Two Four Barrel Big Block Manifold for sale Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - PARTS | Message format |
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | I have the original Cast Iron Two 4 Barrel carb manifold that was on my 59 Dodge when I bought it. The manifold was on a 400 "Big Block" engine. It should fit a 383, 400, 413, 426 and 440 motors' I also have 3 Carter AFB cars for that manifold. PM me if your are interested and make an offer. Gary | ||
StillOutThere |
Location: Under the X in Texas | And the casting number is ___________? | ||
matador440 |
Elite Veteran Posts: 690 Location: BELTSVILLE, MARYLAND 20705 | If it was on a 383 or 400 It will not fit a 413 or a 426 or a 440 .. They are different engine blocks | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | I will try to get the casting # off the manifold and carbs, tomorrow. Yes the manifold came off a 400 engine. Gary | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | Here is the manifold and carbs for sale on Ebay. https://www.ebay.com/p/1542212974?iid=303558568942&chn=ps&norover=1&... Gary | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | ok the part number on the manifold is 1827899. Here is the exact same one on ebay for sale with the carbs. https://www.ebay.com/p/1633147939 one of my AFB carbs has the number 2c4 9836S the 4 digit # on that carb is 2770.This carb has the electric heated choke. The other carb has the part # 88 98265 and the 4 digit # is 2312. I will post pictures later Gary | ||
Expert 5K+ Posts: 9654 Location: So. Cal | Are you living in Tulsa, OK now? That's what the ad says. | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | ok, here are some pictures. I am also selling the original distributor for my 1964 Dodge Polara 500 that has the 426 wedge engine. The distributor was the dual point "Prestolite" (I think). It has been converted to To the Electronic pickoff. Vary rare if you goggle it! Tag says 3690432. Again just give me a bid for any of the items you want. Here are the pictures: | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | ok, here are some pictures. I am also selling the original distributor for my 1964 Dodge Polara 500 that has the 426 wedge engine. The distributor was the dual point "Prestolite" (I think). It has been converted to To the Electronic pickoff. Vary rare if you goggle it! Tag says 3690432. Again just give me a bid for any of the items you want. Here are the pictures: (Mopar two four barrel carb manifold 1827899 smallest-crop.jpg) (Carb Carter AFB 2770 electric choke smallest-crop.jpg) (Carb carter afb 2312 No choke smallest-crop.jpg) (Distributor 1964 Dodge 426 wedge converted to Electronic smallest-crop.jpg) (Distributor 1964 Dodge 426 wedge converted to Electronic Tag smallest.jpg) Attachments ---------------- Mopar two four barrel carb manifold 1827899 smallest-crop.jpg (211KB - 176 downloads) Carb Carter AFB 2770 electric choke smallest-crop.jpg (240KB - 176 downloads) Carb carter afb 2312 No choke smallest-crop.jpg (234KB - 171 downloads) Distributor 1964 Dodge 426 wedge converted to Electronic smallest-crop.jpg (235KB - 173 downloads) Distributor 1964 Dodge 426 wedge converted to Electronic Tag smallest.jpg (209KB - 176 downloads) | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | I'm still in "The Peoples Republic of California" same place Yorba Linda. I put that ebay post up for folks that want more info on the intake manifold. Also what "some folks" think that manifold and carbs are worth. I'm not looking for near that much money, just a "reasonable offer" That was NOT my post on Ebay. I wanted to give the folks on The Forward Look first shot at these parts. They are NOT listed anywhere else for sale. Gary | ||
Expert 5K+ Posts: 9654 Location: So. Cal | Your carb numbers need clarification. The casting numbers don't matter, only the stamped number on the base of them matters. A 2770 number doesn't exist. Look and see if there is something else or if you made a mistake reading it. A 2312 number also doesn't exist, but there is a 2812 for a '59 Plymouth 318 car. | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | ok Here are the numbers on the base of the carbs. You were right that I did not quite read the numbers right (Carter AFB # on base 1.jpg) (Carter AFB base # 2.jpg) Attachments ---------------- Carter AFB # on base 1.jpg (175KB - 173 downloads) Carter AFB base # 2.jpg (222KB - 176 downloads) | ||
Expert 5K+ Posts: 9654 Location: So. Cal | Yeah, those are the right numbers. 9626S and 9636S are both Carter aftermarket carburetors with 625 CFM. | ||
