frame questionJump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forward Look NON-Technical Discussions -> 1955-1961 Forward Look MoPar General Discussion | Message format |
| w.weiland |
Expert Posts: 1563 ![]() ![]() ![]() ![]() Location: Lordstown, Ohio | i have someone wanting to buy a 57 custom royal 2 door frame from me. for there 58 fury. do they interchange if so something to show this guy that they do. he told me wheel base was different. but thats more than likely in spring perches???? | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11135 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Not sure of the fine details but it would appear that the 1957 Dodges had a 122 inch wheel base. https://www.lov2xlr8.no/brochures/dodge/57dg/bilder/4.jpg https://www.lov2xlr8.no/brochures/dodge/57dg1/bilder/8.jpg Whereas the 1958 (and probably 1957) Plymouth wheelbase was 118 inches. The only 58 Plymouths that had 122 inch wheel bases were the wagons (because the Plymouth, Dodge, and Desoto wagons ("suburbans") shared the same basic body, etc. ) https://www.lov2xlr8.no/brochures/plymouth/ply8/bilder/10.jpg All that said: 1. The start of Chapter 13 of the 1955-58 Parts book has several pages devoted to adapting one frame to another application. 2. Oddly, apparently, the 1957 Fury sat on a 122" wheel base but the 1958 Fury did not. It sat on a 118" wheel base. Go figure 1829 750 was the 122" wheelbase frame. 1829 948 was the 1958 Plymouth, non-suburban, non-convertible (everything else) frame. So my guess is, a clever person with an arc welder (aren't they all these days) and loads of skills and a bit of luck could adapt 122" Dodge frame to a 1958 Plymouth 118" wheelbase Fury. At least, that is what I *think* (I stand to be corrected by those with more knowledge) Edited by 56D500boy 2025-05-20 4:40 PM (57-58DodgeAndPlymouthWheelbases.jpg) (57-58DodgeAndPlymouthFramePNs.jpg) Attachments ---------------- 57-58DodgeAndPlymouthWheelbases.jpg (149KB - 322 downloads) 57-58DodgeAndPlymouthFramePNs.jpg (147KB - 289 downloads) | ||
| Finsinthemirror |
Elite Veteran Posts: 1165 ![]() ![]() ![]() ![]() Location: CA | I'm pretty sure the Dodges had the 122 in frames which won't work for the 118in Plymouth. He will need a Plymouth frame Wayne. | ||
| 58coupe |
Expert Posts: 1795 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Alaska | That must be a misprint, I have owned both 57 and 58 Furys and they are the same 118" wheelbase. That said, i believe the extra 4 inches of the Dodge frame are located in the area of the back seat and the front mount of the rear springs. it may be possible to shorten the frame there, Also I think the rear springs are longer on the Dodge because of this. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11135 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | 58coupe - 2025-05-21 7:57 AM That must be a misprint, I have owned both 57 and 58 Furys and they are the same 118" wheelbase. Some copy writer in the brochure department, named Lucy, apparently has got some of 'Splaining to do. https://media1.tenor.com/m/rHlzWpEWlIcAAAAC/oh-no-oh-my-god.gif The 1957 Fury Brochure does say 118 inches. (57FuryBrochureSpecPage.jpg) Attachments ---------------- 57FuryBrochureSpecPage.jpg (147KB - 331 downloads) | ||
| FinFury57 |
Elite Veteran Posts: 703 ![]() ![]() ![]() Location: Kangasala, Finland | That is a misprint. 1957 Fury has the same 118" wheelbase as rest of the 1957-58 non-suburban Plymouths. | ||
| mstrug |
Expert 5K+ Posts: 6691 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Newark, Texas (Fort Worth) | Agreed. the frame 4'' longer on the dodge. Hence; the longer fenders. There is a chart somewhere showing body mount distances. maybe in a mopar collision manual. I bet 4'' cut after the front wheels would be correct, but, check measurements. Might be in here: https://www.ebay.com/itm/300933040927 | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11135 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Turns out that I have previously posted these: 1957-58 Dodge frame: And 1957-58 Plymouth frames: REFERENCE Thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=70178 | ||
frame question
