Single circuit to dual circuit Jump to page : 1 2 3 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Todd, is the new dual circuit m/c for disc/drum or disc/disc? The disc normally have a residual valve of roundabout 2 lb, while drums should be 10 lb. I'm not sure that new residual valves is the solution, but if the ones you have in the m/c now ar 2 lb in both ports, then this is part of the problem. | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | . This sounds like a situation I had when I first started driving, in a 55 Dodge, back in 1967. The brakes were "fine" (as long as you pumped them a couple of times). *HOWEVER* if, after pumping the brakes up, you kept your foot on the pedal, the pedal very slowly sank to the floor. I had no clue. I was 16 and had not done much work on a car. But my dad who was very mechanically inclined knew what the issue was so I bought a MC repair kit and after we removed the MC, he instructed me on the replacement of the "cup"/seal at the front of the piston. It had a nick in it (or it was just worn -I don't recall). I lightly sanded the piston bore with fine (800 grit) sand paper, replaced the cup (and the other bits that came in the kit) and everything was good. So it sounds (to me) like your problem is that there is a piston cup/seal (or piston bore) issue. Edited by 56D500boy 2020-12-01 2:22 PM | ||
Todd |
Veteran Posts: 147 | Sven: It's a drum / drum dual master; https://www.ebay.de/itm/1960s-Mopar-Drum-Brake-2660809-BENDIX-Master... 56D500boy: as i wrote, the new master seemed to be ok, cause he has pressure when you plug the ports and try to stroke the piston, so much pressure that you are not able to stroke the piston. Edited by Todd 2020-12-01 12:22 PM | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | So Todd , you 've confirmed that the circuit in the car is ok by reinstalling the old m/c and you've confirmed that the new m/c is ok by plugging the ports. That leaves only the diameter and stroke differences. | ||
Todd |
Veteran Posts: 147 | YES - I came to the same conclusion. It can only be due to the piston that is too small. | ||
Expert 5K+ Posts: 9654 Location: So. Cal | ...or a problem with the connections from the master to the rest of the system. | ||
Todd |
Veteran Posts: 147 | How do you mean that exactly? | ||
Expert 5K+ Posts: 9654 Location: So. Cal | I have used smaller masters before and they do allow a lot more travel, but they have always developed pressure in the system. I know that Neil and other people have used that master successfully as well. So I tend to think there is something else that is the real problem. You have 4 connections & one plug that are different when you swap to the single circuit master. I have personally found that the plugs that are sold don't seal well so that would be my first guess as to where the problem lies. Those plugs also can damage the distribution block if you tighten them a lot because they aren't made to seal the same as the line. To plug the port, I always take a line (with a connector on it), cut it short, weld the end of the line shut, and then braze a coating of brass over the top of it to ensure it is sealed. You also have a union at the rear brake line. Sometimes those can come loose if you don't tighten them properly so it could be worth checking. But I agree with your sentiment to retain the single master with the drums. I don't think the small safety factor with the dual is worth the effort for an original system. Neil ultimately felt the same way about it. (39900287dz.jpg) Attachments ---------------- 39900287dz.jpg (147KB - 226 downloads) | ||
Todd |
Veteran Posts: 147 | New thought: A disc / drum master with the large bore should work if a 10 lb residual valve is installed for the disc port brake line at the front. Any concerns? Disc/drum masters with 1.125" bore are easy to get. Edited by Todd 2020-12-02 4:02 AM | ||
Todd |
Veteran Posts: 147 | This one has 1.125" bore, residual 10lb for rear port almost built in, and able to mount directly to firewall w/o any adapter: https://www.ebay.com/itm/1966-1970-Mopar-Bendix-Style-Manual-Disc-Dr... | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Hypothetically yes Todd. The disc/drum mc displacement must be close to the oem mc | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | Are you bleeding the brakes by yourself or are you having someone pump the brakes while you bleed off at the wheels while they are pushing down. I have always been able to get a better bleed when I have my wife push down the brake pedal. The step is to push down the brake pedal until you get some pressure. Once you have pressure, bleed out the wheel cylinder until the brake pedal goes almost all the way down, but not all the way down, and then close the bleeder at the wheel before the pedal hits bottom. This way you always have a positive pressure in the brake system when you open a wheel cylinder bleeder. You are trying to never have less than positive pressure when any bleeder is open. You have to do this a bunch of times at each wheel but if you do it right, you never suck air back in at the wheel cylinder. Every time I try to bleed to a bottle, I don't get as good a bleed. It just sounds to me like you still have a lot of air in the system. It is hard to troubleshoot without being there but sounds to me like just still a lot of air in the system. It doesn't take much air to make the brakes not work at all. | ||
