16 inch wrist style wipers?
amlsml
Posted 2023-05-31 5:36 PM (#629914)
Subject: 16 inch wrist style wipers?
looking all over for a 16 inc wrist style wiper for my 60 phoenix. Ill even buy replacement rubber if possible. I could cut my arms and probably add a later push on style, thoughts?
(IMG_3119-Resize.jpg)
(IMG_3109-Resize.jpg)
Attachments IMG_3119-Resize.jpg (93KB - 24 downloads)
Attachments IMG_3109-Resize.jpg (140KB - 26 downloads)
Attachments IMG_3119-Resize.jpg (93KB - 25 downloads)
Old Ray
Posted 2023-05-31 7:41 PM (#629916 - in reply to #629914)
Subject: Re: 16 inch wrist style wipers?
500
I have new blades coming, will get back to you when they get here.
Posted 2023-05-31 9:22 PM (#629920 - in reply to #629914)
50002000200010010010010025
Just re-use the originals and replace the rubber. That's what I do and it works well.
amlsml
Posted 2023-05-31 11:31 PM (#629922 - in reply to #629914)
where did you get new rubber? I would reuse these, but can't find the correct rubber, thanks
60 dart
Posted 2023-05-31 11:47 PM (#629923 - in reply to #629920)
50002000100050010010010010025
Powerflite - 2023-05-31 9:22 PM
westaus29
Posted 2023-06-01 9:56 AM (#629932 - in reply to #629914)
I took my 55 rubber inserts down to Toyota and got replacements - last way longer than generic
chstrumpetdude
Posted 2023-06-01 12:34 PM (#629937 - in reply to #629914)
Toyota? I wonder what part#/supplier.
I ended up purchasing a set of the NAPA classics (look like cheap Tricos) They are really not that great, but the refill fit perfectly. They have a silvery paint coating and use an ugly plastic mount to the wiper arm on our clip types. The bayonet arms don't require this ugly plastic.
Anco used to have a refill that used a black plastic instead of the typical metal banding on the blade (U-16R); however, none are available anymore. You can get U-19R several places that should be able to be cut down I think and would be the next cheapest option. The cut to fit & adapting the U-19R would be the most economical. The easiest option is paying the $24ish per blade at NAPA and swapping blades onto the original wiper or ordering Trico classics.
My problem was that I had old U-16R'ss and those you can't modify with new generic blades due to the plastic mounts to the rubber blade. Now that I have the old school metal type refill, I can like order generic cut to fit strips.
Posted 2023-06-01 1:20 PM (#629941 - in reply to #629914)
You can get rubber/plastic refills from Ebay and Napa. It's not worth the cost to try to get the rubber/metal refills. You may need to bend the metal tangs of your blade holder in a little bit as the plastic is usually slightly more narrow. Order any oversize length and just cut to length. Usually you just need to turn the metal retaining clip around 180 degrees to make it work on our blade holders. After cutting, you can melt the end with a soldering iron to prevent the rubber from sliding out. Napa had a bunch of the older style refills that they put on clearance, and I bought a bunch of them - just any random length as most refills are longer than 16" anyway.
(Wiper Refills.jpg)
Attachments Wiper Refills.jpg (175KB - 21 downloads)
amlsml
Posted 2023-06-08 6:30 PM (#630090 - in reply to #629914)
found an Anco 13-16 refill on eBay, worked great. thanks!
NicksGarage
Posted 2023-06-09 1:40 PM (#630108 - in reply to #629914)
1000100252525
I refill mine using the rubber from Trico Classic ones.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=73909
