Dodge 325 coolant manifold needed
wheelcover
Posted 2020-12-13 7:02 PM (#606695)
Subject: Dodge 325 coolant manifold needed
I’m looking for a coolant manifold for a Dodge 325, maybe the same for a Dodge 315. Part number cast into the front passenger side arm of this manifold is 1733997. This is the piece that routes coolant from the water pump to the heads and block.
Posted 2020-12-13 7:54 PM (#606698 - in reply to #606695)
Subject: RE: Dodge 325 coolant manifold needed
500020002000500100100100100
wheelcover - 2020-12-13 4:02 PM
So Item 29 in the diagram below, except with the pentagon-shaped water pump opening as in the photo below the diagram (or does the 325 have two piece water manifold?)
(57D500_325_Front.jpg)
Attachments 57D500_325_Front.jpg (125KB - 119 downloads)
Posted 2020-12-13 8:35 PM (#606699 - in reply to #606695)
Subject: Re: Dodge 325 coolant manifold needed
5000200020005001002525
All 315 and 325 are one piece with the water pump housing.
big m
Posted 2020-12-14 11:28 AM (#606715 - in reply to #606695)
50002000500100100100
I have the water manifold available in good condition.
---John
wheelcover
Posted 2020-12-25 3:43 AM (#607088 - in reply to #606715)
I’m interested, I’ll send you a PM