Todd |
Veteran Posts: 147 | No i have no air in the system because the old master works perfect as always as i wrote - very good pedal pressure. I always use a one-way bleeder valve when bleeding. No chance to suck air back in the system when bleeding. Edited by Todd 2020-12-02 6:49 AM | ||
Expert 5K+ Posts: 9654 Location: So. Cal | I just made a plug for my '56 Fury yesterday. This is what it looks like. The '55-'56 uses a non-standard thread size (7/16-20 instead of 7/16-24) at the top port so I am waiting to receive tube nuts for it before I can finish it. (56Fury White Brake Plug.jpg) Attachments ---------------- 56Fury White Brake Plug.jpg (111KB - 219 downloads) | ||
Todd |
Veteran Posts: 147 | Wow looks pretty nice!! | ||
Expert 5K+ Posts: 7395 Location: northern germany | Something doesn't make sense here. You mean even if you pump, the pedal stays soft or sinks to the floor? That means the reservoir is empy then and the MC sucks air? | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Powerflite - 2020-12-02 9:03 AM I just made a plug for my '56 Fury yesterday. This is what it looks like. The '55-'56 uses a non-standard thread size (7/16-20 instead of 7/16-24) at the top port so I am waiting to receive tube nuts for it before I can finish it. Nathan: I like what you've done but I can't weld (no equipment/skills, etc) so I would need a non-welding option. Wouldn't something like this Edelmann Union Tee work for the distribution of pressurized brake fluid to the front brakes? (EdelmannUnionTeeDetails.jpg) Attachments ---------------- EdelmannUnionTeeDetails.jpg (105KB - 214 downloads) | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | I understand what you are saying. The wheel cylinders need more fluid than is available from the master cylinder to make the shoes contact the drums. By the time your brake pedal hits the floor, you still have not pumped enough fluid from the master cylinder to move the brake shoes to the drums. So, you need more fluid displacement from your new master cylinder. Fluid displacement is diameter of the cylinder times distance of the stroke. Your original master cylinder must displace more fluid than the new one so why would this be? If you look at the schematic above that Dave posted that shows how dual master cylinders work, you see the fluid intake and return ports. Fluid displacement to the wheel cylinders doesn't start until the cup is past this port and pushing toward the wheel cylinders. Is it possible that the preload from your brake pedal on your new master cylinder is different than the original. If on your new master cylinder, the plunger is a long way back from this fluid intake and return port, you will use up a lot of your pedal travel before you start moving fluid to the wheel cylinders. Your original wheel cylinder is probably set up so this port covers much earlier than on your new one. Is there a way to adjust the length of the stroke on the new master cylinder. If you adjust your brake drums tight so that you have drag, that might solve the problem because it will take less fluid to make the shoes hit the drums. But it creates the new problem of drag on the wheels, heating up the drums, and wearing out your brake shoes early. It seems to me like a residual valve would make the shoes stay close to the drum just the same way as adjusting the shoes close to the drums. I'm not sure I see much difference in the benefit of the residual valve versus just adjusting your brakes tighter. The real issue is that your new master cylinder is not displacing enough fluid to move the wheel cylinders far enough so that the shoes contact the drums. If your new master cylinder pumps up tight when it is operated when it is plugged off, and the OEM wheel cylinder will pump enough fluid to make the shoes touch the drum, then the only thing that can be wrong is that the new wheel cylinder is not displacing as much fluid as the original wheel cylinder. Why is this? That's all you need to figure out. You can't have any leaks or the OEM would not work, and you would see the leaks. This is just a fluid displacement issue. Anyway, just my two cents worth. | ||
Expert 5K+ Posts: 7395 Location: northern germany | 56D500boy - 2020-12-02 5:02 PM Nathan: I like what you've done but I can't weld (no equipment/skills, etc) so I would need a non-welding option. Wouldn't something like this Edelmann Union Tee work for the distribution of pressurized brake fluid to the front brakes? You actually only need a bolt, 7/16-20 or -24. To not just rely just on teflon tape (which ich actually 100% safe) you could "machine" the end of the bolt that faces the inside (which is easily done with a simple drill and angle grinder) so it seals at the sharp edge of the inside cone too. | ||
