58 plymouth horn not working after replacing shaft insulator Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
johnnybuick |
Veteran Posts: 147 | Hi fellow members.. After replacing the steering shaft plastic insulator between the steering box & steering shaft due to alot of dangerous play whilst driving. The horn now no-longer works. The original plastic insulator removed was decimated yet the small square copper shim that was stuck up against the outer side of the old insulator was still intact .. so i re-glued it onto the new insulator same position for easy insertion & i sanded clean the outer face of the shim to ensure it made contact with the shaft housing once inserted. After putting all back together horn failed to work. Is there any other way to now make the horn work without completely dis- assembling again ? Maybe make some sort of connection on the steering shaft between the steering wheel & indicator mechanism ? Will totally appreciate your efforts to help solve this problem. Thanks ! | ||
Expert 5K+ Posts: 5006 | nope have to tear it apart. there is a coper foil that connects the shaft to the wheel. Search "shaft insulator" and you might find pics. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | First of all, check with a ground wire from a good ground to the steering column (on a spot with good coontact) Otherwise you'll need to pull the steering column and insure a good ground. Below photos of a solution made by a member here. (Shaft&Groundwire.JPG) (Shaft@front.JPG) Attachments ---------------- Shaft&Groundwire.JPG (73KB - 113 downloads) Shaft@front.JPG (68KB - 107 downloads) | ||
ronbo97 |
Expert Posts: 4042 Location: Connecticut | Verify that the black wire that extends from the black horn button is still connected to the 'multi-connector' (for lack of a better term). You will have to pull the steering wheel in order to get to the button. Also, verify that the wire wasn't yanked from the button. It's a fragile design and this often happens. Ron | ||
johnnybuick |
Veteran Posts: 147 | Thankyou guys for your efforts.. forward looking must now go with some simplified forward thinking !! ..im looking at this hole i just discovered above the ignition & i have this switch that will fit nicely... im back baby !! (s-l1600 (1).jpg) (20220204_175207.jpg) Attachments ---------------- s-l1600 (1).jpg (106KB - 116 downloads) 20220204_175207.jpg (197KB - 106 downloads) | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Did the exact same thing on my 1960 Plymouth wagon. | ||
Expert 5K+ Posts: 7400 Location: northern germany | Here are the instructions I gave years ago along with a little trick to keep the insulatur alive a little longer with better steering feedback to boot: http://forwardlook.net/forums/forums/thread-view.asp?tid=71996&post... | ||
johnnybuick |
Veteran Posts: 147 | Tested the ol girl out today for the first time since replacing the insulator..& she drives like a dream..no play what-so- ever ! Like driving a different car .. gotta horn ? Right now, only to drive it some more !!! Edited by johnnybuick 2022-02-11 3:51 AM (20220211_191340.jpg) Attachments ---------------- 20220211_191340.jpg (146KB - 101 downloads) | ||
