Several '57-'59 Mopar originality questions
S. Bauer
Posted 2022-08-31 2:43 AM (#623937)
Subject: Several '57-'59 Mopar originality questions
New User
Hello ! I'm currently in the market for a MoPar fin car, and hope this is the right place to ask some questions concerning the originality of such vehicles.
First of all, a question about door latches and strikers: were they originally painted same color as the door jambs, Zink plated, or had any other type of finish ? What about the screws that hold the latches ?
One of the cars that I have interest in is a metallic green '57 Desoto Firesweep 2dr HT, which is... sufficiently DeLovely... for my taste )
The paint is old on this one, but looks like an older respray to me, because the door latches, strikers and some rubber plugs on door edges are painted body color (see picture). But maybe I'm wrong and that is how these cars came from factory ? The seller doesn't claim the paint to be original, but also doesn't state otherwise explicitly.
The information I could find so far is mutually contradicting - many restored cars have painted door lathes, but others seem to use Zink plating type finish on those parts.
Also, should the dashboard be painted body color, period, or it could use a diffrent type of paint from factory (e.g. - was painted separately from the body) ? On the car I've mentioned, the body is metallic green (incl. door jambs and all; seller claims it is Tamarack Green), but the face of the dashboard is non-metallic green of a much lighter shade (seems to be the case on other similar cars, as well).
Second question, on a '57 Dodge, what color the dashboard was typically painted ? I've found many cars with beige dashboards, either with black lower edge, or completely painted beige (picture no. 2). Sometimes nothing else is beige one these cars, either exterior or interior.
Was beige used as some kind of "one color fits all" finish to streamline aseembly line production etc., or this is just sloppy restoration with no regard to the original color scheme ?
Also, what types of pedals were used on '57 Dodges ? The car in my second picture seems to have what I think to be Plymouth pedals used with power brakes (the rubber pads are covered in circular "bumps").
I've also seen some cars with a radically different rubber pads featuring a more complex "ribbed" design. Which type is correct for a '57 Dodge - first, second, or maybe both ?
Edited by S. Bauer 2022-08-31 2:51 AM
(298644541_8191165637621183_1056314352904395487_n.jpg)
(74707_b4jkj9ila4ha0nd1aoakjstf9m_1620321073_2.jpg)
Attachments 298644541_8191165637621183_1056314352904395487_n.jpg (94KB - 48 downloads)
Attachments 74707_b4jkj9ila4ha0nd1aoakjstf9m_1620321073_2.jpg (259KB - 51 downloads)
Posted 2022-08-31 7:45 AM (#623939 - in reply to #623937)
Subject: Re: Several '57-'59 Mopar originality questions
50001000500
JC Auto can help you a lot. Yes those pedals look like Plymouth, 1957 and 1958 for sure, not sure if 1959 are the same. This link to jcauto shows the ribbed pedal pads: https://www.ebay.com/itm/252489583461?chn=ps&norover=1&mkevt=1&mkrid... his ebay store: https://www.ebay.com/sch/jcautorestoration/m.html?item=252489583461&... A look at a brake pedal: https://www.ebay.com/itm/372588105561 and a cheaper gas pedal: https://www.ebay.com/itm/362549409594?hash=item5469a0f73a:g:hSAAAOSw... As for dash colors, they are all over the place , my car is minty green and white, i think the dash and interior cloth is in a green hue. I see some came with a beige dash doing an internet search. Black dashes seem popular too. Some paint chip pages list interior colors. I you don't like beige dashes, just walk away, More '57 Dodges out there. Not sure about painted 'Latches' I don't think the concours judge would care. Dash colors may have been a by the factory thing also. Marc.
ToMopar
Posted 2022-08-31 7:50 AM (#623940 - in reply to #623937)
10001002525
what are you expect from an 60+ yrs old vehicle. Over the years something changes on that vehicles.
If you like an very original restored car instead, you pay $$$
ronbo97
Posted 2022-08-31 10:38 AM (#623942 - in reply to #623937)
Subject: RE: Several '57-'59 Mopar originality questions
2000200025
Yes, the latches, etc. were painted when the door was painted at the factory.
The dash was painted a different color from the body. The color of the dash will coordinate with the interior. There were certain interior colors that could be had with the exterior color of the car. For example, if you ordered a red car, you could get either a red/black interior or a 'neutral' interior, which was black and white.
Yes, those are Plymouth brake and gas pedals. Quirey Quality Design sells the correct molded pedals for 57-9 Dodge.
Ron
Posted 2022-08-31 12:34 PM (#623944 - in reply to #623937)
Welcome to the Forward Look!
Door hardware was painted body color at the factory for every original car I have ever seen. That would include latches, strikers, and screws - but not the rubber plugs in the door.
However, this would have been at the discretion of the assembly plant. I would not bet against at least one instance of a FL Mopar car body being painted without its hardware and then those parts assembled later. They assembly line controls in those days were not the same as they are today.
Some of your door plugs are painted body color and I would consider that a tip-off that it had been repainted; but it is unusual to see jambs and inner doors ever get repainted (unless there is a whole car color change involved).
Dashboards were painted to be complimentary to the rest of the interior. The off-white and black dashboard you showed is absolutely typical of an original car, and several interior codes probably used that same dash paint combination. Interior and exterior colors are not the same. The factory had suggestions for dealers about which interior codes to order with certain exterior colors, but in those days you could order basically anything you were willing to pay for.
As for the pedal pads, someone probably replaced those at some point. But again it's not out of the question that an assembly plant used whatever was available on-hand to get cars completed regardless if the part was "correct" for that specific make/model.
You're asking the right questions, but Mopar was not always 100% consistent across makes built in separate assembly plants. For example, some '57 Desotos will have gray inner fenders, some black. Both are correct, it just depends on where it was built. Have fun!
Edited by 57burb 2022-08-31 12:36 PM
