LS Intake on a Poly 318
Posted 2022-09-09 6:29 PM (#624125)
Subject: LS Intake on a Poly 318
50005000100100100252525
A guy in Australia is adapting an LS intake to be used on a poly 318. I wonder if something like this could be done with a new hemi intake. Bore spacing is probably the biggest factor to take into account.
(LS Intake on Poly 318.jpg)
(LS Intake on Poly 318 Back.jpg)
Attachments LS Intake on Poly 318.jpg (146KB - 436 downloads)
Attachments LS Intake on Poly 318 Back.jpg (173KB - 447 downloads)
Posted 2022-09-09 8:16 PM (#624126 - in reply to #624125)
Subject: RE: LS Intake on a Poly 318
50005000500100100252525
Powerflite - 2022-09-09 3:29 PM. Bore spacing is probably the biggest factor to take into account.
LS bore spacing is apparently 4.40" center to center
REFERENCE: https://www.onallcylinders.com/2017/10/12/ls1-engine-specs-performan...
Apparently (according to Willem Weertmann's book), the 318 poly bore spacing is 4.46". So pretty close.
Would be nice to see how a Gen III hemi intake would work.
60 dart
Posted 2022-09-09 11:46 PM (#624133 - in reply to #624125)
Subject: Re: LS Intake on a Poly 318
Expert 5K+ Passed away 30th Sept 2024. You will be missed Chuck!
5000200010005001001001001002525
machine an adapter , offset hold down bolts , porting and a lot more engineering--------------------------------later
PolyJ
Posted 2022-09-10 12:23 AM (#624134 - in reply to #624125)
The LS1 intake conversion was pioneered by Buck and Clark Hinkle on their 426 A-block (with LA short block) for the 2016 Engine Master Challenge. The LS1 runners are extremely close to where spacers and some slight porting adjustment works. The engine ended up putting out 552 HP @ 5,900 and 563 TQ @ 4,300.
The Gen III Hemi runner ports are substantially shorter than the A-block along with some velocity killing turns the adapter would need to negotiate to go from the Gen III Hemi runner angle to the A-block angle and to align with the A-block ports.
(LS1_adapter3.jpg)
Attachments LS1_adapter3.jpg (176KB - 433 downloads)
wayfarer
Posted 2022-09-15 1:35 PM (#624283 - in reply to #624125)
500100100100100
....given enough time and money anything is possible......
Posted 2024-07-16 8:45 PM (#636181 - in reply to #624125)
500010005001002525
Article: https://www.motortrend.com/how-to/426-cube-318-poly-can-outgun-hemis...
Mopar1
Posted 2024-07-21 11:28 AM (#636224 - in reply to #636181)
2000100010025
mstrug - 2024-07-16 7:45 PM
Article: https://www.motortrend.com/how-to/426-cube-318-poly-can-outgun-hemis... So it's not an A Poly, it's an LA with poly heads....bait & switch!
