Single circuit to dual circuit Jump to page : 1 2 3 Now viewing page 3 [50 messages per page] | View previous thread :: View next thread |
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | It's always the same procedure Todd, start with the wheel cylinder farest from the m/c - in a dual circuit that would be the front right lower wheel cylinder, front right upper wheel cylinder, front left wheel lower wheel cylinder, front left upper wheel cylinder, rear right wheel cylinder and rear left wheel cylinder. Naturally depending which port is using for front circuit. If you adjust the brake shoes to full contact (blocked wheels) it will be easier to bleed out the eventual air. Do my measuring test before you start to bleed. That will tell you if there's any air in the circuits. | ||
Todd |
Veteran Posts: 147 | Sven: unfortunaly it's too late for the test, I had to start over. During the last bleeding, the fluid in the master was used up and it drew in air. s**t happens. But i will do the measuring if i have to pump again at the second try. I will now set the brake shoes to full contact before bleeding. I've been thinking about an important thing. It affects the external residual pressure valve for the front port: On the picture you can see where I have placed it. I suspect it is too far away from the master - because: when I install the brake line at the master port, there is of course air in the brake line between the master and the residual presssure valve at the beginning. If I now press the brake pedal and release it again, this air is sucked back into the master, because the way to the residual valve is too long. The residual valve must be installed directly on the master port. And you can certainly help me: I need an adapter with a male 9/16 - 20 "connection (into master) and a male 3/8 - 24" (into residual valve). Do you know where I can buy something like this? Is there such an adapter? Or do i think wrong with my theorie? Edited by Todd 2020-12-15 1:32 PM | ||
Expert 5K+ Posts: 9654 Location: So. Cal | Another common issue is the residual valves look like they come well seated and sealed. That often isn't the case. You need to remove the pipe threaded connectors and re-apply them with teflon tape to seal them well. | ||
Todd |
Veteran Posts: 147 | Good thought, I'll seal them beforehand. | ||
Todd |
Veteran Posts: 147 | wizard - 2020-12-15 1:00 PM If you adjust the brake shoes to full contact (blocked wheels) it will be easier to bleed out the eventual air. You mean set the shoes to the fully released position Sven? https://youtu.be/oVCb0TE0lMI See at minute 4:00..... Edited by Todd 2020-12-15 2:32 PM | ||
Expert 5K+ Posts: 7393 Location: northern germany | Todd - 2020-12-15 1:20 PM I've been thinking about an important thing. It affects the external residual pressure valve for the front port: On the picture you can see where I have placed it. I suspect it is too far away from the master - because: when I install the brake line at the master port, there is of course air in the brake line between the master and the residual presssure valve at the beginning. If I now press the brake pedal and release it again, this air is sucked back into the master, because the way to the residual valve is too long. The residual valve must be installed directly on the master port. And you can certainly help me: I need an adapter with a male 9/16 - 20 "connection (into master) and a male 3/8 - 24" (into residual valve). Do you know where I can buy something like this? Is there such an adapter? Or do i think wrong with my theorie? It is not too far away, but of course the closer to the MC the better and of course you have to bleed the system again after the instalation of the residual valve so I don't get the problem. All residual valves I have ever seen are tapped for 1/8 NPT threads. | ||
Todd |
Veteran Posts: 147 | Yes you're right. But Wilwood sell them with inverted 3/8 - 24 adapters to directly install the brake line. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Todd - 2020-12-15 8:31 PM wizard - 2020-12-15 1:00 PM If you adjust the brake shoes to full contact (blocked wheels) it will be easier to bleed out the eventual air. You mean set the shoes to the fully released position Sven? https://youtu.be/oVCb0TE0lMI See at minute 4:00..... The adjusting cam is an excenter Todd, so fully backed off will be locked wheels as well. Try and check | ||
