1956 Windsor water pump heater hose adapter source
Twotallkris34
Posted 2025-06-04 9:21 PM (#640309)
Subject: 1956 Windsor water pump heater hose adapter source
Hey All, recently had my water pump rebuilt for my 56 Windsor. The rebuilder only put one of the 90's for the heater hose back on. I am going to call to see if they have the one they left off it, but the ends are warn so I would like to replace them if I can. I have not been able to find them anywhere does anyone have a source? I believe there 90 degree 3/8male npt to 5/8 hose barb. Thanks.
Posted 2025-06-04 10:12 PM (#640311 - in reply to #640309)
Subject: Re: 1956 Windsor water pump heater hose adapter source
500050005002525
If you don't mind using a non-original part, McMaster will supply you with a brass one.
https://www.mcmaster.com/53525K22/
Part number ...K52 is a 45 degree version of the same thing.
