Camshaft
Todd
Posted 2021-07-29 11:16 AM (#613877)
Subject: Camshaft
Hi folks.
1960 dodge dart 5,13 Lt (313 cui) / V8: does the engine has a "flat tapped" camshaft or not ?
thx a lot
Posted 2021-07-29 2:46 PM (#613885 - in reply to #613877)
Subject: Re: Camshaft
Flat tappet I believe is all the factory produced. Roller tappets are an after-market performance upgrade.
Posted 2021-07-29 4:05 PM (#613889 - in reply to #613877)
5000200020005001002525
If you mean solid lifters or hydraulic, it should be solid. But yeah, all cams were flat tappet until around 1985.
58coupe
Posted 2021-07-29 5:37 PM (#613892 - in reply to #613877)
100050010010025
Not exactly correct Nathan. The 59 Dodge with the 326 used hydraulic lifters. Since this was a one year only engine, not sure any other poly A engine used them.
You are correct that roller lifters were not used until 85.
Edited by 58coupe 2021-07-29 5:41 PM
Todd
Posted 2021-07-31 6:42 AM (#613912 - in reply to #613877)
Thanks @ all