Expert 5K+ Posts: 7393 Location: northern germany | Todd - 2020-12-15 3:35 PM Yes you're right. But Wilwood sell them with inverted 3/8 - 24 adapters to directly install the brake line. So wouldn't it be more logical and easier to search for, or fabricate a 9/16-20 to 1/8 NPT adapter? Also cleaner looking and a connection that can leak less. Maybe you can just tap the 9/16 MC tube nut (if there's enough meat) and use a male/male 1/8 NPT to 1/8 NPT connector? | ||
Expert 5K+ Posts: 9654 Location: So. Cal | I'm not following what you are saying Sid. All connections go to 3/16 line - even at the master, so how does what you are saying help anything, or is even possible to do? I also wouldn't want that long residual valve sticking out of my master. Edited by Powerflite 2020-12-15 4:07 PM | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Also Todd, I don't think that you have air in the system, you confirm that you have a rock hard pedal on the second sttoke. Adjusting the brake shoes to full contact means that ther will be no lash, so first stroke still might be low, but thereafter you should have the same height every time you try the brakes If you get this condition with low pedal on every stroke, then the displacement is too low. | ||
Expert 5K+ Posts: 7393 Location: northern germany | Powerflite - 2020-12-15 4:05 PM I'm not following what you are saying Sid. All connections go to 3/16 line - even at the master, so how does what you are saying help anything, or is even possible to do? I also wouldn't want that long residual valve sticking out of my master. Why do you want to run a 3/16 line between the MC and the residual valve when you can attach it directly to the MC? They ain't that long and It still looks better than a valve in the middle of a brake line and you can use a 90° adapter. In my car it is attached directly to the prop valve as desribed with a male/male NPT connector but I will change it eventually and move it to the MC. | ||
Expert 5K+ Posts: 7393 Location: northern germany | I know such things are considered a "No-No" when you work on brake systems, as it is 9/16-18 thread not 20, but it will work anyway. I am a safety neard. Maybe you have to run a 9/16-20 die on it and of course you have to grind off the AN cone. https://www.ebay.de/itm/Gewindeadapter-1-8-NPT-zu-Dash-6-90-schwarz-... | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | Todd, I sure enjoyed and learned from the video you posted showing how to bleed and adjust the brakes. | ||
Todd |
Veteran Posts: 147 | Thanks samstrader. Yes....TECH ist the best of the best. Always ask Tech - he knows :) | ||
Expert 5K+ Posts: 7393 Location: northern germany | 1960fury - 2020-12-15 4:02 PM Todd - 2020-12-15 3:35 PM Yes you're right. But Wilwood sell them with inverted 3/8 - 24 adapters to directly install the brake line. So wouldn't it be more logical and easier to search for, or fabricate a 9/16-20 to 1/8 NPT adapter? Also cleaner looking and a connection that can leak less. Maybe you can just tap the 9/16 MC tube nut (if there's enough meat) and use a male/male 1/8 NPT to 1/8 NPT connector? I checked and yes, the MC tube nut is big enough. So you can simply tap it and screw the residual valve directly to the MC with that: (NPT-elbow.jpg) Attachments ---------------- NPT-elbow.jpg (113KB - 244 downloads) | ||
dplotkin |
Veteran Posts: 153 Location: Massachusetts | Todd: I posted on the linked thread "spongy brakes" concerning the same problem I had with a 1960 F with front disks and stock drums using a drum/drum master. The drum/drum master will fit under the booster and I have this setup working well in my 61 Plymouth Savoy with later Mopar B body rear drums and GM single piston calipers. Because it worked in the Plymouth I thought it would work in the 300 F. No dice. Same as you - too much travel not enough juice. Finally employed the taller but shorter Bendix disk/drum master for a 70 Imperial. I cut .700 from the top of the jar & threaded in two screws to hold the lid on. This master is a one inch and an eighth bore and has sufficient volume. Pedal travel is still longer than I would like but it is acceptable. Try that master - no reason why you cannot use a disk/drum master on a drum/drum setup. Just use a 10 pound residual valve in the front circuit. See the aforementioned thread where I posted photos. Dan | ||
Todd |
