I am thinking converting my "accordian" power brake booster system to a more contemporary system when I switch from single master cylinder to dual (drum/drum) master cylinder (MC). I have the photo below of another (different) 56 Dodge that has had its power brake system updated stored in my "Brake Info" folder. But I don't know the booster they used.
I like the booster in the photo because it is flat(ish) to the firewall and it looks very factory, albeit after 1961.
I know that to achieve this conversion, I will have to change the brake pedal system (I am working with Big M on this). I just need to figure out what booster to use. I already have the MC.
Anybody?
Edited by 56D500boy 2020-11-21 6:19 AM
(56DodgeWagonWithPowerBrakeConversion_small.jpg)
Attachments ---------------- 56DodgeWagonWithPowerBrakeConversion_small.jpg (144KB - 212 downloads)
Location: Kansas City, KS | Looks like a common 1967 and up Chrysler booster, same for the master cylinder too.
Try searching for Cardone 54-73520 |
Location: Lower Mainland BC | KcImperial - 2020-11-21 6:49 AM
Thanks Don. I think you are right. Thanks very much:
Power Brake Booster-Vacuum Cardone 54-73520 Reman
1968 Chrysler 300 Base 7.2L 7211CC 440Cu. In. V8 GAS OHV Naturally Aspirated
Diaphragm Diameter: 9.125 IN (Not sure if that is the canister or just the diaphragm) Probably will need a 1" spacer to clear the heater box on the firewall
Edited by 56D500boy 2020-11-21 12:40 PM
Location: So. Cal | If you swap it out, send the unused parts to me please. |
Location: Lower Mainland BC | Powerflite - 2020-11-21 9:17 AM
Sorry Nathan. Everything that I remove/change on my car, stays with the car, for its next caretaker. (Who might like accordions, etc.)
