60 Plym A Arm bushings
Mopar1
Posted 2024-07-01 4:16 PM (#635932)
Subject: 60 Plym A Arm bushings
200010002525
Got upper A arm bushings from Rock Auto. Found a machine shop to do the swap. They took out the old ones & then discovered that the new ones were too big. Old ones have an O.D. of 15/16, the ones RA sent are 1 1/8th. Unless the factory mis-boxed, the parts I got what was supposed to fit. Dorman BC810149PR does anyone know if this is right size for the part number? mis-boxed? Leaves me dangling as to how to solve this. In my original search a parts house had them but the price for 1 was as much as for all 8 from RA. Plus if a mis-box how large is the problem......
Posted 2024-07-01 4:26 PM (#635934 - in reply to #635932)
Subject: Re: 60 Plym A Arm bushings
5000200020005001001001002525
The Chrysler/DeSoto use a larger bushing than Dodge/Plymouth. It sounds like you got the wrong part.
Shep
Posted 2024-07-01 4:28 PM (#635935 - in reply to #635932)
2000100010010010010025
Try this. https://www.facebook.com/PerformanceSuspensionTech/
Posted 2024-07-01 7:05 PM (#635936 - in reply to #635934)
50002000100100100100252525
Powerflite - 2024-07-01 4:26 PM
Maybe the 126" wb Chryslers, not the 122" wb Chryslers and all 60/61 Desotos used the same size as Plymouth and Dodge in 1960/61 too.
Mopar1
Posted 2024-07-01 11:15 PM (#635939 - in reply to #635936)
200010002525
All the refs seem to show the Dorman part as being right. I'll call them tomorrow.
Mopar1
Posted 2024-07-02 10:32 AM (#635941 - in reply to #635939)
200010002525
Dorman said they don't have one that's 15/16 O.D. The other dimensions are I.D. of 13mm & 60 mm width. Now what??
Posted 2024-07-02 11:40 AM (#635942 - in reply to #635941)
500050001002525
I believe the OE part number (PN) is 1825 317. A quick google on "1825317 Upper Bushing" shows up some NOS and aftermarket (TRW and Moog) options.
https://www.google.com/search?client=firefox-b-d&q=1825317+Upper+bus...
Rock Auto shows two options for 1825317
https://www.rockauto.com/en/partsearch/?partnum=1825317
(1960MoparFrontSuspension_PartsSectionPointers.jpg)
(1960MoparUpperControlArmBushingPN1825317.jpg)
(1960MoparUpperControlArmBushingPN1825317_Photo.jpg)
(1960MoparUpperControlArmBushingPN1825317_RockAutoDelphi.jpg)
(1960MoparUpperControlArmBushingPN1825317_RockAutoDorman.jpg)
Attachments 1960MoparFrontSuspension_PartsSectionPointers.jpg (105KB - 44 downloads)
Attachments 1960MoparUpperControlArmBushingPN1825317.jpg (142KB - 40 downloads)
Attachments 1960MoparUpperControlArmBushingPN1825317_Photo.jpg (61KB - 43 downloads)
Attachments 1960MoparUpperControlArmBushingPN1825317_RockAutoDelphi.jpg (135KB - 44 downloads)
Attachments 1960MoparUpperControlArmBushingPN1825317_RockAutoDorman.jpg (116KB - 46 downloads)
Posted 2024-07-02 6:08 PM (#635947 - in reply to #635941)
Mopar1 - 2024-07-02 10:32 AM
IIrc the outside diameter is 7/8", not 15/16". You can very easily make your own poly bushings using readily available leaf spring shackle bushings. That's what I did. That way you can leave the outer shell in the control arm.
Mopar1
Posted 2024-07-02 10:50 PM (#635953 - in reply to #635947)
200010002525
Didn't see the last 2 posts before I ordered from Bernbaum at work today. We'll see how this works out.
Posted 2024-07-02 11:05 PM (#635955 - in reply to #635932)
Bernbaum should be allright......unless it's run by someone else now, which is very possible by now. Ordered from him in the 80s
Shep
Posted 2024-07-03 8:20 AM (#635958 - in reply to #635955)
The new person running Birnbaum seems ok.
Posted 2024-07-03 7:51 PM (#635975 - in reply to #635932)
Outer diameter of the upper bushings for all 118" and 122" WB 60/61 Mopars is 1.1/8"
Mopar1
Posted 2024-07-04 10:58 AM (#635986 - in reply to #635975)
200010002525
1960fury - 2024-07-03 6:51 PM
Apparently mine is 15/16. One is original & one is a replacement from Big M.
