normsclassicradio![]() |
Extreme Veteran Posts: 310 ![]() ![]() ![]() Location: Kalispell, MT USA | OK, so WAY back in the early 70's, I helped my dad put a variable speed wiper motor and switch in my 64 880. They never parked, just turned off anywhere. Fast forward to last night. I was looking for the reason the reverse lights didn't work. I found that the wiper switch was not connected properly, and since the reverse lamps pick up power from the wiper switch side of the circuit breaker on the switch, I reconnected the wires correctly. Now I have reverse lights. And also the wipers park. In the UP position. Since the first arm on the motor isn't removable, how is this possible? Maybe the arm pivots are 180 out of position? The illustration in the service manual isn't very clear. Maybe someone had a late Exner car and can post a photo of how is is supposed to look? Norm | ||
mikes2nd![]() |
Expert 5K+ Posts: 5143 ![]() ![]() ![]() | Typically you'll adjust the wipers. Unless you arms are wrong. | ||
57chizler![]() |
Expert Posts: 3829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: NorCal | When in operation at any speed, is the arc of the wiper blades on the windshield correct? If so, the pivot isn't 180 out or the blades would try to drive into the cowl. When the blades park in the "UP" position do they always stop in the same place regardless of their position when the switch is turn to OFF? If they park in different up positions, you might need to adjust the Park switch in the wiper motor. | ||
mikes2nd![]() |
Expert 5K+ Posts: 5143 ![]() ![]() ![]() | here are the 57-59 arms... not sure if it helps https://www.youtube.com/watch?v=w_Ojdf79fDA | ||
mikes2nd![]() |
Expert 5K+ Posts: 5143 ![]() ![]() ![]() | the motor has the park mechanism... its going to stop... but you have to adjust your wipers so they are down when they stop. | ||
wizard![]() |
Board Moderator & Exner Expert 10K+ Posts: 13125 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | 57chizler - 2024-06-13 8:20 PM When in operation at any speed, is the arc of the wiper blades on the windshield correct? If so, the pivot isn't 180 out or the blades would try to drive into the cowl. When the blades park in the "UP" position do they always stop in the same place regardless of their position when the switch is turn to OFF? If they park in different up positions, you might need to adjust the Park switch in the wiper motor. How true | ||
Extreme Veteran Posts: 310 ![]() ![]() ![]() Location: Kalispell, MT USA | They always park up. I have to crawl back under the dash, but my thought was if the pivot arms are pointed the opposite direction than intended, it could cause this issue. But maybe there is only room to swing one direction. Maybe when I was 10 (in 1974) I got the links going to the wrong side. same outcome. I just have to get my somewhat larger self back under there and have a look. Edited by normsclassicradio 2024-06-14 6:03 PM | ||
Extreme Veteran Posts: 310 ![]() ![]() ![]() Location: Kalispell, MT USA | This last weekend I pulled the wiper motor and arm assembly The pivots and links can only be assembled one way, and are marked left and right. I used the FSM to set up jumper wires and test the motor. It always parked in the same place, 180 degrees off. I decided to remove the cover of the motor, and everything seemed ok. Then I removed the nut from the main shaft. Bingo! It has 2 flats and can be assembled 180 out of whack. So after reassembly now the wipers work properly for the first time since the 70's. Norm. PS, man my shoulders still hurt, not so easy to work under the dash at 60 years old compared to when I was 10... | ||
mikes2nd![]() |
Expert 5K+ Posts: 5143 ![]() ![]() ![]() | Yeah it had to be reversed... no other way it could do that. | ||
