FRONT DISC SWAP 64 880
normsclassicradio
Posted 2024-05-03 12:12 PM (#635002)
Subject: FRONT DISC SWAP 64 880
This swap should work on end of run forward look full size.
https://photos.app.goo.gl/rS5bR4A3G4MQTVQT9
Parts are readily available.
(resize parts list.jpg)
Attachments resize parts list.jpg (93KB - 416 downloads)
Shep
Posted 2024-05-03 2:27 PM (#635003 - in reply to #635002)
Subject: Re: FRONT DISC SWAP 64 880
20001000100100100100252525
Nicely done, will the stock wheels clear the calipers?
normsclassicradio
Posted 2024-05-03 3:13 PM (#635004 - in reply to #635002)
Subject: RE: FRONT DISC SWAP 64 880
The 15x5 wheels are too narrow, I had to use 1/4" spacers. I want to keep my big center caps. Later 15" wheels would clear fine. There is a company that makes custom sized Mopar wheels that take the larger cap. I also remember seeing on line someone had made little spacers to weld to the wheel to be able to use the larger caps. Maybe it was on here?
Edited by normsclassicradio 2024-05-03 3:15 PM
(back of wheel.jpg)
(wheel spacers.jpg)
Attachments back of wheel.jpg (60KB - 409 downloads)
Attachments wheel spacers.jpg (69KB - 383 downloads)
