60-62 unibody full size 4 door hardtop side window interchange
Posted 2024-06-13 9:09 PM (#635684)
Subject: 60-62 unibody full size 4 door hardtop side window interchange
500020005002525
Do they all interchange? Need a right rear door glass for a 60 Dodge Dart hardtop
Edited by 1960fury 2024-06-13 9:57 PM
Space Trukin Wagon
Posted 2024-06-14 12:04 PM (#635690 - in reply to #635684)
Subject: Re: 60-62 unibody full size 4 door hardtop side window interchange
From both researching master parts catalogs and comparing glass from cars over the years, to the best of my knowledge the following will interchange:
> 1960-61 Dodge Dart line and Plymouth interchange
The 1960-61 Dodge Matador/Polara, Chrysler, Desoto and ALL station wagons the Rear glass is different [longer] and only interchanges between those models. Therefore, does NOT interchange with the Dart line or Plymouth.
ONLY the Front door glass will interchange across every 4-door hardtop model.
The glass from 1962-64 Dodge 880 4-door hardtop models is the same dimension as the 60-61 Matador/Polara.
It will interchange with those models but there are differences with the mounting brackets or tracks that attaches to the glass.
Edited by Space Trukin Wagon 2024-06-14 12:07 PM
Posted 2024-06-14 6:14 PM (#635697 - in reply to #635684)
500020005002525
OK, thank you very much!
Posted 2024-06-14 11:24 PM (#635701 - in reply to #635684)
500020005002525
Weird about the 60 Dart/Polara,Matadore 4 d HT difference, since I'm pretty sure, 2 door hardtop glass interchanges between 118/122 wb.
