Location: Northern Illinois | im in the process of converting my 55 dodge to a dual master cylinder. ran the brake lines, used the correct fittings and re routed the brake light switch. im having trouble finding a brake fitting for the distribution tee. the main line coming in i believe is 7/16-20 thread? i would like to use a tube nut, but it seems like the only ones i can find is for 1/4 inch tubing. im using 3/16 lines. any advice
Tony |
Location: So. Cal | There are a lot to choose from on Ebay. Here is one of them if your thread is 7/16-24. I don't remember now if it was a special 7/16-20 or not.
https://www.ebay.com/itm/224141621618
Edited by Powerflite 2022-05-10 12:02 PM
Location: Northern Illinois | hi nathan, yeah thats what i had bought (7/16-24) tube nut. the threads i have is 7/16-20. kind of difficult to find in a local part store. not much online either. the ones im finding are for 1/4 tubing. would like to keep it 3/16 if possible |
Location: So. Cal | I just confirmed that they are special 7/16-20 that I used on my cars. I purchased a 10 pack of them from Brake Hoses Unlimited on Ebay.
https://www.ebay.com/itm/331854508305
There are also 2 packs on Ebay if you search for them.
https://www.ebay.com/itm/232427313838
Location: Northern Illinois | just ordered them! thanks again!! |
