| Is there a commercially available connector that a fellow could use on the headlight pigtail. I could replace the wire to the headlights with one continuous wire without a connection but then that creates a problem if I want to pull the headlight bucket out for any reason. I can make a connector if I have to but some nice neat 2 prong plug would probably be cleaner.
Del S
(20201222_142933 2.jpg)
Attachments ---------------- 20201222_142933 2.jpg (60KB - 226 downloads)
Del: The factory provided for that eventuality/possibility by having a connector block on the firewall, right near the left head light. Two terminals for the headlight wires: one for the red wires and one for the black. No need for an extra connector (in my opinion):
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68378&...
Edited by 56D500boy 2020-12-29 9:15 PM
| That is my intent if I don’t come up with a decent connector. And it isn’t that difficult to pull the wires should I need to remove the complete bucket at some point. Just need a couple of grommets and done.
Del S |
Del if you really wanted a 2 pin connector, there are these:
https://www.amazon.ca/ZYTC-Waterproof-Electrical-Connector-Marine/dp...
And these:
https://www.amazon.ca/Sea-Dog-Polarized-Connector-2-Wire/dp/B000Y89T...
| Thanks, I have pico similar to first pic. Thought the maybe a bit large. I have it figured out using a piece of hose and shrink sleeve
Del
Edited by dels56 2021-01-02 2:25 PM
