1957 plymouth vacuum check valve
ply57nz
Posted 2020-09-28 1:10 AM (#603680)
Subject: 1957 plymouth vacuum check valve
Are the check valves for the brake vacuum tank on a 57 plymouth still available or is there a kit to rebuild them. Any help greatly appreciated
Posted 2020-09-28 12:30 PM (#603693 - in reply to #603680)
Subject: RE: 1957 plymouth vacuum check valve
200010005001001002525
Part number is 1672436, try the NOS vendors.
ply57nz
Posted 2020-09-28 2:23 PM (#603697 - in reply to #603693)
Subject: Re: 1957 plymouth vacuum check valve
Thanks for the part number, will give that a try.
Posted 2020-09-29 1:39 PM (#603751 - in reply to #603693)
57chizler - 2020-09-28 9:30 AM
Not 100% sure whether 1672 436 is the correct Check Valve assembly but if it is, there is a spring 1674 996 and a valve 1674 995 that could potentially be replaced:
Edited by 56D500boy 2020-09-29 2:24 PM
(55-58PowerBrakeBoosterTypesAndPNs.jpg)
(55-58PowerBrakeVacuumCheckValvePNs.jpg)
Attachments 55-58PowerBrakeBoosterTypesAndPNs.jpg (189KB - 221 downloads)
Attachments 55-58PowerBrakeVacuumCheckValvePNs.jpg (196KB - 225 downloads)
ply57nz
Posted 2020-10-01 12:48 AM (#603826 - in reply to #603680)
Might try getting the inner resurfaced as it has a bit of pitting and might try making a new spring for it as well. See if that works while I look for another