Expert 5K+ Posts: 9654 Location: So. Cal | Interesting idea about machining your own 45 degree cone to seal as a plug, Sid. The one at the bottom is 3/8-24. Dave, the tee you show will work, just won't be mounted like the factory one and routing will be different. | ||
Expert 5K+ Posts: 7395 Location: northern germany | Powerflite - 2020-12-02 7:34 PM Interesting idea about machining your own 45 degree cone to seal as a plug, Sid. It is surprisingly accurate if the bolt is spinning fast in a drill and you shape it with an angle grinder. I even modified an AN fitting adapter from 37° to 45° on one side, when I made my own PS pressure line with steel to braided teflon line. Works great. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | So, since this got me curious I went out and checked some spare parts and came to some conclusions; The oem master cylinder has a diameter of 1-1/8" (28,575mm) and a maximum stroke of approximately 1.150" (29mm), supplying a displacement of 18,6 cm³ The oem wheel cylinder has a diameter of 1-1/8" (28,575mm) Ratio 1:1 This means that if the m/c piston is pressed in "full stroke", the 6 wheel cylinder pistons will move 4,8mm each outwards. So, lets assume that the stroke is the same in the "new" dual circuit cylinder; Master cylinder diameter 1" (25,4mm), maximum stroke approximately 1.150 (29mm) supplying a displacement of 14,7 cm³ The oem wheel cylinder has a diameter of 1-1/8" (28,575mm) Ratio 1:075 Hypothetically, this means that if the m/c piston is pressed in "full stroke" 6 wheel cylinder pistons will move 25% less, approximately 3,7mm each outwards. So, with the same stroke/displacement it might work, but always with a very low pedal. Perhaps someone better than me in mathematics could correct my theory here? | ||
Todd |
Veteran Posts: 147 | Thank you for your effort Sven. That reveals the biggest problem: one stroke of the dual master is not enough to move the wheel brake cylinders. In my case, a very slight braking effect only occurs when the pedal is completely on the floor. And I mean completly on the floor. This master ist not suitable. My options: try a 1,125 dual master for disc/drum, or enjoy the OE master with new brake lines. I think I'll take the second solution. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | You're welcome Todd. If you go for the oem m/c, please do the following; - Remove all wheel cylinders, wash them good and inspect the bores and rubber parts. Any flaw means new stuff. - Clean and inspect the m/c, even more important, there must be no rust pits in the bore. - Flush the brake lines with alcohol. - Inspect the brake hoses and change them at any flaw detected. - Inspect all the brake lines for any wear or rust. If you need to change, use ONLY steel or copper/nickel lines, stay away from copper as it's not safe for vibrations and very easily micro cracks can occure during the coning. Do the above with scrutiny and do not accept any flaw. Now you have to chose the brake fluid, I can recommend DOT5, synthetic even at a much higher cost since there will be no rusty parts. You can paint your m/c without risk of having a grim result after spillage. If you do all the above, you will have an as safe as possibe single circuit brake system, this is what I did. Since you have manual brakes, it should be fairly simple to add a small float with a switch for low level warning on the m/c. You should be able to get some ideas as for parts to use from a scrap yard. The other option far as I understand is to go "all in" like Sid did, open up your wallet and get a Wilwood dual circuit brake system. Mind that many kits on the market uses Mustang parts, suitable for the low vehicle weight, but not for heavier cars. | ||
Expert 5K+ Posts: 7395 Location: northern germany | wizard - 2020-12-03 3:05 AM So, since this got me curious I went out and checked some spare parts and came to some conclusions; The oem master cylinder has a diameter of 1-1/8" (28,575mm) and a maximum stroke of approximately 1.150" (29mm), supplying a displacement of 18,6 cm³ The oem wheel cylinder has a diameter of 1-1/8" (28,575mm) Ratio 1:1 This means that if the m/c piston is pressed in "full stroke", the 6 wheel cylinder pistons will move 4,8mm each outwards. So, lets assume that the stroke is the same in the "new" dual circuit cylinder; Master cylinder diameter 1" (25,4mm), maximum stroke approximately 1.150 (29mm) supplying a displacement of 14,7 cm³ The oem wheel cylinder has a diameter of 1-1/8" (28,575mm) Ratio 1:075 Hypothetically, this means that if the m/c piston is pressed in "full stroke" 6 wheel cylinder pistons will move 25% less, approximately 3,7mm each outwards. So, with the same stroke/displacement it might work, but always with a very low pedal. Perhaps someone better than me in mathematics could correct my theory here? Just simpler. If you take the same stroke, and the wheel cylinders remain the same, it is just 1.1/8" bore VS 1" bore that you need to know that the movement will be less.... then again, the dual MC has 2 pistons....? | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | The two pistons are agood part ofthe problem Sid. I imagine that the "new" m/c is n for 4 cylinders, 2 front and 2 rear and with lesser diameter, let's say 1". That would be just fine as the displacement of the stroke will give the same portion to front and rear. Now, if the "new" m/ c is mounted in a Car with 6 cylinders, it's a problem, since One port must supply 4 cylinders and the other port only 2. Most probably it's the rear cylinders Todd is giving some resistance/brake from on the End of the pedal travel as the front once would not move sufficiantly with the same portion of fluid. | ||