Posted 2024-07-04 11:36 AM (#635988 - in reply to #635986)
Mopar1 - 2024-07-04 10:58 AM
You mean the outer shell, or the inside diameter of the hole in the control arm? If so, you UCAs are not OE anymore.
Just checked my 60 Fury, 60 Adventurer, 61 Fury and 59 Fury, all use the same type of bushings 1.1/8" outside diameter. The inside diameter of the outer shell is eyactly one inch.
Here is the key for an easy switch to POLY bushings. Go this route, you won't regret it.
Edited by 1960fury 2024-07-04 11:48 AM
Mopar1
Posted 2024-07-04 11:44 AM (#635996 - in reply to #635988)
200010002525
1960fury - 2024-07-04 10:36 AM
They ae original.. Dimensions are from the machine shop guy so I believe O.D. of the bushings.
Posted 2024-07-04 11:50 AM (#635998 - in reply to #635996)
Mopar1 - 2024-07-04 11:44 AM
Yeah, believe the machine shop guy and not someone who has 4 of these cars in the driveway and who restored these cars for 36 years..... good luck
Posted 2024-07-04 11:51 AM (#636000 - in reply to #635932)
in case you didn't read it:
Posted 2024-07-04 9:02 PM (#636020 - in reply to #635932)
500010005002525
1'' dia. poly... https://www.ebay.com/itm/386851575157?chn=ps&norover=1&mkevt=1&mkrid...
$13
Sold in Quantity
Pair
Color
Black
Material Type
Urethane
Notes
Enough for one spring eye.
Overall Length
1.42
Diameter Small End
1.00
Diameter Big End
1.32
Inside Diameter
.56
MFG. Part #
91043255
Polyurethane bushing set for Chrysler-type rear leaf spring eye. Accepts a 9/16" bolt. Overall length is 1-3/8" including the shoulder, which is 3/16".
One pair of these leaf spring bushings services one rear spring eye
Similar Items
See all
PROTHANE 4-801 MOPAR A-Body (60-76) Polyurethane Rear Spring Shackle Bushings
New
$16.99
Free shipping
Top Rated Plus
Seller with 99.1% positive feedback
For 1970-1976 Plymouth Duster Leaf Spring Shackle Kit Rear 77472NNGH 1974 1971
New
$68.00
Free shipping
Moog K6559 Leaf Spring Bushing - Rubber, Direct Fit
New
$14.68
Free shipping
Speedway 91043255 Polyurethane Pair of Chrysler/Pinto Leaf Spring Bushings
Universal Fit, 1.42" Overall Length, Black, Urethane
Edited by mstrug 2024-07-04 9:03 PM
Posted 2024-07-04 9:16 PM (#636022 - in reply to #635932)
500010005002525
https://metrommp.com/spring_and_shackle_bushing_1_bottom_od_bn_18/
Spring and Shackle Bushing. 1" bottom O.D -BN 18
Spring and Shackle Bushing. 1" bottom O.D. X 1-1/4" high, with 1/2" I.D. Each
Features
Made with high quality compounds to last for years
Manufactured with durability in mind.
Need expert help? We're available at1-800-878-2237 - Email us atmetrosales@metrommp.com
$9.96
SKU:
BN 18
UPC:
00642535219016
Unit Of Measure:
Each
Count:
1
Edited by mstrug 2024-07-04 9:18 PM
Mopar1
Posted 2024-07-04 10:56 PM (#636024 - in reply to #635998)
200010002525
1960fury - 2024-07-04 10:50 AM
Yeah, believe the machine shop guy and not someone who has 4 of these cars in the driveway and who restored these cars for 36 years..... good luck :)
The machine shop is an hour away, he said the 1 1/8 won't fit. That's all I got to go on at this point. When they come in I'll be going over.
Mopar1
Posted 2024-07-11 11:33 AM (#636126 - in reply to #636024)
200010002525
Went to the machine shop yesterday with the ones sent by Bernbaum. They fit, the ones that were supposed to fit are too big. It has since occurred to me that both A Arms are from Big M.
Mopar1
Posted 2024-07-13 10:44 PM (#636150 - in reply to #636126)
200010002525
What is the torque on the bushing bolts?
Posted 2024-07-14 12:59 AM (#636151 - in reply to #636150)
Subject: serRe: 60 Plym A Arm bushings
500050001002525
Mopar1 - 2024-07-13 7:44 PM
Should be in the factory service manual like these ones.
(57-58PlymouthFrontSuspensionTourques.jpg)
Attachments 57-58PlymouthFrontSuspensionTourques.jpg (229KB - 48 downloads)
Mopar1
Posted 2024-07-30 10:14 AM (#636327 - in reply to #636151)
200010002525
OK, you guys win! Big M sent the wrong A Arms. John has sent the right ones so I'll be getting back to making progress.
