removing intermediate shaft on 413
59Imp
Posted 2020-10-06 4:30 PM (#604089)
Subject: removing intermediate shaft on 413
New User
I am trying to bring a 59 Imperial back to life; has been sitting inside for 40 years. Trying to remove intermediate shaft to gain access to oil pump for priming. Shaft comes up about 2 inches and is free of the cam gear but will go no further. Any ideas would be appreciated. Thank You.
Posted 2020-10-06 5:21 PM (#604092 - in reply to #604089)
Subject: Re: removing intermediate shaft on 413
50002000100100100100
I know that, there is residue on the shaft. Pull the shaft up as much as possible and try to spray penetrating oil on the shaft, then work up and down and repeat but it is probably better to remove the oil pump (very easy) and spray the shaft from below. Eventually you will get it out but do not force, as this can work the bushing loose.
59Imp
Posted 2020-10-08 10:54 AM (#604183 - in reply to #604092)
New User
Thanks; I will try that.
58coupe
Posted 2020-10-08 11:41 AM (#604186 - in reply to #604089)
100050010010025
If you don't get the shaft out, pull all the spark plugs so there is no load on the bearings which should be done anyway and add some light oil into each cylinder. as Sid said it is pretty easy to get to the oil pump from outside the engine.
Posted 2020-10-08 4:07 PM (#604198 - in reply to #604186)
58coupe - 2020-10-08 11:41 AM
Very good advice also heat the oil (pan).
BTW, I like your precautions starting the engine. This is how it must be done. I've seen it countless times, people pouring gas into an engine that hasn't been started for ages even with the old oil still in the pan. This has destroyed many good engines or put the equivalent of wear of 100+K miles on the engine in just a few seconds. You can watch the "Will it start?" vids on YT. Very depressing.
