then need adjustable pushrods to compensate for the length/height......if you have cut the heads, deck or use a reground cam you will still need adjustable pushrods but with the proper lifter you will use ¼" tip t&b. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11028 ![]() ![]() ![]() ![]() Location: Lower Mainland BC | 56D500boy - 2025-07-09 2:40 PM 2808569 [supercedes P/n 1531204, 1555176, 1731618 1851904 & 2084029] I took some of those equivalent numbers and went tappet hunting on Rock Auto. That resulted in 3 options. https://www.rockauto.com/en/partsearch/?pgname=Engine&partnum=280856... The Melling option (expensive) listed sizes which might be useful as a comparison. Edited by 56D500boy 2025-07-09 6:18 PM (HydraulicTappetCrossOversFor315Poly_3Options.jpg) (HydraulicTappetCrossOversFor315Poly_MellingDetails.jpg) Attachments ---------------- HydraulicTappetCrossOversFor315Poly_3Options.jpg (147KB - 236 downloads) HydraulicTappetCrossOversFor315Poly_MellingDetails.jpg (149KB - 241 downloads) | ||
| mstrug |
Expert 5K+ Posts: 6683 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Newark, Texas (Fort Worth) | Seems they fit various MOPAR engines: https://www.ebay.com/itm/253165412771?chn=ps&norover=1&mkevt=1&mkrid... Fits 1952-1958 Desoto Dodge Lifter set of 16 Lifters 276 291 330 341 270 315 Dodge/Chrysler 413 1959-1965 Plymouth/Dodge 440 1966-1967 Plymouth/Dodge 383 1959-1967 Dodge/Chrysler/Plymouth/Desoto 361 1958-1966 331 Chrysler 1954-1956 354 Chrysler // and 354 Dodge truck 1956-1959 392 Chrysler 1957-1958 Dodge/Desoto/Plymouth 350 1958 Dodge/Desoto 325 1957 Desoto 291 1955 Desoto 330 1956 Desoto 341 1956-1957 Desoto 345 1957 Desoto 276 1952-1954 Dodge 270 1955 Dodge 315 1956 Dodge 241 1953-1954. Darn 1956 315. | ||
| mstrug |
Expert 5K+ Posts: 6683 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Newark, Texas (Fort Worth) | Kanter, I know... https://www.ebay.com/itm/312286281823?_skw=dodge+325+315+lifters&itm... 16 Valve Lifters Dodge 241 270 315 325 361 350 383 V8 Up for sale is a brand new set of 16 Hydraulic Valve Lifters. These are precision machined to meet or exceed O.E.M. specifications. These will fit the following: These are for engines with Hyraulic Lifters only! 1953-54 Dodge with 241ci V8 engine using 1 piece lifters 1955-56 Dodge with 270ci V8 engine 1956 Dodge with 315ci V8 engine 1957-58 Dodge with 325ci V8 engine 1958-66 Dodge with 361ci V8 engine 1958 Dodge with 350ci V8 engine 1959 Dodge with 383ci V8 engine 1963-67 Dodge with 383ci V8 engine 1961-63 Dodge with 413ci V8 engine 1965 Dodge with 413ci V8 engine 1964-65 Dodge with 426ci V8 engine 1966-67 Dodge with 440ci V8 engine 1954 Dodge Truck with 241ci V8 engine 1955-56 Dodge Truck with 260ci V8 engine 1955-56 Dodge Truck with 270ci V8 engine 1954-56 Dodge Truck with 331ci V8 engine 1956-59 Dodge Truck with 354ci V8 engine 1957-59 Dodge Truck with 315ci V8 engine 1960-67 Dodge Truck with 361ci V8 engine 1960-67 Dodge Truck with 413ci V8 engine 1967-68 Dodge Truck with 383ci V8 engine Control #: 16 x VL 8 315 and 325! if real. | ||
| wayfarer |
Elite Veteran Posts: 935 ![]() ![]() ![]() ![]() ![]() ![]() Location: Peoples Republic of Oregon | Two additional thoughts. AFAIK, TopLine Johnson aka Hy-lift, is the only US manufacturer of the #812 lifter. I asked the EngineTech folks and they admit that theirs are made in Thailand or some such place. Melling would not tell me the source of their product. You can buy direct from Topline. Also note that there is another 'Johnson' brand and it is NOT the same as TopLine. | ||
| Mopar1 |
Expert Posts: 3158 ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | wayfarer - 2025-07-11 8:47 AM Melling; That doesn't sound good... Johnson: Someone is doing trademark infringment, also not good to muddy the waters..Melling would not tell me the source of their product. Also note that there is another 'Johnson' brand and it is NOT the same as TopLine. | ||
| Steve1956 |
Veteran Posts: 139 ![]() ![]() | Thanks everyone for all the info. I'm nearly there !! I'm just seeking confirmation if anyone has used a #812 lifter with the standard 9 3/16" pushrod. Now I understand the overall height of the lifter is the not the issue, rather the measurement of the push rod seat in the lifter from the base of the lifter. hence my question. Thanks, Steve | ||
| wayfarer |