Expert 5K+ Posts: 7395 Location: northern germany | wizard - 2020-12-03 11:49 AM The two pistons are agood part ofthe problem Sid. I imagine that the "new" m/c is n for 4 cylinders, 2 front and 2 rear and with lesser diameter, let's say 1". That would be just fine as the displacement of the stroke will give the same portion to front and rear. Now, if the "new" m/ c is mounted in a Car with 6 cylinders, it's a problem, since One port must supply 4 cylinders and the other port only 2. Is the number of wheel cylinders of importance and not the number/diameter of the pistons/bore? It is the pistons that needs to move regardless where it is installed. There are 4 pistons in the rear and 4 in front. | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | I have learned a lot about brake systems because of this thread. And I apologize for adding confusion. I didn't know anything about residual valves so I studied them and have included two links I thought were interesting. I can now see several advantages of using these valves and they are inexpensive and easy to install. I think newer style master cylinders might have these residual valves already installed in the outlet nozzles on the master cylinder. Sevn's calculation of the volume of a stroke on the master cylinder is interesting because it shows that a lot of volume is lost when you reduce the diameter of the bore from 1.125 inches to 1.000 inches. 1/8 of an inch doesn't seem like much but it reduces the volume more than you would think. I searched Rock Auto for a while and couldn't find any Dodge dual cylinder master cylinders with 1 1/8 inch bores. Cardone does offer a rebuild service that says their rebuilt cylinders have 1 1/8 inch bores. If this is really correct, I wonder if they just bore out old wheel cylinders to 1 1/8 inch and refit with 1 1/8 internals. I'm pretty sure this would be possible because I've sent in cores in the past that had pits so deep that you would have to bore out an extra 1/8 inch to clean them up. I had all of my wheel cylinders and master cylinder sleeved with stainless steel a few years ago and I'm sure they had to bore out to install the sleeves. So maybe this is an option. Anyway, sorry for any confusion I may have added. http://www.how-to-build-hotrods.com/brake-system.html https://www.bing.com/images/search?q=brake+line+residual+... | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | 1960fury - 2020-12-03 11:38 PM wizard - 2020-12-03 11:49 AM The two pistons are agood part ofthe problem Sid. I imagine that the "new" m/c is n for 4 cylinders, 2 front and 2 rear and with lesser diameter, let's say 1". That would be just fine as the displacement of the stroke will give the same portion to front and rear. Now, if the "new" m/ c is mounted in a Car with 6 cylinders, it's a problem, since One port must supply 4 cylinders and the other port only 2. Is the number of wheel cylinders of importance and not the number/diameter of the pistons/bore? It is the pistons that needs to move regardless where it is installed. There are 4 pistons in the rear and 4 in front. Yes of Course Sid, both number of Wheel cylinders as well as the diameter is important as the displacement of the m/c is divided by the number of Wheel cylinders and the diameter gives the ratio/movement I's a Dodge 60 with oem brakes, so 4 front cylinders and 2 rear cylinders | ||
Expert 5K+ Posts: 7395 Location: northern germany | wizard - 2020-12-03 11:59 PM 1960fury - 2020-12-03 11:38 PM wizard - 2020-12-03 11:49 AM The two pistons are agood part ofthe problem Sid. I imagine that the "new" m/c is n for 4 cylinders, 2 front and 2 rear and with lesser diameter, let's say 1". That would be just fine as the displacement of the stroke will give the same portion to front and rear. Now, if the "new" m/ c is mounted in a Car with 6 cylinders, it's a problem, since One port must supply 4 cylinders and the other port only 2. Is the number of wheel cylinders of importance and not the number/diameter of the pistons/bore? It is the pistons that needs to move regardless where it is installed. There are 4 pistons in the rear and 4 in front. Yes of Course Sid, both number of Wheel cylinders as well as the diameter is important as the displacement of the m/c is divided by the number of Wheel cylinders and the diameter gives the ratio/movement I's a Dodge 60 with oem brakes, so 4 front cylinders and 2 rear cylinders Well, again, the rears are duals (1x2 pistons each per side) the front singles (2x1 piston per side). That's 4 pistons front and 4 pistons at the rear. The number of wheel cylinders ist not of importance. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Yes Sid, but that means that the rear piston max stroke is divided by 2 which makes the rear brakes less powerful and also very important to adjust the rear brakes as close to the drum as possible. The new mc is surely for wheel cylinders with 1" diameter and two pistons per cylinder. The new drum/drum system had 1 cylinder per wheel if I recall correctly. | ||