Veteran Posts: 147 | Hi. Thanks. I purchased a brandnew 1 1/8 bore disc/drum master and installed a 10 psi external wilwood residual valve in the line. The first try did not work as i wrote. But I'll try again. I will bleed the front brake circuit particularly thoroughly and see what happens. But not enough time at the moment. I'm sure I'll do it before Christmas. I won't buy a third MC. If it doesn't work this time, I'll give up. I will report...thanks!! BTW...The OE line from master to the front tee was 1/4"....maybe that will have the necessary effect to feed the brake 4 front cylinders....maybe it is worth a try too...if 1/4" line will fit to the port of the MC...hmmm....will it fit? Worth a try or not? Edited by Todd 2020-12-17 12:07 PM | ||
Todd |
Veteran Posts: 147 | 1960fury - 2020-12-16 3:06 PM I checked and yes, the MC tube nut is big enough. So you can simply tap it and screw the residual valve directly to the MC with that: Hmmm....how's about this adapter...would it also work? https://wabotech.de/ORFS-Einschraubverschraubung-UNF-9-16-18-AG-NPT-... | ||
Expert 5K+ Posts: 7393 Location: northern germany | Todd - 2020-12-17 1:42 PM 1960fury - 2020-12-16 3:06 PM I checked and yes, the MC tube nut is big enough. So you can simply tap it and screw the residual valve directly to the MC with that: Hmmm....how's about this adapter...would it also work? https://wabotech.de/ORFS-Einschraubverschraubung-UNF-9-16-18-AG-NPT-... Yes, good find! But it would make the valve stick out. Since it is 9/16-18 oo it might need a little reworking with a -20 die but it is not aluminum, like the elbow fitting I posted, so it would be even safer. Edited by 1960fury 2020-12-17 4:14 PM | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | I used this site to buy my 7/16 x 20 Tube Nuts. I went to the page that has Plugs and the BQ 162 is a 7/16 X 20 plug. Would this work? They also have 1/2 x 20. All of my fittings were 7/16 X 20. Anyway, not sure exactly what you need but these people sure have a lot of this unusual stuff and I was very pleased with what I got from them. Fit perfect. https://www.mfcp.com/product/fittings/automotive-fittings/plugs-caps... Edited by samstrader 2020-12-19 6:26 PM | ||
Expert 5K+ Posts: 9654 Location: So. Cal | 7/16-20 was used on '55-'56, but the '57-up cars used 7/16-24. | ||
Todd |
Veteran Posts: 147 | Merry christmas to all. As for the conversion from the single-circuit to the dual-circuit brake - that's it, i quit! The second attempt didn't work either. Firm pedal only when pumping the pedal. Then if I wait a few seconds, I have to pump again. Even if i adjust the shoes to full contact. Now I'm looking forward to installing the old single-circuit MC. I'm really looking forward to a firm pedal and good brakes, just like it was before. Thank you for your involvement and help. I wish you all a happy new year! Thanks, Todd. Edited by Todd 2020-12-26 1:50 PM | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Sorry Todd, it's a drag after all the work and effort. At least, you confirmed that the displacement of the m/c is insufficiant in the tested ones. Please make a post of the brand, article number and diameter here | ||
Todd |
Veteran Posts: 147 | MBM Disc/Dum MC MC5621 Cast Iron Original Bendix Style 2225621 1-1/8" Bore 9/16"-20 INV & 1/2"-20 INV 10lb residual valve built in to rear port. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Thanks' Todd, I assume this is the last dual circuit m/c tested, what about the first one? | ||
Todd |
Veteran Posts: 147 | Auto City Classic Drum/Drum Brakes MC1323 Mopar Bendix Style RPB8001 Manual or Power Applications 1" Bore 9/16"-20 INV & 1/2"-20 INV W/ Builtin internal residual valves As for the single MC: Between MC and the tee there is a 1/4" line, i also want to replace, but i don't have the tool to flare 1/4" lines, so i have to order the line - flared with the correct fittings ready to install. The size of those fittings is 7/16-24 UNF (long 20 mm version) BOTH sides, am i right? Edited by Todd 2020-12-27 9:14 AM | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Todd - 2020-12-27 2:31 AM Auto City Classic Drum/Drum Brakes MC1323 Mopar Bendix Style RPB8001 Manual or Power Applications 1" Bore 9/16"-20 INV & 1/2"-20 INV W/ Built-in internal residual valves Todd: So something like this? Any idea where I could buy just the push-rod accessories? I am going to use a similar Raybestos MC36221 (as shown below): Edited by 56D500boy 2020-12-27 12:19 