will long rams clear Magnum/hi flow exhaust manifolds?
goldencommando
Posted 2022-03-29 10:26 PM (#620592)
Subject: will long rams clear Magnum/hi flow exhaust manifolds?
Has anyone tried this? I would like to run 68-70 B or C body Magnum exhaust manifolds with long ram intake manifolds, but I am not sure if the height of the exhaust manifolds may interfere with the long rams.
If that is a no go, then what headers fit the 60-64 full size cars? Mine is the 122" wheelbase
Posted 2022-03-30 7:52 PM (#620604 - in reply to #620592)
Subject: Re: will long rams clear Magnum/hi flow exhaust manifolds?
It won't work, as you WILL need the heat riser system with the OE ram exhaust manifolds , unless it is just a show car or you live near the equator. You could fab/modifie headers to mimic the OE heat riser system.
goldencommando
Posted 2022-03-31 8:46 PM (#620635 - in reply to #620604)
I'm not concerned about the heat riser. My question is about clearance
finsruskw
Posted 2022-03-31 10:14 PM (#620641 - in reply to #620592)
2000100100100252525
Find a set of the 300J or ram K headers.
Thats what I have on my F.
wayfarer
Posted 2022-04-07 1:16 PM (#620780 - in reply to #620592)
50010010010010025
...but, will the intake runners clear....?
