Plastic barrier between door and interior door panel
jboymechanic
Posted 2020-06-29 11:58 PM (#600319)
Subject: Plastic barrier between door and interior door panel
10005001001001002525
What is a good material to install between the inside of the interior door panel and the door? I don't recall removing any paper, plastic or anything when my Imperial came apart, but I know that it would be best to put some kind of barrier material in there to make sure my panels don't get water spots should water get inside the door or rear quarter. What are people here using?
Posted 2020-06-30 1:04 AM (#600321 - in reply to #600319)
Subject: Re: Plastic barrier between door and interior door panel
50005000200010010025
I use age resistant plastic foil, the type used in houses as a moist barr ier.
The lower part should be inserted through the Long slot in the door so the moist will be Lead into the door and not to the interior.
Posted 2020-06-30 1:52 AM (#600322 - in reply to #600321)
5000100010025
wizard - 2020-06-29 10:04 PM
Agree. I used 6 mil polyethlyene vapour barrier sheeting (as used in house construction) when I re-did my four 4dr sedan doors. I also tucked the tail into the slot, as Sven suggested.
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69434&...
Edited by 56D500boy 2020-06-30 1:53 AM
Posted 2020-06-30 10:21 AM (#600339 - in reply to #600319)
500010005002525
Hot glue works really well to attach it too. I would recommend painting the insides of your panels with a good sealer if/when the barrier eventually fails for some reason.
Posted 2020-06-30 12:01 PM (#600343 - in reply to #600339)
5000100010025
Powerflite - 2020-06-30 7:21 AM I would recommend painting the insides of your panels with a good sealer if/when the barrier eventually fails for some reason.
Agree. This is what I did when I made my first panel from Masonite: The white is an oil-based primer. The blue is "ZeroRust" metal spray paint on the new clips that I added.
jboymechanic
Posted 2020-06-30 9:28 PM (#600366 - in reply to #600319)
Like this stuff here from Menards:
https://www.menards.com/main/paint/painting-protection/plastic-sheet...
