Long Ram Carb question Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
jaded13640 |
Veteran Posts: 295 | We fired up the 62 Dodge today and I am not familiar with these carbs or how to set them up. I have a hard enough time with one carb. Now we have two? Yikes! I don't know what the big brass screw in the middle there even does. Any help would be greatly appreciated.. Wayne (center screw.jpg) Attachments ---------------- center screw.jpg (42KB - 195 downloads) | ||
Expert Posts: 3768 Location: NorCal | The brass screw is an air bleed, it controls the amount of air entering the carb at idle. Turning the screw counterclockwise allows more air in and will increase the idle speed. This is used in conjunction with with the fuel mixture screws to adjust the idle/low speed air/fuel mixture. | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | Here Ya go! Everything you need to know about setting up a pair of rams. 28 pages of it http://www.jholst.net/60-supplement/supplement.pdf Edited by finsruskw 2020-12-21 3:09 PM | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | Get a Uni-Syn carburetor balancer. https://amzn.to/34B1zwB You only need one as you adjust them one at a time. Make sure your linkage is properly adjusted first according to the document provided above. I made an adapter to fit the AFB using a 1 lb. cottage cheese container. Fits the top of the carburetor perfectly and I just cut a hole in the bottom to match the Uni-Syn. These also make good carb covers for when you're doing stuff under the hood with the air cleaner's off. (afb_cover2.jpg) Attachments ---------------- afb_cover2.jpg (165KB - 199 downloads) | ||
jaded13640 |
Veteran Posts: 295 | Well, I can see that I don't have an "anti-stall unit" as shown in the documentation. I wonder if it that's only necessary when you have A/C. We don't. Also, as for the uni sink tool. would two vacuum gages suffice? If not I'll buy the tool. My concern is that we have a .509 Purple Shaft in it. The old model .509. Mancini's tells me the old .509 and new .509 are all together different. That the new ones are way more street friendly. Ordinarily with that level of cam would provide very little if any vacuum at idle. That's why they needed those tanks that stored some vacuum or the power brakes wouldn't work. We don't have power brakes but I'm wondering if we'll see any vacuum signal at an idle? I kind of understand the central brass screw adjustment. Wayne | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | Even regular cars have vacuum reservoirs for the power brakes. Not a ram thing. The anti-stall is used on cars with or without A/C. The Uni-Syn should still work since it's using the air drawn in through the air horn and not a vacuum source. | ||
matt |
Veteran Posts: 143 Location: Malmberget, Sweden | Im from Sweden and cant see this page. Can anyone send me this pdf on my email? /Matt | ||
Expert 5K+ Posts: 9604 Location: So. Cal | Matt, you don't have your email listed on your profile. | ||
Expert 5K+ Posts: 9855 Location: Lower Mainland BC | matt - 2020-12-23 2:46 PM Im from Sweden and cant see this page. Can anyone send me this pdf on my email? /Matt Have look through the list of resources at this very helpful website (the pdf should be there): http://www.jholst.net/300resource/index.php | ||
matt |
Veteran Posts: 143 Location: Malmberget, Sweden | Powerflite - 2020-12-23 6:17 PM Matt, you don't have your email listed on your profile. Sorry. Now its | ||
Stroller |
Extreme Veteran Posts: 371 | With a meatier vacuum robing cam put on a hydro boost for the power brakes. Problem solved. | ||