Todd |
Veteran Posts: 147 | Well folks i will now try this 1.125" piston disc/drum master https://www.ebay.com/itm/1966-1970-Mopar-Bendix-Style-Manual-Disc-Dr... with a extern 10 lb residual valve for the front lines. I will let you know what happens. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Todd, I think you will find that your pedal will firm up with the larger bore MC. If your lines are truly bled of air and you can push your pedal to the floor that means you are not trying to compress the liquid, which is not compressible, in your system. You might be moving your wheel cylinder pistons but not to the point that they all bottom our and you begin to feel the increased pressure. A larger bore with the same pedal stroke will move more volume get you to that point. I have added front disc brakes to 4 old mopars now, the first was a great learning experience and made my last three go flawlessly. Like you, I got my system together and the car stopped, but the pedal was soft and went to the floor. The MC had a 1 & 1/32" bore, so I switched to a 1 & 1/8" bore MC and the brakes were perfect. By the way, later mopar MCs didn't have any residual valves build into them, instead they were external. You can then pick a MC bore of your liking and then add the external residual valves you need. Let us know how it goes. | ||
Expert 5K+ Posts: 7395 Location: northern germany | wizard - 2020-12-04 12:37 PM Yes Sid, but that means that the rear piston max stroke is divided by 2 which makes the rear brakes less powerful and also very important to adjust the rear brakes as close to the drum as possible. The new mc is surely for wheel cylinders with 1" diameter and two pistons per cylinder. The new drum/drum system had 1 cylinder per wheel if I recall correctly. The rear brakes SHOULD be less powerfull, however, it does not matter where the pressure is divided, in a wheel cylinder or outside of it, like in the front. There is just one line going in, front or rear. Every piston has to move a certain amount for braking action, regardless if it is a single 2 piston wheel cylinder or 2 single pistons per wheel. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Yes of Course Sid, but everyone knows that the rear brakes must have less force than the front. | ||
Expert 5K+ Posts: 7395 Location: northern germany | wizard - 2020-12-04 4:36 PM Yes of Course Sid, but everyone knows that the rear brakes must have less force than the front. :laugh: It is the design of the 2 brake cylinders per wheel that makes the braking more effective, creating 2 "forward" brake shoes. The force should be the same from a single pot MC, if there is no restriction in the distribution block to the rear. The rears are NOT "less powerfull" because it is a dual cylinder. Again, where the force is divided is of no importance. 1 pessure line to 2 pistons, front and rear. | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Forgot to add this, helpful to pick out a master cylinder for your application: http://therammaninc.com/files/categories/Moparts_Complete_Guide_to_... | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | Good job finding a 1 1/8 bore master cylinder Todd. I looked for an hour and couldn't find one. I bet this may fix you up. Just one extra thought on brake line routings. It is better not to have a high spot in the line that can trap air. I think this doesn't matter too much since the line diameter is so small but just better. When we used to design piping systems in refineries, we always made sure of this. | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | One general type of question for the brake systems on these cars. During all of studying this, I found an article about nose diving when you put your brakes on hard and suddenly, which my car does. The article said that if this happens, it means the residual valve to the back wheels is not working (or in my case, the residual valve doesn't exist). Do all of these 1950s cars sort of nose dive when you put the brakes on hard? Have folks added a residual valve to the line going to the back drums to reduce this nose diving? Or is the nose diving just a normal part of these cars? Just wondering now that I have a new understand of the brake systems. Thanks for your original question Todd because I have really learned a lot. Sam | ||
Expert 5K+ Posts: 7395 Location: northern germany | All cars nose dive. Of course our cars have softer springs and heavy engines but a faulty residual valve could make it worse (good point). You can make a night and day difference if you move the battery (that is in the worst possible location) to the right rear trunk. | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | That is a heavy battery and way up front. And it would also be nice to have it out of the way. I may look into moving it. This has sure been a good learning discussion about brakes for me. Even applies to more modern cars. | ||
