1957 341/345 water pump
springsweptwing
Posted 2021-04-24 7:24 AM (#611381)
Subject: 1957 341/345 water pump
100010025
Hi,
Looking for a water pump for a 1957 345ci engine, cannot seem to find any available, there are ones listed upto 1956 and just wondering if the only difference is the size of the spigot where the pulley fits?
If so I can swap that over
This is my type of pump with the shaft exposed where the pulley fits
Thanks Paul.
(images (6).jpg)
Attachments images (6).jpg (6KB - 157 downloads)
springsweptwing
Posted 2021-04-24 7:26 AM (#611382 - in reply to #611381)
Subject: RE: 1957 341/345 water pump
100010025
These are the ones available listed to fit a 341ci, but have a larger bore for the pulley?
(91015686_R_2e34f390-c12c-4edc-9fe3-65d172b4fd73.jpg)
Attachments 91015686_R_2e34f390-c12c-4edc-9fe3-65d172b4fd73.jpg (5KB - 157 downloads)
Posted 2021-04-24 12:37 PM (#611391 - in reply to #611382)
I think that your water pump was/is Part Number (PN) 1752 218, which looks like this (below):
Mopar Mall says that they can/will rebuild your pump for $$.
https://www.moparmall.com/Water-Pump-for-1955-1957-DeSoto-Hemi-Poly-...
REFERENCE (old for sale thread): http://www.forwardlook.net/forums/forums/thread-view.asp?tid=51560
Edited by 56D500boy 2021-04-24 12:38 PM
springsweptwing
Posted 2021-04-24 3:54 PM (#611401 - in reply to #611391)
100010025
Hi Dave,
I think the only difference is the hub that the pulley bolts to and I can get one of the larger hub for a third of the price, shipping and import duty ect
Thanks Paul.
Posted 2021-04-24 4:22 PM (#611403 - in reply to #611401)
springsweptwing - 2021-04-24 12:54 PM
The other critical details include the center to center spacing of the 4 mounting bolt holes. With the 55 and 56 Dodge V8s there are smaller and larger versions that look the same but the hole spacing is significantly different.
The last critical dimensions included the impeller diameter and the distance between the pump mounting flange and the pulley mounting flange (short nose or long nose??).
Hope it works out.
Edited by 56D500boy 2021-04-24 6:25 PM
NM Desoto
Posted 2021-04-24 5:38 PM (#611409 - in reply to #611381)
Subject: Re: 1957 341/345 water pump
The large pilot hub is for the '56 and earlier. The shaft and bearing assembly is the same. Being very careful, you can press the large hub off and install the '57 hub.
ToMopar
Posted 2021-04-26 4:54 AM (#611443 - in reply to #611381)
10001002525
Check out here: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=4110&p...
There are the size of the 341 pump
springsweptwing
Posted 2021-04-28 8:18 AM (#611493 - in reply to #611443)
100010025
OK thanks for replies, stripped mine and worn out inside, looks like easiest way is to buy the earlier pump and swap hub over ??
(IMG_20210425_202606_copy_1024x768.jpg)
(Screenshot_20210427_103616_com.ebay.mobile_edit_654633365301152.jpg)
(Screenshot_20210427_103658.jpg)
Attachments IMG_20210425_202606_copy_1024x768.jpg (231KB - 160 downloads)
Attachments Screenshot_20210427_103616_com.ebay.mobile_edit_654633365301152.jpg (80KB - 164 downloads)
Attachments Screenshot_20210427_103658.jpg (84KB - 157 downloads)
springsweptwing
Posted 2021-05-10 8:51 AM (#611865 - in reply to #611493)
100010025
Just a update on water pump, the new manufactured ones that kanter supply will not work with the other hub, the shaft is slightly small and I can just push the old hub on by hand, going to try machining the hub that came with the pump and see if that works.