PM | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Todd - 2020-12-27 11:31 AM As for the single MC: Between MC and the tee there is a 1/4" line, i also want to replace, but i don't have the tool to flare 1/4" lines, so i have to order the line - flared with the correct fittings ready to install. The size of those fittings is 7/16-24 UNF (long 20 mm version) BOTH sides, am i right? I'll try to check this tomorrow Todd | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | I'm sorry it didn't work out Todd. You did great work I think and it is so frustrating when you can't make something work out after working so hard. I can totally relate to your frustration. Thanks for posting everything because your lessons learned help us all understand how brakes work better and also helps our thinking when considering going to dual master cylinders. I think I'll just stay with my single master now even though I know a dual cylinder is a lot safer. Sam Edited by samstrader 2020-12-27 1:46 PM | ||
Todd |
Veteran Posts: 147 | 56D500boy - 2020-12-27 12:15 PM Todd: So something like this? Any idea where I could buy just the push-rod accessories? I am going to use a similar Raybestos MC36221 If you still have your old single master, you can re-use both, rod and clamp/mounting, both fits to the new MC. Sam: Thanks a lot Sam, there are all nice and helpful people here, fantastic forum. Sven: thanks for have a look at the requested thread sizes Edited by Todd 2020-12-27 2:02 PM | ||
Expert 5K+ Posts: 9900 Location: Lower Mainland BC | Todd - 2020-12-27 10:57 AM 56D500boy - 2020-12-27 12:15 PM Todd: So something like this? Any idea where I could buy just the push-rod accessories? I am going to use a similar Raybestos MC36221 If you still have your old single master, you can re-use both, rod and clamp/mounting, both fits to the new MC. Not if you change the pedal assembly like I am planning. (Needs a clevis at the pedal end like the original 55 Mopar PB/MC combo had). Edited by 56D500boy 2020-12-27 5:10 PM | ||
Expert 5K+ Posts: 9654 Location: So. Cal | You can get things like that at Summit. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Todd - 2020-12-27 11:31 AM As for the single MC: Between MC and the tee there is a 1/4" line, i also want to replace, but i don't have the tool to flare 1/4" lines, so i have to order the line - flared with the correct fittings ready to install. The size of those fittings is 7/16-24 UNF (long 20 mm version) BOTH sides, am i right? Ok Todd, just checked; the 1/4" fittings are both male 7/16"-24 UNF and 3/3" (approx 20 mm) long will work just fine. | ||
Todd |
Veteran Posts: 147 | Thanks so much Sven! | ||
Expert 5K+ Posts: 9654 Location: So. Cal | I just finished bleeding the brake system on my '56 Fury with front discs, original rear drums & a 1.032" dual disc brake master. It has a solid, high pedal now with about 1.5" of travel. The only issue is the pedal is firm even with the rear bleeders open. The rear brake hose must have plugged itself off, but was open enough to allow the air to escape past it while under pressure. | ||
Todd |
Veteran Posts: 147 | Hi Guys. Finally, I would like to contact you again on this topic. I have now reinstalled the single-circuit master and immediately had the good feeling of a firm and rock solid pedal. This is the final proof that a two-circuit master does not work on a car with drums all around - not even if it has the same bore size. At least not if the car has six wheel brake cylinders. Now I have a single circuit brake system again with new components. I overhauled the master, the brake lines are all new and the wheel brake cylinders are all new too. A tedious experience, but in the end I am happy that everything is working properly again. Thank you to everyone who shared my thoughts on this topic and wanted to help. Best wishes, Todd Edited by Todd 2021-01-18 9:52 AM | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Great Todd! Now you must maintain your brake system. Change the brake fluid every two years if you use DOT3. That will prevent rust issues. Or use DOT5, but then you must clean out the DOT3 or 4 from the system. | ||
samstrader |
Extreme Veteran Posts: 443 Location: Beaumont TX | I'm glad everything is working again Todd.... Congratulations. I also appreciate your work and documentation because it applies to my car 100 percent. I'll know what to do with mine now. Sam | ||
