torque converter stall speed?
dodge59
Posted 2023-06-08 6:26 PM (#630089)
Subject: torque converter stall speed?
1000
on the forwardlook  57-59   torqueflite A-466  cars  ...  what  converter stall speed (rpm) did they have ? did the poly engines  vs the bigblocks vary in stall  rpm speed?
Edited by dodge59 2023-06-08 6:33 PM
Posted 2023-06-10 1:58 PM (#630124 - in reply to #630089)
Subject: RE: torque converter stall speed?
200010005001001001002525
There is no set stall speed for any given converter, the more power you feed it the higher the stall speed will be...IOW, the same converter behind a 413 will stall higher than behind a 318.
Posted 2023-06-10 6:52 PM (#630134 - in reply to #630089)
Subject: Re: torque converter stall speed?
Torque converters have ratings as to their stall speed. 1800 rpm’s are common for MoPar factory installed units. Racing units are rated around 3500 rpm’s.
Shep
Posted 2023-06-10 7:03 PM (#630136 - in reply to #630134)
20001000100100100100252525
Also depends on whether the brakes can hold the car when power braking, we use an 8" block against the front wheels, but if the rear turns before maximum stall, you don't get an accurate number.
dodge59
Posted 2023-06-10 7:47 PM (#630137 - in reply to #630089)
1000
I remember reading somewhere on fwlk that the stall was 2100 rpms
57plybel
Posted 2023-06-12 10:23 PM (#630181 - in reply to #630089)
500252525
Interesting question, all I can add is that the powerflite converter is said to have an aprox 300rpm higher stall speed than the torqueflite  converter..... I plan to try this out for my next build.  It does appear to be smaller in diameter.
Colin
dodge59
Posted 2023-06-13 9:56 AM (#630187 - in reply to #630089)
1000
next question would be : is it best two refill converter with a couple quarts of oil before installing in the car or leave it dry to some extent ?
Shep
Posted 2023-06-13 10:19 AM (#630188 - in reply to #630187)
Yes, put some fluid in a dry convertor before installing.
dodge59
Posted 2023-06-13 7:34 PM (#630204 - in reply to #630089)
1000
Thanks everyone !