Elite Veteran Posts: 935 ![]() ![]() ![]() ![]() ![]() ![]() Location: Peoples Republic of Oregon | If anything has been changed from the oem design, like regrinding the cam, decking the heads or block, or using a fat head gasket then the amount of lifter preload will change and can certainly affect runability. This is the reason for installing adjustable pushrods. I suggest using Smith Brothers. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11028 ![]() ![]() ![]() ![]() Location: Lower Mainland BC | wayfarer - 2025-07-16 8:30 AM If anything has been changed from the oem design, like regrinding the cam, decking the heads or block, or using a fat head gasket then the amount of lifter preload will change and can certainly affect runability. This is the reason for installing adjustable pushrods. I suggest using Smith Brothers. https://www.pushrods.net/adjustable-pushrods One of these Mopar-related shops in Australia should be able to help you. Unfortunately, none appear to be right close to Sydney. But they will have phones. https://www.google.com/search?q=Mopar+speed+parts+in+Australia&clien... Good luck. Edited by 56D500boy 2025-07-16 6:05 PM | ||
| Steve1956 |
Veteran Posts: 139 ![]() ![]() | Does anyone have any experience of the valve lifters supplied by US Seal Co,. They seem a lot cheaper than Melling and others. Their relevant P/N seems to be LIF8. Does anyone have any experience / opinion of the valve quality? Thanks | ||
| wayfarer |
Elite Veteran Posts: 935 ![]() ![]() ![]() ![]() ![]() ![]() Location: Peoples Republic of Oregon | Interesting.....their website is dated 2023 which, may or may not be a 'thing'. The website also only indicates seals as their product line. I did not find lifters. Perhaps I didn't look deep enough. Given the total cost of your rebuild, is an additional $200, m/l, that much of a problem? | ||
| Steve1956 |
Veteran Posts: 139 ![]() ![]() | Sorry for being vague. Here is a link to the item https://ussealparts.com/catalogsearch/result/?q=lif8 Not wanting to be too defensive, but I am retired and doing this restoration on a tight budget and a pension, so I do try not to pay any more than I need on items otherwise the whole project would be way over an extra $200. $US, and much more in my local currency $AUD) That being said, I do appreciate the interest and time it takes to offer responses. All input accepted and appreciated. thanks, Steve | ||
| wayfarer |
Elite Veteran Posts: 935 ![]() ![]() ![]() ![]() ![]() ![]() Location: Peoples Republic of Oregon | Steve, I completely understand the retired thing....most days I am just plain tired....living on pensions and investments never keeps up with inflation so we are always struggling to get work done. I do feel bad for folks who have no skills. The link shows a proper listing for 'some' of the possible applications however, the same list also includes several 68-71 engines which would be incorrect as MaMopar changed lifter and pushrod design for the 68 model year. ....can't be both...... | ||
| mstrug |
Expert 5K+ Posts: 6683 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Newark, Texas (Fort Worth) | Set of 16 NOS Mopar valve hydraulic tappets / lifters. These are all new old stock parts and fit big block engines and possibly some small block Mopar V8s. Check your parts books. Free shipping https://www.ebay.com/itm/127209363448?_skw=mopar+%281957%2C57%2C1958... $249 | ||
| mstrug |
Expert 5K+ Posts: 6683 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Newark, Texas (Fort Worth) | https://www.martinrobey.com/jensen/ff/mkii/engine/engine-internals/1... Tappet / Follower Set - Standard Size for Jensen Interceptor, FF, SP, Convertible, Coupe & C-V8 (383ci & 440ci Engines) £138.66 Ex | ||
| Mopar1 |
Expert Posts: 3158 ![]() ![]() ![]() ![]() ![]() Location: N.W. Fla. | wayfarer - 2025-07-24 12:44 PM You have to be tired before you can be retired...Steve, I completely understand the retired thing....most days I am just plain tired.... | ||
| wayfarer |
Elite Veteran Posts: 935 ![]() ![]() ![]() ![]() ![]() ![]() Location: Peoples Republic of Oregon | The only 'problem' with the Jensen listing is that I do not see any reference to year. Jensen started using the B&RB in 66 but continued for several years. | ||
| Steve1956 |
Veteran Posts: 139 ![]() ![]() | Well, the answer is I purchased a set of US Seal Co Lifters, P/N LIF8, and they checked out to be a perfect fit. They were a good price on ebay, so I am happy to have that dilemma solved. Thanks for everybody's contribution. | ||
