| Guys,
Would the rear glass trim from a 1955 Belvedere/Savoy fit the rear glass of a 1956 Belvedere/Savoy? I know that the Belvedere has different trim on the lower C pillar, but I'm assuming that the roofs and glass are the same for these two years.
Thanks |
Location: Branson, MO | Should be identical as long as the bodies are the same, 2 door, 4 door, etc.
Location: Lower Mainland BC | Viper Guy - 2022-08-24 9:02 AM
And hardtops are different than sedans, at least glass height-wise.
Location: Eastern Iowa | Reference the part numbers for each and see if they are the same is the best way. |
