331 Hemi, oil on plugs?
1955NYer
Posted 2020-11-29 10:38 PM (#606187)
Subject: 331 Hemi, oil on plugs?
Hey everyone,
I was changing my spark plugs and there was oil on the plugs, not where the spark itself happens, but around the rest of it and around where I removed them. Oil on all 8. Is this normal? Never had any oil around the plugs before, then again this is my first time messing around with a vehicle this old.
58coupe
Posted 2020-11-30 1:10 AM (#606190 - in reply to #606187)
Subject: Re: 331 Hemi, oil on plugs?
100050010010025
That brings up several questions . How much do you drive and is it using oil? Oil on the plugs means it is burning oil which can come from worn rings or valve guides most likely.
1955NYer
Posted 2020-11-30 7:28 AM (#606191 - in reply to #606187)
It is driving zero. I run it for 5 minutes every other day.
Posted 2020-11-30 7:55 AM (#606192 - in reply to #606187)
500020002000500100
Completely normal for a hemi motor. There is oil that collects around the tubes and when you remove the plugs, that oil is released onto the plug as you pull it out. Hot Heads sells tube seals that will prevent this from happening, but you have to machine your heads to press fit them into it.
Posted 2020-11-30 10:47 AM (#606193 - in reply to #606187)
500050002000100025
That's what I thought as well, the tubes are held in place by the spark plugs. I noticed the same on a Hemi engine I was working on.....
Posted 2020-11-30 12:59 PM (#606196 - in reply to #606187)
Subject: RE: 331 Hemi, oil on plugs?
200010005001001002525
They make these to solve that problem but they've never worked for me.
https://www.jegs.com/i/Milodon/697/27050/10002/-1?gclid=EAIaIQobChMI...
1955NYer
Posted 2020-12-01 12:36 AM (#606206 - in reply to #606187)
Awesome. Thank you for the detail. I appreciate it!
