1959 dodge cr 4 door hardtop rear back glass interior trims needed
dodge59
Posted 2022-09-04 6:05 PM (#624027)
Subject: 1959 dodge cr 4 door hardtop rear back glass interior trims needed
1000
searching  for the interior trim garnish painted trims  around the rear back glass on 59 dodge cr 4 drht. both horzontal trims by the top of the rear seat corners  and also the driver side curved vertical trim  .. see attachment.
(81706436_497543794220500_7683474988195643392_n.jpg)
Attachments 81706436_497543794220500_7683474988195643392_n.jpg (76KB - 49 downloads)
22mafeja
Posted 2022-09-05 12:43 AM (#624032 - in reply to #624027)
Subject: RE: 1959 dodge cr 4 door hardtop rear back glass interior trims needed
5001002525
Are you sure that the car had these parts from the factory? My Firedome 2d ht had no part like the green surrounded one. It was substituted with a wide lip on the glass seal.
dodge59
Posted 2022-09-05 10:01 AM (#624034 - in reply to #624027)
Subject: Re: 1959 dodge cr 4 door hardtop rear back glass interior trims needed
1000
Hi Ralf... That maybe because the 59 hardtops had the cardboard headliner .. interior garnish moldings had to cover up the edges where the board headliner edges stopped. I have had several 59 dodges over the years and the hardtops all had garnish trims around headliner and tops and sides of windshields frt and back .
dodge59
Posted 2022-09-05 10:09 AM (#624035 - in reply to #624027)
1000
Big M sent a pair of horizontal trims and they were to short in length so the 59 cr 4 hardtop is unique.
Posted 2022-09-05 10:17 AM (#624036 - in reply to #624027)
5000200020005001002525
I think I have these trim parts from my '57 New Yorker 4dr hardtop. Assuming that 23-64-66 is the right section in the parts book, they used the same part number for all Dodge, DeSoto, Chrysler in '57-'58. Plymouth was different for some reason. But the part number changed in '59 for some reason, so you might have to get them from a '59 Dodge, DeSoto, Chrysler only.
dodge59
Posted 2022-09-05 11:01 AM (#624037 - in reply to #624027)
1000
Nathan , 59 dodge had the big raised back glass so the interior vertical side trims were longer in length . but the horizontal trims by the corners of the rear seat should be the same a s long as it is a hardtop . here is a pic of a 59 coronet hardtop with raised back glass for reference .
john
(1959 dodge back glass trims inside.JPG)
Attachments 1959 dodge back glass trims inside.JPG (124KB - 53 downloads)