NC Adventurer |
Veteran Posts: 148 | Here's a decent article on the issue of calculating master cylinder bore size and pedal ration: https://www.onallcylinders.com/2014/08/07/pedal-pushers-figure-pedal... Will this M/C fit your needs? Bore is 1.125". https://www.autozone.com/brakes-and-traction-control/master-cylinder... | ||
Expert 5K+ Posts: 9654 Location: So. Cal | On this thread, I show how to calculate all you could want to know about brake system design and I also implicitly show that a 1" master should build pressure in an all drum system without any issue as long as the brake shoes are adjusted to a reasonable level. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=71807 | ||
Todd |
Veteran Posts: 147 | I'll find out this week when the new master has been delivered. Please be patient. @ jboymechanic & NC Adventurer: Thank you for your interest in this topic and the helpful, interesting links.Many thanks to everyone who contributed to this topic.I will be back soon..... Edited by Todd 2020-12-07 9:39 AM | ||
Todd |
Veteran Posts: 147 | Hi guys, I'll get back to you. The new disc / drum master with 1 1/8 "bore is built in. And .... YES .... it works! I have a firm pedal and really good brake pressure. BUT .... only when I push the pedal the second time The first step on the pedal is almost to the floor. The rear port of the master has an internal 10 lb residual valve. For the front port I installed an external wilwood 10 lb (10 psi) residual valve into the line. On the picture you can see the position where I installed it (don't have a current picture yet - it is the picture with the old master with the small bore that did not work). [img]https://thumbs.picr.de/40069177tl.jpg[/img] What do you think, why is it that I only have firm pressure on the pedal the second time I push the pedal? Is the position of the external residual valve incorrect? Or are there still air bubbles in the brake lines after all? I bleed twice ... Edited by Todd 2020-12-12 1:53 PM | ||
Expert 5K+ Posts: 9654 Location: So. Cal | Did you replace that plug yet? | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Todd, do this test first; Adjust the rear brake shoes to full contact, both sides and see if that gives something. If not, adjust also the front brake shoes to full contact, both sides and see if you get some improvement. If you get a firm pedal, press hard and make a measurement from the depressed brake pedal to the steering wheel or the dash. Release the pedal and wait 2 minutes - press down the pedal again and check if you have the same measurement as before - if not, then there's still some air trapped in the system. If you don't get any improvement, then you must measure the displacement of the oem m/c and thereafter the combined displacement from the dual /mc and check if you have approximately the same amount of fluid. Check also if you have more fluid from one of the ports in the dual m/c - if so, you must use that to the front wheels | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | I agree with Sven about adjusting the brakes. If you have to pump to get good pedal, it means your brakes are too far away from the drum. I have been driving my car for about 300 miles with new brake shoes and now I have a low pedal on the initial press and it will stop the car but if I pump the brake one time, it get a high pedal. I know my brakes need adjusted and I will do that this weekend. What you are describing is exactly what we would get when I was a kid and we had to adjust the brakes. These old cars have zero automatic brake adjustment so you have to adjust them from time to time and you have to adjust them a second time pretty soon after you put new brake shoes because the brake shoes burn in and lose a little thickness. It could be air in the lines but it sounds like brake adjustment to me. When you pump the brakes and get a high pedal, is it spongy or solid as a rock. Spongy is air and solid as a rock is shoe adjustment needed. The great news is you are very close now. And I will know exactly how to put a dual cylinder on my car... | ||
Todd |
Veteran Posts: 147 | Hi friends. Sorry that I’m only getting back to you now. I have a lot to do on the job right now, and the working days are really long right now. When i pump and get a high pedal, it is solid as a rock. Can't push further downward. I have just readjusted the drums. If I adjust the brake shoes even more close to the drum, they rub too hard on them. Sven: Unfortunately, I don't have the time for the tests at the moment and I'm a little too tired for that. I've already used over 4 liters of fluid and need a little break :)When I have time, I bleed the brake system again. There may still be some air in the system. I will keep you up to date. Thanks again for all the helpful support, i really appreciate that. Edited by Todd 2020-12-15 9:55 AM | ||
Todd |
Veteran Posts: 147 | I have now read that it is common for dual-circuit brake systems to start bleeding at the front-wheel brake cylinder which is nearest to the master cylinder. That's new to me. Can you confirm that ??? Edited by Todd 2020-12-15 12:10 PM | ||
