Disc Brake Conversion Master Cylinder Leaks
FINS!
Posted 2022-04-23 8:12 PM (#621051)
Subject: Disc Brake Conversion Master Cylinder Leaks
50010010010010025
Did front and rear disc brake conversion, a shop ran the lines and put in the new aftermarket booster. The master cylinder is leaking from the lid slightly when you apply the brakes (dripping down the front). Ideas? Am also getting a very pronounced squeak from the rear. This is a '57 Dodge
Shep
Posted 2022-04-24 11:00 AM (#621073 - in reply to #621051)
Subject: Re: Disc Brake Conversion Master Cylinder Leaks
20001000100100100252525
MC gasket not seating and possible overfill? Noise in rear needs further info.
Posted 2022-04-24 12:41 PM (#621076 - in reply to #621051)
5000
a pic would help
Posted 2022-04-24 5:25 PM (#621087 - in reply to #621051)
50002000100100100100
When I converted to dual, before the Internet, I did not bench bleed the MC and for a time it leaked from the lid. It stopped after a few 1000s. Maybe that was caused by not bench bleeding, but not sure.
