Generator ro Alternator swap
steffanf
Posted 2024-12-07 2:01 PM (#638108)
Subject: Generator ro Alternator swap
I'm thinking of swapping out my generator for an alternator. The engine is a '58 392 Hemi. What else would have to be swapped out in order to do this? Also, are there any advantages to even doing this swap?
-Gregg B.
Posted 2024-12-07 2:15 PM (#638109 - in reply to #638108)
Subject: Re: Generator ro Alternator swap
50005000500
If you don't have a lot of high power electronics in your car, there is no real advantage to doing this, other than saving a little weight. I run original generators on my old cars and don't have any issues with charging the battery or running the lights. If you do want to do the swap, you'll need a voltage regulator to work with it, and you'll need to bypass the original regulator on the fender.
When I installed an alternator that looked like a generator, it had the regulator built into it. So I just gutted the original regulator, removed the resistors underneath it & soldered thick wire jumpers inside it to make it work with the new alternator.
Edited by Powerflite 2024-12-07 2:18 PM
(300 Air Cleaners.jpg)
(Modified VReg2.jpg)
Attachments 300 Air Cleaners.jpg (229KB - 360 downloads)
Attachments Modified VReg2.jpg (127KB - 383 downloads)
steffanf
Posted 2024-12-07 3:01 PM (#638111 - in reply to #638109)
I plan on upgrading the headlights to something brighter, perhaps just halogens, using relays and a Putco harness. Also, I plan to change to a Pertronix electronic ignition. Would it be important to change to an Alternator with these modifications? Or does any of this matter either?
-Gregg B.
Edited by steffanf 2024-12-07 3:13 PM
Posted 2024-12-07 4:35 PM (#638113 - in reply to #638108)
50005000500
No, the difference is minimal. If you use LED's, they use even less electrical current than the Halogens. Also, the Pertronix might like the generator better because there is usually less electrical noise. I run electronic ignition on all my vehicles with generators & alternators.
steffanf
Posted 2024-12-07 5:55 PM (#638115 - in reply to #638108)
Awesome... thanks for the help. I will keep the generator then and see how everything goes.
Posted 2024-12-08 2:35 AM (#638121 - in reply to #638108)
5000500020001000100100
The generator works well, but long cruise in cities will drain the battery. If you plan to do mostly highway and country roads the generator will do well.
I used the generator for many yesrs, but changed to 50 amp alternator. Long road trips with wipers and heater fan, cruises was my reasons for the change.
