Ignition Switch for 1958 Imperial
steffanf
Posted 2025-02-03 12:17 PM (#638789)
Subject: Ignition Switch for 1958 Imperial
What type of switch is used on 1958 Imperial models? It is a kind with 3 screw posts in the back or 4? Does it connect to the dash with a screw bezel or a set screw in the back? Does anyone have a part number?
-Gregg B.
Posted 2025-02-03 1:42 PM (#638791 - in reply to #638789)
Subject: RE: Ignition Switch for 1958 Imperial
500050001000100252525
Based on my previous investigations of Neutral Starting Switches, your 58 Imperial should have Neutral Starting as per this video:
https://www.youtube.com/watch?v=KJvJV8KyInM
If that is true, the electrical component of your ignition switch is a three terminal 1770 040 that is attached to the dash from the bottom by a set screw. There are several switches available from a variety of supplies on eBay:
https://www.ebay.ca/sch/i.html?_from=R40&_trksid=p3490034.m570.l1313...
REFERENCE THREAD: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=74501&...
